Are complex numbers necessary in quantum mechanics?
219 replies · 33K views
maline said:
The question is a philosophical one: why did Nature "choose" complex amplitudes over real ones?
The ontological question of what the wave function means is independent, it seems to me, of whether or not it uses complex numbers. If you had a physical interpretation that said something like "the wave function is a length of some object" or "the wave function is a probability", then certainly complex values are unphysical. But it seems to me that worrying about whether it's complex prior to coming up with a physical meaning for it is putting the cart before the horse.
Certainly, you can always eliminate complex numbers by using matrices instead of numbers, or by using quaternions, or whatever. But I don't see that such a change is anything more than aesthetic.
On the other hand, Hestenes had a program, spacetime algebra, for replacing all occurrences of complex numbers in physics by geometric objects such as elements of a Clifford algebra. To a large extent, it can be done. I'm not sure, though, that it actually has helped in figuring out the ontology of the wave function. Hestene's interpretation of the Schrödinger equation, for example, interprets the ##i## in ##H |\psi\rangle = i \frac{d}{dt} |\psi\rangle## not as an imaginary number, but as a bivector representing the spin of the particle. That makes the Schrödinger equation into an approximation to the Pauli equation. So it's sort of interesting.
Well quaternionic quantum theory violates no-signalling. It's not entirely aesthetic. @maline is talking about a similar reason for the reals.
Just an update @maline , I did a bit of a literature search. I can't see an a priori argument eliminating the reals from first principles unlike the quaternions, although it is under investigation if local tomography hints at something and if the global degrees of freedom cause some problems to develop.
There is a paper by Adán Cabello here: https://arxiv.org/abs/1801.06347
He reconstructs quantum theory as the most general probability theory for an agent who can perform idealized measurements with discrete outcomes. Any more general theory leads to inconsistencies (probabilities sum to over unity) for repeated copies of an experiment. Just for interest Cabello uses the fact that it's the most general probability theory to argue that this implies it says little about nature.
Related to this discussion his argument only shows the most general probability theory is either Real or Complex QM. He has some comments at the end about trying to find the reason for the Hilbert space being complex.
A. Neumaier said:
The electromagnetic field in its Silberstein representation is another, classical complex-valued beable!
I don't think the Silberstein representation should be thought of as fundamental or ontological (even if classical EM would be true of Nature). It is not Lorentz-covariant, and it also does not nicely express the Lorentz force law, which is the main observable effect of the fields.
A. Neumaier said:
But then ##i## appears in the formula for the ##\tilde H## of a harmonic oscillator. So your propsed recipe doesn't help at all.
Indeed, once we start listing Hamiltonians for systems that actually turn up in the world, we quickly see that they look much more natural as operators on complex Hilbert space. That is part of what we wish to explain. However, note that if necessary, was can always do things in real Hilbert space, by having separate dimensions for (what in complex QM we call) the real and imaginary parts of each dimension coefficient. Then the imaginary number ##i## is replaced by the operator ##J## which exchanges them anti-symmetrically.
I am referring to interpretations like MWI or dBB, or even GRW, where the wavefunction is seen as a fundamental object, like a field. Indeed in may be the only fundamental object. So that answers what its "meaning" is, and we are free to ruminate on whether complex values seem appropriate.
I do magnanimously allow others to not share my niggling feelings and ruminations.
There is one important difference between complex QM and the real QM generated by thinking of the real and imaginary parts as different dimensions: the question of which operators count as linear. Operations like complex conjugation, or selecting the real or imaginary part, are linear on ##\mathbb R^2## but not on ##\mathbb C##, and similarly for larger Hilbert spaces. When we say that QM is complex rather than real, we are referring to the fact that all of the unitaries and observable operators that show up in QM are complex-linear, rather than merely linear in the corresponding real space. In other words, looking from the real-QM perspective, there is a pairing of dimensions into effective complex dimensions, that is maintained by all physical operators. One effect of this is that the state ends up only being fixed (by physical outcomes) up to a complex phase, or in real-QM terms, up to a 2-D rotation. On the face of it, this seems like good enough reason to conclude that the real-QM description is just unnatural and our world does use complex QM. This is something that could have been otherwise, and we are left to asking God how the choice was made. Perhaps He wants us to be able to do local tomography of states.
