Area of a bounded region using integration
5 replies · 2K views
Steven_Scott
Member advised that the homework template must be used, not deleted
In Calculus II, we're currently learning how to find the area of a bounded region using integration. My professor wants us to solve a problem where we're given a graph of two arbitrary functions, f(x) and g(x) and their intersection points, labeled (a,b) and (c,d) with nothing else given.
I know how to find set up the integration if I'm given the functions explicitly but these aren't specified. Everything I find in textbooks and on-line only gives examples with specified functions, not arbitrary ones labeled f(x) and g(x).
Can someone please show me how I'd go about setting up a problem like this?
Steven_Scott said:
In Calculus II, we're currently learning how to find the area of a bounded region using integration. My professor wants us to solve a problem where we're given a graph of two arbitrary functions, f(x) and g(x) and their intersection points, labeled (a,b) and (b,c) with nothing else given.
If ##f(x) = x^2## and ##g(x) = x ## what would you do and why?
You then need to generalise this approach.
Steven_Scott said:
... where we're given a graph of two arbitrary functions, f(x) and g(x) and their intersection points, labeled (a,b) and (b,c) ...
Is there a typo here? Shouldn't the intersection points be (a,b) and (c,d)?
You're right.
Thank you.
I don't understand how you can possibly be given a formulation that is only for particular functions and not general. E.g for the area delimited by the x-axis, a function f(x) and x = a and x = b for example.
The answer to this question will not be the most neat compressed formula, but one of those more strung-out 'peicewise' mones involving x≥, x≤ etc. that you have surely met and done exercises on, e.g. when they were explaining what what is meant by a function.
##f(x)dx## is an elemental area "under the curve" consisting of a rectangle of height ##f(x)## and width ##dx## located at some ##x##.
##g(x)dx## is an elemental area"under the curve" consisting of a rectangle of height ##g(x)## and width ##dx## located at the same ##x##.
##dA=f(x)dx-g(x)dx## is the "area under the curve" difference between ##f(x)dx## and ##g(x)dx## also at the same ##x##.
What is the total "area under the curve" difference in the interval ##x_1 \le x \le x_2##?
Hint Add all the ##dA##'s together and write an expression for the sum in terms of the given symbols.
