Are Eigenvectors of Unitary Transformations Orthogonal?
13 replies · 7K views
Ed Quanta
Show that the eigenvectors of a unitary transformation belonging to distinct eigenvalues are orthogonal.
I know that U+=U^-1 (U dagger = U inverse)
I tried using a similar method to the proof which shows that the eigenvectors of hermitian transformations belonging to distinct eigenvalues are orthogonal.
So assume our eigenvectors are a and b. I assumed U(a)=xa and U(b)=yb
x<a|b>=<Ua|b>=<a|U^-1b>= ?
Help anyone. I know this probably isn't too rough.
They are the reciprocals. U^(-1)a=1/x
So
x<a|b>=<Ua|b>=<a|U^-1b>=<a|(1/y)b>=1/y<a|b>
So (x - 1/y)<a|b>=0
Now how do I know x - 1/y cannot equal 0?
Be a little careful. You are probably dealing with a complex inner product. If it's real then this is fine. As U is orthogonal, what do you know about the absolute value of x and y?
The absolute values of x and y must be real.
Ok, so I get that the norm of the eigenvalues must equal 1.
<a|b>=<Ua|Ub>=x*y<a|b>
x*y=1?
As I've said, be a little careful. You are correct in the case if U is real. But if U is complex, the condition is [tex]x^* y=1[/tex]. So if x=y, then [tex]x^* x=1[/tex] and the eigenvalues are unit complex numbers. How does this help you with the original problem?
So x*y does not equal 1 unless y=x.
I'm still confused man. I want to show that x*y<a,b>-<a,b>=0
I want to show then that x*y does not equal 1. Where do the norms fit in?
Ed Quanta said:
So
So (x - 1/y)<a|b>=0
You've gotten this far and have assumed x and y are DIFFERENT eigenvalues of U. If U is real this is super easy, since x and y are both in the set {+1,-1} and DIFFERENT. What about U complex? Then you have to mend your ways and remember [tex]<c x,y>=c^*<x,y>[/tex].