But if it turns out that this pairing is actually completely natural and even inevitable, for any real Hilbert space with the right symmetries, then that gives us a different perspective. That would mean there really are not two options that could have been, but only two self-sufficient ways of expressing the same theory. The complex version will be the neater and more convenient one, but God need not commit to it.
And yes, this would explain why actual Hamiltonians like the harmonic oscillator look so ugly in real QM: it is because we are expressing things in terms of an observable position operator, and that operator must comply with the emergent complex structure - meaning it cannot have nondegenerate real-QM eigenstates (I mean in the limiting, rigged-Hilbert-space sense in which the standard non-relativistic position operator does have eigenstates), but only degenerate and indistinguishable pairs of states.
stevendaryl said:
I don't understand exactly what is being debated. Imaginary numbers come into play from the beginning in quantum mechanics when one writes:
##H |\psi\rangle = i \hbar \frac{d}{dt} |\psi\rangle##
You can certainly perform tricks to try to eliminate the ##i##, but what's the motivation for that?
Again, the key question of this thread is: "Why complex numbers are necessary for QM?" Everybody agrees that they are very convenient, but are they necessary? While your argument looks reasonable, it is not quite waterproof. To see that, let us consider, following Schrödinger, the case of the Klein-Gordon equation in electromagnetic field. While your formula is still valid for that case, one can do without complex numbers, as any solution of this equation for the wave function can be made real by a gauge transformation (the 4-potential of the electromagnetic field will also change as a result, but the electromagnetic field will not, so we will get a physically equivalent solution). Thus, if you choose a certain gauge (the unitary gauge, where the wave function is real), you don't need complex wave functions.
It is also possible (but more difficult) to show that one real function is also sufficient for the Dirac equation in the electromagnetic field or in the Yang-Mills field. Again, let me emphasize that this is not about replacing complex numbers with pairs of real numbers.
As for the motivation... As this thread shows, many people would like to know the answer to the question: "Why complex numbers are necessary for QM?" The above shows that, to answer this question, one needs more elaborate arguments than yours.
There may be some additional motivation. For example, if we consider Klein-Gordon-Maxwell electrodynamics (scalar electrodynamics), we can use the gauge transformation to make the matter wave function real (this will not change the physics) and then algebraically eliminate the matter field altogether. The resulting modified Maxwell equations will describe independent evolution of the electromagnetic field. This is unexpected and looks pretty neat.
As it was brought up earlier, complex numbers in QM seem to have a very different role in QM than they have for example in electrical engineering theory (e.g. phasors) where their usage is completely artificial. In contrast, the role they play in QM seems to be fundamental - at least fundamental to the theory if not to Nature herself.
Over the years, my understanding on this matter is from reading multiple sources, which all seem to argue that complex numbers arise in QM due to, or more accurately in order to, model non-commutativity. A good example is the fundamental role they play in defining the Pauli matrices and so define the spinors in Dirac theory; in fact, the Pauli matrices are literally not much more than generators of the Lie algebra of SO(3) multiplied by a factor of ##i##.
Auto-Didact said:
complex numbers arise in QM due, or more accurately in order to model non-commutativity. A good example is the fundamental role they play in defining the Pauli matrices
But this cannot be a fundamental reason since general real matrices are also noncommutative.
Not just non-commutativity in general but the specific case giving rise to Heisenberg's uncertainty principle.
Personally, I'd argue that the existence of spin is what requires complex numbers.
These statements seem plausible, but they are not correct. I quoted the relevant articles several times.
Schrödinger (Nature, v.169, 538 (1952)) showed that
Heisenberg's uncertainty principle does not require complex numbers, as the Klein-Gordon equation in electromagnetic field satisfies the principle, but its wave function can be made real by a gauge transformation.
I (Journ. Math. Phys., 52, 082303 (2011),
http://akhmeteli.org/wp-content/uploads/2011/08/JMAPAQ528082303_1.pdf) showed that
the existence of spin does not require complex numbers, as, for example, the Dirac equation in electromagnetic field, which certainly describes spin, is generally equivalent to an equation for just one real function.​
Regardless if it can be rewritten in real form in a highly ad hoc manner, the very derivation of the Dirac equation certainly requires complex numbers, wouldn't you agree?
If we accept the necessity of complex numbers for the derivation of the Dirac equation, then the complex numbers mostly seem to arise to ensure the Lorentzian structure of spacetime directly reflected in the wave operator.
