Approximate the voltage with Kirchoff's law
The discussion centers on applying Kirchhoff's first law, represented by the equation E(t) = L * (di/dt) + R*i, to approximate voltage values at specific time intervals. Given the inductance L of 0.98 henries and resistance R of 0.142 ohms, the calculated voltage E(t) values for t = 1.00 to 1.04 seconds are 2.400, 2.403, 3.386, 5.352, and 7.320 volts respectively. The method used involves calculating di/dt using the slope formula and applying the three-point formula for better accuracy. The user seeks clarification on the calculation of di/dt at t = 1.04 and how to express di/dt in terms of t.
  • Understanding of Kirchhoff's laws, specifically Kirchhoff's first law.
  • Familiarity with calculus concepts, particularly derivatives and slopes.
  • Knowledge of electrical components, including inductance and resistance.
  • Experience with numerical methods, such as the three-point formula for approximating derivatives.
  • Study the application of Kirchhoff's laws in circuit analysis.
  • Learn how to derive expressions for di/dt in terms of time for dynamic systems.
  • Explore numerical methods for derivative approximation, including the three-point and n-point formulas.
  • Investigate the relationship between current, voltage, and resistance in electrical circuits.
Students in electrical engineering, physics enthusiasts, and anyone looking to deepen their understanding of circuit analysis and numerical methods for approximating derivatives.
Ryuuken
Kirchoff's first law gives the relationship E(t) = L * (di/dt) + R*i where L is the inductance, R is the resistance and i is the current.
<br /> \begin{tabular}{|c|c|c|c|c|c|}<br /> \hline<br /> $\emph{t}$ &amp; 1.00 &amp; 1.01 &amp; 1.02 &amp; 1.03 &amp; 1.04\\<br /> \hline<br /> $\emph{i}$ &amp; 3.10 &amp; 3.12 &amp; 3.14 &amp; 3.18 &amp; 3.24\\<br /> \hline<br /> \end{tabular}<br />
Suppose t is measured in seconds, i is in amperes, the inductance L is a constant 0.98 henries and R is 0.142 ohms. Approximate the voltage E(t) when t = 1.00, 1.01, 1.02, 1.03, 1.04.
Three-point formula: \frac{1}{2h}[f(x_{0}+h) - f(x_{1}-h)]
The official solution is:
<br /> \begin{tabular}{|c|c|c|c|c|c|}<br /> \hline<br /> $\emph{t}$ &amp; 1.00 &amp; 1.01 &amp; 1.02 &amp; 1.03 &amp; 1.04\\<br /> \hline<br /> $\emph{E(t)}$ &amp; 2.400 &amp; 2.403 &amp; 3.386 &amp; 5.352 &amp; 7.320\\<br /> \hline<br /> \end{tabular}<br />
Using 0.98*di/dt+0.142*i and di/dt = (y_{1} - y_{0})/(x_{1} - x_{0})
di/dt = 2, i = 3.10 I get 2.400.
di/dt = (2 + 2) / 2, i = 3.12 I get 2.403.
di/dt = (2 + 4) / 2, i = 3.14 I get 3.386.
di/dt = (4 + 6) / 2, i = 3.18 I get 5.352.
Now the last one is di/dt = 7 but how do I get that 7? For the other ones, I took the slope from both sides and divided by 2. The only way I can think of is to add all the previous slopes together and divide by 2, (2 + 2 + 4 + 6) / 2 = 7 but I'm not sure if that makes sense or why that would work.
Also, is there a way get some expression in terms of t for di/dt. So I can use a three-point formula like \frac{1}{2h}[f(x_{0}+h) - f(x_{1}-h)]. Substitute f(x) for E(t) to get \frac{1}{2h}[E(t_{0}+h) - E(t_{1}-h)].
Thanks.
Why do you give the "three point formula" when the problem says "using di/dt = (y_1-y_0)/(x_1- x_0)"?
Well my book says the results were given by the three-point formula (or some n-point formula) so I'm trying to figure out how to apply it to get the same result although using di/dt = (y_1-y_0)/(x_1- x_0) works.
Do you know if the way I got di/dt = 7 is correct? If so, why?
Thanks.
