Anyone ever work with a DE like this?
  • Context: Graduate
  • Thread starter Thread starter Mosis
    Work
The discussion revolves around a nonlinear differential equation of the form r^2(d^2Y/dr^2) + r(dY/dr) - (3/2)^2Y = Cr^3Y^{1/3}. Participants explore potential methods for analyzing the equation, including perturbation techniques and the implications of the nonlinearity introduced by the Y^{1/3} term. The conversation touches on the existence of bounded solutions and the behavior of solutions under different conditions for the parameter C.
  • One participant notes the challenge posed by the nonlinear nature of the equation, suggesting that knowing solutions to the homogeneous part may not aid in finding solutions to the full equation.
  • Another proposes a perturbation method, suggesting a series expansion in powers of C, but expresses concern about the intractability introduced by the Y^{1/3} term.
  • A different participant suggests expressing the Y^{1/3} term using a series expansion, acknowledging the complexity that arises beyond the first two terms.
  • Some participants discuss the implications of the sign of C, indicating that for C>0, solutions may be unbounded, while for C<0, the behavior could be more complicated, potentially leading to solutions that blow up.
  • There is a suggestion to rewrite the equation in terms of a new variable z = ln(r) to analyze the behavior of solutions more effectively.
  • One participant questions the assumption that Y is positive, arguing that the behavior of the first derivative is crucial for determining the boundedness of solutions.
  • Another participant emphasizes the importance of plotting the solutions to understand the vector field and suggests using numerical methods to explore the behavior of solutions under various initial conditions.
  • Further contributions include a suggestion to analyze critical points and the stability of solutions, particularly for C<0, and a warning about the proper handling of the Y^{1/3} term in simulations.
Participants express differing views on the implications of the nonlinearity and the behavior of solutions based on the value of C. There is no consensus on the existence of bounded solutions or the best approach to analyze the equation, indicating ongoing debate and exploration of the topic.
Participants highlight the complexity introduced by the Y^{1/3} term and the challenges in applying perturbation methods. The discussion also reflects uncertainty regarding the assumptions about the positivity of Y and the implications for solution behavior.
Mosis
This has come up in my research, and my supervisor and I don't really know how to proceed. It reads
r^2\frac{d^2Y}{dr^2} + r\frac{dY}{dr} - \left(\frac{3}{2}\right)^2Y = Cr^3Y^{1/3}
I know the RHS is an equidimensional DE which has the nice solution Y = r^{\pm 3/2}, but I have no idea how this could help with that nasty Y^{1/3} term sitting on the RHS.
Really, we just want to learn SOMETHING about this DE. What do the solutions look like? Does a bounded solution exist? What can we do if C is small? etc.
Any ideas?
wow, 46 views, no reply - is this really that uncommon?
The problem is that that is a seriously non-linear equation. Since solutions of non-linear equations do not add to another solution, Knowing a solution to LHS= 0 does not help. For C small, you might try a perturbation method, writing the solution as a series in powers of C: y_0+ Cy_1+ C^2y_2+ \cdot\cdot\cdot. Substituting that into the equation and equating like powers of C will give, for the "C0" term, the homgeneous equation as the equation for y_0. Then the "C1 term will gvie a non-homogeneous equation for y_1 with the (now known) y_0 on the right side, etc.
I was thinking about that kind of perturbation scheme, but the fact that we have Y^1/3 makes that intractable i.e. what to do with \left(Y_0 + CY_1\right)^{1/3}?
You could express it as Y_0^{1/3} (1+C(Y_1/Y_0)+C^2(Y_2/Y_0)+...)^{1/3} = Y_0^{1/3}(1 + \frac{1}{3}(C(Y_1/Y_0)+C^2(Y_2/Y_0)...) - \frac{1}{9}(C(Y_1/Y_0)+C^2(Y_2/Y_0)...)^2 ...
because (1+x)^a = 1 + xa + x^2 a(a-1)/2! + x^3 a(a-1)(a-2)/3! + ..., x \ll 1
It will be incredibly messy beyond the first two terms, but at least you can get some results.
By the way, it would simplify your calculations if you did a substitution z = \ln{r}.
Further thoughts.
There are two distinct cases, C>0 and C<0.
Once you rewrite your expression as r = ln z, Y&#039;&#039; = 9/4 Y + C e^{3z} Y^{1/3},
it's easy to see that, as long as C>0, all nontrivial solutions are unbounded (because the second derivative is always positive, therefore the graph of the function is convex).
Every individual solution will look like a bunch of exponentials a*exp(b*z) stitched together, depending on which of the two terms on the right hand side dominates (most of the time, one of the two terms would be negligible). Draw a plot of the solution of the equation 9/4 Y = C e^{3z} Y^{1/3}. Use log scale on the vertical axis. Think about the behavior of a solution of your DE that passes through a point to the left of the curve. See if you can prove (or at least convince yourself) that almost all solutions either blow up because Y crosses below zero, or diverge as exp(-1.5 z) as z\rightarrow -\infty and as exp(4.5 z) as z\rightarrow +\infty.
If C<0, things are more complicated, and many solutions would blow up at some point because there's nothing to keep Y from going negative.
hamster143 said:
Further thoughts.
why are you assuming Y is positive? also, exp(-r) is convex but decays as r goes to infinity. Of course, it blows up in the other direction, but in my case, Y = Y(r), and r > 0, so I'd really need some information about the first derivative to conclude all nontrivial solutions are unbounded.
hamster143 said:
Further thoughts.
also, I'm not sure why you suggest plotting the solution to that equation - how can that help me?
Because Y^(1/3) is only defined for positive Y.
Yes, exp(-r) is convex. But notice my variable change: from r that goes 0..infinity, to z that goes from minus infinity to infinity.
If you have a function whose argument goes from minus infinity to infinity and its graph is convex, it must be unbounded on either side.
Because either of two terms on the right hand side would dominate, depending on which side of the graph you are. So, as long as you're sufficiently far to the left, solutions of DE would behave as if there's no pesky cubic root term.
I agree with hamster143, even it does not help you in terms of the details it will give you a lot of information about the vector field. My suggestion is setup your DE in MATLAB or your favorite solver while keeping it nonlinear, and let the solutions from many (I mean many) initial conditions and get a feeling for the differential equation. You can even read off if there is a bounded solution or not.
You never know! It might act like almost linear in the region of interest. (Happened to me also)
hamster143 said:
Further thoughts.
you can further write that using the fact that Y=exp(9z/2) is an exact solution, and write Y=exp(9z/2)y(z), with :
y&#039;&#039;+9y&#039;+18y-Cy^{1/3}
which is autonomous, and proceed by local analysis.
you can check that the critical points are
y = y&#039;=0, and y=(-C/18)^{3/2}, y&#039;=0
the second stationary points leads to a non bounded solution Y(z). The jacobian at (0,0) is not defined, but we have the inequality
[y&#039;^{2}/2+9y^{2}-Cy^{4/3}3/4]&#039;=-9y&#039;^{2}
So, for C<0, y=0=y' is stable, and you might have bounded solutions
* beware when simulating that in matlab, y^(1/3) does not give the proper solution. try sign(y)*abs(y)^1/3 instead.
what do you mean by a convex graph
  • · Replies 36 ·
  • · Replies 0 ·