Admittedly, this feels like a weak argument, similar to the point that Woit is making here: https://www.math.columbia.edu/~woit/wordpress/?p=7773
First, we discuss if complex numbers are required, rather than just convenient, so it does not matter if the Dirac equation "can be rewritten in real form in a highly ad hoc manner",
it is important if it can be rewritten in real form in principle.​
To agree or to disagree that "the very derivation of the Dirac equation certainly requires complex numbers", I would need to look at the original derivation of the Dirac equation, as I forgot the derivation long ago:-). However, I don't understand how this could be relevant: if the Dirac equation in electromagnetic field is equivalent to an equation for just one real function, that means that complex numbers are not required for the Dirac equation.
Another thing about the derivation. To derive his equation, Dirac required that the equation be of the first order. However, Feynman and Gell-Mann proved later (Phys. Rev. 109, 193 (1958)) that the Dirac equation can be written as a second-order equation, I showed that it is generally equivalent to a fourth-order equation, therefore, Dirac's derivation was based on a wrong assumption (of course, that does not change the value of Dirac's accomplishment). So why is the original derivation important for this thread?
Again, we are not trying to decide in this thread if complex numbers are convenient for the Dirac equation (they are convenient for classic physics as well), we are trying to decide if they are necessary. My take is they are not.​
I am explicitly speaking about necessity, not convenience, as I already clarified in the beginning of post #156.
The original derivation of Dirac is important because it explicitly shows the principles he is adhering to, namely respecting the Lorentzian structure of the wave operator; this brings with it loads of mathematical bagage which is either fundamental to Nature or not.
The point I am making about ad hoc rewriting is precisely that the equation can be rewritten as second order or fourth order and so removing its complex nature. This procedure screams to me to be the same kind of mathematical trick such as the Wick rotation, i.e. of the variety often useful for tractability reasons, but certainly not universally valid.
Quantum mechanics = quantum logic.
Quantum logic = orthomodular lattice.
Orthomodular lattices can be realized as sets of subspaces in a Hilbert space with real, complex, or quaternionic scalars. This is Piron's theorem. So, there are 3 legitimate versions of quantum mechanics with good logical structures. For example, you can possibly build an octonionic Hilbert space, but this will not be a good quantum mechanics due to violation of some axioms of logic.
There were some attempts to develop real or quaternionic versions of quantum mechanics but, as far as I know, they didn't bring any new physics.
Eugene.
I am not saying the original derivation is not important, I am saying it is not relevant to the question: are complex numbers necessary for the Dirac equation? The answer cannot depend on Dirac's beliefs and principles: complex numbers are either necessary for the Dirac equation or not.
As for "Lorentzian structure" and "Wick rotation", let me ask you: do you think complex numbers are necessary for special relativity?
I don't understand this. Rewriting the Dirac equation as a fourth order equation plus gauge transformation allows using just one real function instead of four complex functions. However dirty this trick may be, it proves that complex numbers are not necessary for the Dirac equation.
The answer to the former is very much an answer to the latter: the hyperbolic structure of Minkowski space has mathematical and experimental consequences, e.g. the unobservable nature of Lorentz contraction; this is a consequence of the hidden conformal structure in SR. If complex numbers aren't fundamental to SR, it means that this is purely a coincidence.
I know that the consensus of the field is that complex numbers aren't necessary for SR; I accept this, but believe this consensus might be premature and that the complex structure brings far more with it that cannot really be appreciated from a purely pragmatic viewpoint; I am not arguing for convenience here, but for deep mathematical consequences.
My point is the following: unless we specifically push the theory not merely to its limits but beyond, i.e. attempt fundamental analysis of the concepts using the deepest rigorous theories of pure mathematics that we have, we cannot know whether something is necessary or merely convenient; the major programmes of theoretical physics that do this clearly show that the complex structure is not merely convenience but a necessity.
As for QT, the case for the necessity of complex numbers seems to be much clearer than the case for complex numbers in SR. Orthodox QM is patently laden with complex numbers, complex vector spaces and holomorphic functions. There are tonnes of equations in QFT with explicit complex notions such as the gamma function.
The positive frequency condition of QFT - i.e. positive energy - can be deeply demonstrated to be dependent on the underlying complex structure. Moreover, the scale invariance of renormalization group theory is also deeply dependent on the notion of complex numbers.
