Area enclosed between y^2=4-x and y=x-2
  • Thread starter Thread starter Bill_Nye_Fan
    Area
The discussion revolves around finding the area enclosed between the curves defined by the equations y² = 4 - x and y = x - 2. Participants are exploring the use of definite integrals and the area between two curves, with some confusion regarding the calculations and interpretations involved.
  • Participants discuss various methods for calculating the area, including the suggestion to calculate the area under the parabola and subtract the area of a triangle. There are questions about the correctness of the original poster's method and the interpretation of definite integrals, particularly regarding the positivity of areas and the use of different variables of integration.
There is an ongoing exploration of different approaches to the problem, with some participants offering alternative methods and questioning assumptions. While some guidance has been provided regarding the use of horizontal versus vertical strips for integration, there is no explicit consensus on the best approach yet.
Some participants express concern that the discussion may be beyond their current coursework, as they have only recently begun studying definite integrals and areas between curves. There is a mention of the potential complexity introduced by conics, which may not yet be covered in their studies.
Bill_Nye_Fan
Please find attached
[/B]
Definite integrals and area between two curves
[/B]
Also find attached.
The answer in the back of the book says that part c should be 10/3, but that would mean that (8sqrt (2))/3 would need to cancel out in both area 2.1 and area 2.2, whichdoesn't work because areas are always positive.
Why didn't you calculate the area under the parabola and only subtract the triangle? It seems you used more areas than necessary. But I'm not good at reading on the side.
Ah yes that is a much better idea thank you. But still, my method should still be getting the same answer but it's not. Could you please explain to me where I'm going wrong?
[/B]
[/B]
Also find attached.
View attachment 101868 View attachment 101869
Areas may always be positive, but definite integrals are not required to be positive. To calculate an area using a definite integral sometimes requires some interpretation of what the definite integral means in that case.
http://tutorial.math.lamar.edu/Classes/CalcI/AreaBetweenCurves.aspx
Going off fresh_42's comment, you can also evaluate the definite integral to calculate the area under a curve using dy instead of dx as the variable of integration.
To be honest: I didn't like the root expressions. First thing I did was to exchange x and y.
In other words, using horizontal strips instead of vertical strips.
Thank you all for your help, but I feel like some of this stuff is a little beyond my current course. We've only just started looking at definite integrals, and have spent even less time with areas between two curves. I highly doubt we're expected to be using horizontal strips instead of vertical ones when we haven't even learned about conics or anything really.
But again thank you all for your help still
You don't need to know anything about conics to switch the variable of integration. Often times, switching is done as a matter of convenience to simplify the integral.
I think my main problem is that I still don't know how to calculate the area between two curves properly.
Say I was just given y=x-2 and y=-sqrt(4-x) and had to find the area enclosed between them between x=0 and x=2
Isn't the correct way of doing this to just set up an integral over the given domain and subtract the function on the bottom from the function in top? So integral(2, 0, (x-2-(-sqrt(4-x)))dx
... or simply exchange x and y and integrate as you are used to, which is the same.
Okay thank you I'll just do it that way
  • · Replies 20 ·
  • · Replies 18 ·
