Applying the epsilon-delta definition
  • Thread starter Thread starter NATURE.M
    Definition
The discussion focuses on applying the epsilon-delta definition to the function g(x) = 1/x. The participants explore finding a value δ' that is less than δ = 1/10, ensuring that all x within the interval (2 - δ', 2 + δ') satisfy |g(x) - 1/2| < 0.1. They conclude that any δ' in the range (0, 1/10) will work, with specific examples such as δ' = 1/20 being validated through algebraic manipulation. The conversation emphasizes the importance of correctly demonstrating the relationship between δ and δ' through formal proof.
  • Epsilon-delta definition of limits
  • Basic algebraic manipulation
  • Understanding of function behavior near specific points
  • Knowledge of inequalities and their implications
  • Study the epsilon-delta definition in depth
  • Practice proving limits using the epsilon-delta method
  • Explore the implications of different δ values on function behavior
  • Learn about continuity and differentiability in relation to limits
Students of calculus, mathematics educators, and anyone interested in understanding the formal proofs of limits and continuity in functions.
NATURE.M
Consider the function g(x) = 1/x.
b. Find a number δ′ > 0 different from the number δ you found in the previous question such that all the values x ∈ (2 − δ′, 2 + δ′) satisfy that g(x) is within 0.1 of 1/2.
Note, I found I value δ>0 in an earlier question in which the values x∈(2−δ,2+δ) satisfy that g(x) is within 0.1 of 1/2. That value of δ=1/10.
This question b. practically asks the same thing, but for a different value δ'.
Now, I'm considering since we know δ=1/10, then 0<δ'<δ=1/10. Any value of δ' in this interval will satisfy the conditions in question. But how would I show this, more formally.
See if you can find exactly what range of values ##x## satisfy the requirement. You need
$$\left|\frac{1}{x} - \frac{1}{2}\right| < \frac{1}{10}$$
This is equivalent to
$$-\frac{1}{10} < \frac{1}{x} - \frac{1}{2}< \frac{1}{10}$$
Now do some algebra to try to turn this into an equivalent inequality of the form
$$? < x < ?$$
And so I obtain 5/3 <x<5/2.
But how does this demonstrate that 0<δ'<1/10?
Opps I just realized I made an error with a previous calculation, so neglect what I said earlier.
Which number (5/3 or 5/2) is closer to 1/2?
5/3 is closer.
I was thinking maybe I should just solve for δ' the same way I solved for δ (by using the epsilon delta definition, where ε = 1/10. And solving for δ' the same way you'd prove a limit).
Would that be simpler?
I like this approach a lot. Let's pick some δ', let's say δ' = 1/20. Then you want to prove that if 2-1/20 < x < 2+1/20, then |1/x-1/2| < .1. You should be able to do this in a single line knowing what you know.
So, letting δ'=1/20, and if |x-2|<1/20 then |1/x-1/2|<1/10. But from this what do we want to prove? There is no value δ to solve for.
NATURE.M said:
5/3 is closer.
Oops, I meant: which number is closer to 2, not which one is closer to 1/2. OK, so 5/3 is closer to 2. The distance between 5/3 and 2 is 1/3. So any ##x## which is closer than 1/3 to the point ##x=2## will work. What does this imply about the range of possible values for ##\delta'##?
(And yes, your proposed approach will work too. My approach will allow you to find all possible values of ##\delta'## that solve the problem, but that may be overkill.)
No, δ'=1/20 is the value that you solved for in your very first post. You said that any value δ' < 1/10 should work, so I said well let's take δ'=1/20 and see that it does work.
Well, 1/20 < 1/10, so if ##|x-2| < 1/20## then ##|x-2| < 1/10##. But 1/10 is the ##\delta## from your previous problem. Therefore...
I should probably note, that I made an error in calculating δ in the previous question. Its value should be δ=1/5. Although, it wouldn't make a huge difference.
So putting everything together:
We know from the previous question that δ=1/10 works. Then δ' will also work if
0<δ'<δ=1/10.
To prove this suppose δ'=1/20. Then, 1/20<1/10. So it follows that if |x-2|<1/10 then |x-2|<1/20. But we know δ works, as verified in the previous question. Therefore, δ' will also work.
0<δ'<δ=1/10.
No, this doesn't follow. If |x - 2| < 1/10, then x ##\in## (1.9, 2.1). There are plenty of numbers in this interval that aren't within .05 (= 1/20) of 2. A couple of them are x = 1.91 and 2.09.
Opps it should be if |x-2|<1/20, then |x-2|<1/10.
  • · Replies 20 ·