Does this fourth order characterization with the gauge transformation correctly carry over to QFT in curved spacetime?
Well, let us assume for a moment that you are right, and special relativity does require complex numbers. In that case it is not the uncertainty principle or spin that require complex numbers, as there is no uncertainty principle or spin in special relativity, so your statements in post 158 are still incorrect.
The standard Dirac equation is also "patently laden with complex numbers", but it turns out it does not require them. Again, I cannot be sure that QFT does not require complex numbers, but then one needs more sophisticated arguments to prove the necessity.
I don't know, but this is irrelevant to whether it is the uncertainty principle and spin that require complex numbers.
Please give a reference for this demonstration.
You appear to be saying that these characteristics somehow require (or at least strongly imply) a complex structure underlying SR. Why?
That doesn't follow. The argument for complex numbers in SR is in principle completely separate from the argument for complex numbers in QM.
More importantly, I see that you are focussing a lot on #158; I would like to paraphrase Bohr by saying "Every sentence I utter must be understood not as an affirmation, but as a question."
This thread is about complex numbers in QM in general; I think therefore that the arguments I give in other posts in favor of the fundamental place of complex numbers in QT cannot be dismissed so lightly.
It is obvious to me that we have very opposing views of how we basically regard what a physical theory is; the difference between our views are what historically was called the applied mathematics view versus the pure mathematics view of physics.
The derivation of spin from first principles by Dirac is to me clearly a result of the mathematical existence of spinors, whether that is/was acknowledged or not by physicists at the time or even today. The existence of spin as a mathematical object can be demonstrated to be a consequence of the existence of spinors, with the gamma matrices operators which act on spinors. In this sense, gamma matrices are non-commuting elements of the Clifford algebra, giving spinors more degrees of freedom than scalar wavefunctions. This is what my post in #158 was alluding to.
In contrast, from what I understand from your point of view, it seems you would claim that spin is just a physical quantity following from any mathematical model capable of describing aspects of the physics, whether or not these descriptions can on the face of it immediately be shown (through trivial efforts/arguments) to be equivalent to some other purely mathematical model of spin we already have; indeed, such a pragmatic view is referred to as an applied mathematics view of physics.
PeterDonis said:
What are you talking about here? Why do you think Lorentz contraction is unobservable?
https://journals.aps.org/pr/abstract/10.1103/PhysRev.116.1041Lorentz contraction as an actual contraction of length is not directly observable; I thought this was more widely known?
Positive and negative frequency solutions can be naturally split on the Riemann sphere, a distinctly complex analytic notion.
See https://doi.org/10.1098/rspa.1982.0165
In principle, this also has a lot to do with creation and annihilation operators satisfying the rules of a Grassman algebra.
The underlying properties of SR in Minkowski space and curved spaces has key properties allowing advanced mathematical treatment with conformal manifolds and the theory of Riemann surfaces which expose more of physical theory; is this a coincidence?
That's not what the reference you gave (which is just Terrell's classic paper introducing what is now known as Penrose-Terrell rotation) says. It says something more limited: that if you confine yourself to observations made using light rays emitted by a moving object and arriving at your eye, or some equivalent detector corresponding to a single timelike worldline, then you will not observe the object to be contracted, but rotated. But this is by no means the only possible way to make measurements on an object that is moving relative to you; there are other methods that allow you to measure the object's length and show that length to be contracted.
That paper that you are citing says that the Lorentz contraction cannot be observed using one particular technique: forming an image of reflected light on a screen (photographic film, retina of the eye, ...) and interpreting the image as if all the incident light was reflected at the same time. Of course this assumption is only valid when the speed of the moving object is negligible compared with the speed of light; the point of this paper is that (if some other reasonable conditions also apply) the bogus assumption leads to a misinterpretation of the image that precisely hides length contraction in the image.
However “cannot be observed using one particular technique”is a very different and much weaker statement than “not directly observable”, even when the technique in question is naked eye observation.
In principle something like the pole-barn experiment would allow direct observation of length contraction; the impediment is the practical difficulties of manipulating a pole moving at relativistic velocities.
Fully agreed.
Any examples of direct observations of the current experimental state of the art? The only observational "example" I can think of from the top of my head is the perspective from arriving muons which have an extended lifetime due to time dilation.
