Find s, the arc length of a circle
The discussion focuses on calculating the arc length (s) of a circle given a radius of 3 meters and an angle of 4π/5 radians. The correct formula for arc length is s = rθ, which results in approximately 7.54 meters when calculated correctly. A common error identified was the incorrect use of 180 for π in the calculations. Participants emphasized the importance of using a calculator that can convert radians to decimal form accurately.
  • Understanding of arc length formula: s = rθ
  • Knowledge of radians and their relationship to degrees
  • Familiarity with using scientific calculators for trigonometric functions
  • Basic geometry concepts related to circles
  • Learn how to use a scientific calculator for trigonometric conversions
  • Study the relationship between radians and degrees in depth
  • Explore the derivation and applications of the arc length formula
  • Investigate common errors in angle conversions and how to avoid them
Students studying geometry, mathematics educators, and anyone needing to calculate arc lengths in practical applications.
mathdad
The question is asking me to find s, the arc length of a circle.
How do I convert my answer in radians to the book's answer 7.54 meters?
Theta = 4pi/5
radius = 3 meters
See picture.
Your result is already using radians (which are dimensionless) for the angle subtended, but your result will be a length, in meters because the given radius is in meters.. Just use your calculator to convert your result to a decimal approximation.
This is what I meant. How can I use the calculator to convert?
What sort of calculator do you have? Can you type in $12 \pi /5$? Usually there is a little $\lhd \rhd$ symbol which will convert to decimal form.
$12\pi/5\approx7.5398$
See greg1313 is his own calculator :p
I found my error out. I was using 180 for pi.
$180^{\circ}=\pi\,\text{rad}.$ That's your unit conversion equation.
Thank you everyone.
  • · Replies 16 ·
