Approximating Damped Oscillator Time Period and Frequency with Large n
The discussion centers on approximating the time period and frequency of a damped oscillator after a large number of oscillations, specifically when the amplitude drops to 1/e of its original value. For part (a), the derived relationship shows that the ratio of the damped period to the undamped period is approximately 1 plus a small correction term, which is clarified through the use of square root approximations. In part (b), the frequency ratio is similarly approximated, indicating that the damped frequency is slightly less than the undamped frequency. The conversation highlights the importance of applying mathematical approximations for small values in deriving these relationships. Overall, the thread provides insights into the behavior of damped oscillators in physics.
Allan McPherson
An oscillator when undamped has a time period T0, while its time period when damped. Suppose after n oscillations the amplitude of the damped oscillator drops to 1/e of its original value (value at t = 0).
(a) Assuming that n is a large number, show that $$\frac{T}{T_0}=\left (1+\frac{1}{4n^2\pi^2}\right) \approx 1 + \frac{1}{8n^2\pi^2}$$
(b) Assuming that n is a large number, show that $$\frac{\omega}{\omega_0} \approx 1 - \frac{1}{8n^2\pi^2}$$
$$x(t) = A e^{-\gamma t}cos(\omega t + \phi)$$
$$T = \frac{2 \pi}{\omega}$$
$$\omega = \sqrt{\omega_0^2 - \gamma^2}$$
[/B]
I've managed to get the equality for both parts. We want $$\frac{A}{e} = A e^{-\gamma t}cos(\omega t + \phi)$$
which is only true if
##\gamma n T = 1,## ##\omega n T = 2n\pi## and ##\phi = 2m\pi##​
which implies $$T = \frac{1}{\gamma n} = \frac{2\pi}{\omega}$$
So $$\omega_0 = \gamma\sqrt{1 + 4n^2\pi^2}$$
And
$$\frac{T}{T_0} = \frac{\omega_0}{\omega}=\frac{\gamma\sqrt{1+4n^2\pi^2}}{2n\pi\gamma}$$ $$=\frac{\sqrt{1+4n^2\pi^2}}{4n^2\pi^2} = \left ( 1 + \frac{1}{4n^2\pi^2} \right )^{1/2}$$
The answer to part (b) will clearly involve taking the inverse of the right-hand side of the equality and applying the same or a similar approximation.
I know I've seen this approximation before, but I can't for the life of me remember how it works. l would appreciate any help that can be offered.
Allan McPherson said:
An oscillator when undamped has a time period T0, while its time period when damped ?. Suppose after n oscillations the amplitude of the damped oscillator drops to 1/e of its original value (value at t = 0).
You miss a square root:
$$\frac{T}{T_0}=\sqrt{\left (1+\frac{1}{4n^2\pi^2}\right)} \approx 1 + \frac{1}{8n^2\pi^2}$$
If x << 1,
##\sqrt{1+x}=\sqrt{(1+x/2)^2-(x/2)^2 }\approx \sqrt{(1+x/2)^2}=1+x/2##
Also ##\frac{1}{1+x}## is the sum of the geometric series 1-x+x^2-x^3+..., approximately 1-x if x << 1.
You meant
$$=\sqrt{\frac{1+4n^2\pi^2}{4n^2\pi^2}} = \left ( 1 + \frac{1}{4n^2\pi^2} \right )^{1/2}$$
Thank you. That clarifies the approximation for part (a). I'm not sure how that helps with part (b), though.
For part (b) I have $$\frac{\omega}{\omega_0} = \frac{2n\pi}{\sqrt{1+4n^2\pi^2}} = \sqrt{\frac{4n^2\pi^2}{1+4n^2\pi^2}} = \sqrt{1 - \frac{1}{4n^2\pi^2}}$$
Let be ##x=-\frac{1}{4n^2\pi^2}## . |x|<<1, apply the approxiamation for the square root as in Post #2.
Right. Looking at that again, I'm not sure how I thought that could be right. Thank you for your help.