The appearance of magnetic fields around a current-carrying wire can be explained as a length-contraction effect; see, for example, the first section of http://www.physics.umd.edu/courses/Phys606/spring_2011/purcell_simplified.pdf
Then why were you telling me about "Lorentzian structure" and "Wick rotation" in the context of QM?
Sorry for taking your post seriously.
I read your post #158 and commented on it. As far as I remember, I did not read your earlier posts, so I could not have dismissed them, neither lightly nor heavily. I don't think I have to read the entire long thread to post anything.​
OK, I got it. I have a bad habit to read texts exactly as they are written. You have explained that your post #158 means something different from what is written there. I give up.
Lorentzian structure: because I was talking about QFT, seeing that the discussion was focusing on the Dirac equation. There is an argument to make that QM is always a limiting case of QFT; if one argues this way, whether or not they believe in the argument, then the argument about the complex nature of SR is extremely relevant.
Wick rotation: as I said, convenience techniques, such as e.g. the Wick rotation, which make the mathematics more tractable tend to give results of limited validity. By analogy, I was making the case that your algebraic technique and gauge transformation, resulting in a real fourth order version of the Dirac equation, may have similar limitations. This is why I asked if the resulting equation carries over correctly to QFT in curved spacetime.
You misunderstand my intent for clarification; we are speaking about what is fundamental in physical theory, i.e. not just contemporary physics but what should or will likely be continued to be regarded as fundamental in future physics yet to be discovered. As I remarked before this requires a certain view of physics.
In fact, the usual attitude of certainty learned during training is almost never warranted in such discussions, as opposed to discussions about non-fundamental (textbook level) physics, where the level of certainty is rather high because it can almost always trivially be empirically (through experiment) or mathematically justified (e.g. even by a smart undergraduate student).
In other words, discussing foundations necessarily brings with it more uncertainty than in the rest of physics, exactly as Bohr remarked. The only guide theoretical physics has ever known in this intrinsically uncertain endeavor is to rely on pure mathematics not yet appreciated to be relevant to physics; this is often called 'relying on mathematical beauty' and is a concept deeply misunderstood by many physicists today (e.g. Hossenfelder).
Relying on mathematical beauty is truly an art, which cannot be reduced to brainless application of simple techniques and equation churning; it requires development of correct esthetic senses from pure mathematics and therefore requires a finer touch. Importantly, using this methodology in fundamental physics to generate hypotheses often results in highly mathematically elaborate models which stretch across all of physics making them extremely specific and therefore extremely open to falsification.
This is in stark contrast to more specialized topics in physics, which are better served by the applied mathematics view in conjunction with experimental reasoning. I am a strong advocate that thinking about foundational issues in the more pure mathematics manner, and therefore doing fundamental physics in such a way, is the most productive theoretical methodology available and the only tried and true one with precedent of success; the results of all the biggest names in physics attest to this.
Demystifier said:
The ##\pi## of course is definable. But to define any conrete number, you must use some language (English, mathematical language, or whatever). A definition can be viewed as a sentence in the chosen language. The set of all possible sentences is countable, hence the set of all possible definitions is countable.
Still reading this wonderful thread but how is the set of all possible sentences countable? Based on what constraint? Countable words in some vocabulary of some language, countable number of languages, countable number of phonemes? Countable number of shapes the tongue can make? I don't see how a typographic theory is any more immune to the problem of Reals shown by Cantor (the infinite regression of... the diabolical diagonal... the monstrous recursive... meta...) than a typographical number theory.
Because it's built from a finite, discrete set (the alphabet of the language--or even some general alphabet like the Unicode character set that can represent any language), and the number of possible ways you can form sets from a finite, discrete number of elements is countable.
In other words, the concept of a "sentence", at least as I think @Demystifier was using it, ignores the actual continuous variability of the process that produces sentences (people writing them down in longhand or pronouncing them vocally) and focuses on the discrete set of items that carry the intended meaning.
Thanks @PeterDonis I jumped in too enthusiastically perhaps. Had to rapid google. Just got to the punchline of Escher, Godel, Bach. My take is that is is a transcendental punchline. There are no closed alphabets I don’t think (modern coding languages are a perfect example of hybrid you mention) IOW at least for the moment I having deep skepticism that there are countably many formulas - languages are a real as the Reals... just running in their shadow.
