Solving the Elevator's Acceleration: Examining Newton's Laws
The discussion focuses on solving the problem of an object on a scale in an accelerating elevator, where the scale reads 8kg at rest and 9.2kg during acceleration. The key equations involved are F=MA, F=MG, and Fnormal=m(a-g). The solution requires understanding that the apparent weight increases due to the elevator's upward acceleration, leading to the conclusion that the elevator accelerates upwards. The apparent weight can be calculated using the formula m(a+g).
  • Understanding of Newton's Laws of Motion
  • Familiarity with the concepts of force, mass, and weight
  • Knowledge of basic algebra for solving equations
  • Ability to apply physics principles to real-world scenarios
  • Study the application of Newton's Laws in non-inertial reference frames
  • Learn about the relationship between mass, weight, and acceleration in physics
  • Explore the concept of apparent weight in varying gravitational contexts
  • Practice solving problems involving forces in accelerating systems
Students studying physics, educators teaching Newton's Laws, and anyone interested in understanding forces in dynamic systems.
Vipercobra
An object is placed on a scale in an elevator which reads 8kg at rest. This scale shows 9.2kg when the elevator accelerates. What is the direction and magnitude of the elevator's acceleration.
F=MA, F=MG, Fnormal=m(a-g)
Can't really work out how to approach this equation as normally acceleration is given while in this case the change in weight is given. Tried substituing 8 into F=MG which gave 78.4 but I don't know how to process from here. I also tried using the formula Fnormal=m(a-g) but acceleration is unkown so I don't know how to proceed.
I also find Newton's third law confusing when applied to an accelerating lift. From what I have read each force has an action reaction pair in which both are equal. When an elevator accelerates upwards the upward force of the elevator is larger than the downwards force of an object, MG. What is the action reaction pair in this instance? The force upwards on the object isn't equal to the downwards force because if they were the object wouldn't be accelerating upwards.
Lets work from the bottom up
The action reaction pair.
Action: The force due to gravity and the force that cause acceleration
Reaction: the force from the scale keeping the object stationary
This action reaction (equal and opposite reaction) theory only applies to objects that are not accelerating i.e they are either stationary or traveling at constant velocity.
Now for your problem
A scale measure weight, which is a force, not mass.
I assume you know how to convert from mass to weight for calculation purpose.
I also assume you know that gravity is a force that causes acceleration when the is nothing to react to the force like when it is placed on a scale.
Given this information all you have to do is apply logic to determine what direction the lift accelerate for the object to press harder on the scale's surface. then you can determine the actual acceleration.
Relevant equations
F= mg
F=ma
So then does that mean that the formula for apparent weight is simply m(a+g)??
  • · Replies 38 ·
