Are Maxwell relations valid for irreversible processes?
7 replies · 4K views
John Perez
Hi, I have a question
If I am not mistaken, the Maxwell relations of theromdynamics
-----for example: ∂G/∂T) = -S ; ∂G/∂P) = V -----
are valid only for reversible processes.
On the other hand,
dG = ∂G/∂T)*dT + ∂G/∂P)*dP + ∑ μi dni
is valid for any process.
This means that
dG = -SdT + VdP + ∑ μi dni
should only be applicable for reversible processes, and not necessarily for irreversible ones, Right??
The Maxwell relations are just the application of Poincare's lemma to the thermodynamic potentials.
http://johncarlosbaez.wordpress.com/2012/01/19/classical-mechanics-versus-thermodynamics-part-1/
The thermodynamic potentials are applicable to reversible and irreversible processes
http://www.quora.com/Thermodynamics...mics-only-applicable-for-reversible-processes
Thus the Maxwell relations apply to reversible and irreversible processes.
Here's a great way to derive/remember the massive amount of information this branch of the subject contains by drawing pictures:
http://web.mit.edu/course/8/8.593/spring10/bk/on_MRS_Thermodynamic_Mnemonic.pdf
Thanks for answering!
Oh, I didnt know about that Poincare lemma. And the definition of the potentials does apply to any processes.
But I couldn't find anywhere on the first link a mention of the relations bieng valid in one or the other scenario.
The answer in the second link seems to be wrong, there's even a comment about it.
dG = -SdT + VdP apllies to reversible processes, and while dG is the same no matter the "path", -SdT and VdP certainly depend on the path, so the equality should not hold for a irreversible process. In such case it should read dG < -SdT + VdP
If I am not mistaken, the Maxwell relations of theromdynamics...are valid only for reversible processes.
No they've valid for any quasi-static process.
John Perez said:
On the other hand,
This is also only valid for quasi-static processes.
The Maxwell relations are literally just a consequence of the commutativity of mixed partial derivatives.
Ok, thanks.
So all those things are only valid for quasi-static processes, and not "violent" ones. So, for example,
is not valid for "violent" irreversible processes. Or I understand wrong?
After all, like you say it is just a consequence of mixed partial derivatives but the derivative they ultimately come from is U = TdS - PdV, which is a combination of the first and second Principles and (I think) only is valid for quasi-static processes (since reversible seems to be the wrong term here).
No you understood it correctly. In the case of "violent" irreversible processes, i.e. non-quasi-static processes, we only have inequalities.
The second link isn't wrong, the first comment seems to be talking about non-equilibrium thermodynamics, and the second comment makes the original point that dU = TdS - PdV is still valid for irreversible processes, I guess you're conflating this with quasi-static processes or something...
You seem to be saying something equivalent to: because ydx and xdy separately depend on the path, it implies that (ydx + xdy) is also dependent on the path, but you forget that putting them together implies ydx + xdy = d(xy)... I guess classical vector analysis is messing your intuition up so I recommend this article http://em.groups.et.byu.net/pdfs/publications/formsj.pdf
Once you have the differential form a thermodynamic potential established (i.e. dU or one of it's Legendre transforms) you take a second exterior derivative and get the Maxwell relations. This is Poincare's lemma (in direct form, i.e. d^2 w = 0) and is equivalent to commutativity of second partial derivatives (Clairaut's theorem).
Thanks, I think I got it, though I received kind of conflicting answers.
Im leaning for the non-quasi-static = inequalities.
