MHB Finding the Derivative of the Inverse Function of a Cubic Polynomial
To find the derivative of the inverse function of the cubic polynomial \( f(x) = (2x+1)^3 \), the inverse function \( g \) is derived by first rewriting the equation and solving for \( g \). The derivative \( g'(x) \) is calculated using the relationship \( g'(x) = \frac{1}{f'[g(x)]} \). Given that \( f(0) = 1 \), it follows that \( g(1) = 0 \), allowing the evaluation of \( g'(1) \) as \( g'(1) = \frac{1}{f'(0)} \). The final result shows that \( g'(1) = \frac{1}{6} \).
karush
MHB
Let $f(x)=(2x+1)^3$ and let g be the inverse of $f$. Given that $f(0)=1$, what is the value of $g'(1)?$
ok not real sure what the answer is but I did this (could be easier I am sure}
rewrite as
$y=(2x+1)^3$
exchange x and rename y to g
$x=(2g+1)^3$
Cube root each side
$\sqrt[3]{x}=2g+1$
isolate g
$g=\dfrac{\sqrt[3]{x}-1}{2}$
so
$\left(\dfrac{\sqrt[3]{x}-1}{2}\right)'
=\dfrac{1}{6x^{\dfrac{2}{3}}}$
apply $x=1$
$\dfrac{1}{6(1)^{\dfrac{2}{3}}}=\dfrac{1}{6}$hopefully
$f(x) = (2x+1)^3 \implies f'(x) = 6(2x+1)^2$
$f$ and $g$ are inverses tells us two things ...
(1) $f(0) = 1 \implies g(1)=0$
(2) $f[g(x)] = x$
take the derivative of equation (2) ...
$f'[g(x)] \cdot g'(x) = 1 \implies g'(x) = \dfrac{1}{f'[g(x)]}$
$g'(1) = \dfrac{1}{f'[g(1)]} = \dfrac{1}{f'(0)} = \dfrac{1}{6}$
(2) $f[g(x)] = x$
Mahalo
btw how you rate this problem Easy, Medium, or Hard
Medium
noted thanks
(2) $f[g(x)] = x$
that helped a lot
