ASIC Logic Gates NAND Homework: Solving 2-Input NAND Gate Circuit
  • Thread starter Thread starter bradzyc
    Logic Logic gates
The discussion revolves around designing a logic circuit using 2-input NAND gates for a water tank system that requires a pump to operate when any two of three processes (A, B, C) are active. Participants explore various approaches to create the circuit, including converting truth tables to Boolean expressions and discussing the use of different types of gates.
  • Homework-related
  • One participant describes the problem of needing a pump signal when any two of three processes are active and seeks help with designing a logic circuit using only 2-input NAND gates.
  • Another participant suggests designing the circuit using AND and OR gates first, then converting to NAND equivalents.
  • Multiple participants discuss converting the truth table into Boolean algebra, with one participant stating their expression as P = B.C + A.C + A.B and questioning its simplicity under De Morgan's laws.
  • One participant mentions they were initially unaware that 3-input NAND gates could be used and later shares their solution using 3 NAND gates connected to a final NAND gate.
  • Another participant expresses interest in completing the task using only 2-input NAND gates and shares their experience of needing 7 gates, later correcting it to 8 gates after finding an error.
  • A participant describes their thought process in designing the circuit, detailing how they used Excel to model the logic and highlighting the importance of understanding the circuit behavior.
Participants generally agree on the need to design a circuit that meets the specified requirements, but there are multiple competing approaches and no consensus on the most efficient method or the final design using only 2-input NAND gates.
Some participants reference the use of Boolean algebra and De Morgan's laws, but there is no resolution on the simplest form of the expressions. The discussion also includes varying levels of familiarity with circuit design tools and methodologies.
This discussion may be useful for engineering students or individuals interested in digital logic design, particularly those working with NAND gates and circuit simplification techniques.
bradzyc
Hi everyone,
Very new to this forum so please bear with me!
I have an assignment as part of my engineering course that I seem to be struggling with so I'm wondering if I can grab some help.
Basically I have a water tank that feeds three separate processed (A, B, C). When any two of the processes are in operation at the same time, a signal is required to start a pump to maintain the head of water in the tank. I have to design a logic circuit using only NAND gates to meet the requirements. Then devise a logic circuit using only NOR and NOT gates.
Just a quick note also, the NAND gates can only be 2 Input NAND gates and not the 3 Input ones.
Truth Table for all possible states and the required output
A B C P
0 0 0 0
0 0 1 0
0 1 0 0
1 0 0 0
0 1 1 1
1 0 1 1
1 1 0 1
1 1 1 1
I was not present during this lesson due to work requirements so I'm wondering, how would I go about doing this because at the moment, I'm just using trial and error and having to constantly redraw the circuit out and test different activated processed (i.e. A=1, B=0, C=1) until I seem to get the right answer. However, I have not got this yet.If anyone could point me in the right direction or help then it would be much appreciated.
Cheers People!
B
Can you design it using AND and OR gates and then replace them with NAND gate equivalents?
You can convert your truth table into Boolean algebra by looking at the lines where P is true:
P = B.C + A.C + ... (you can complete this line)
Next, can you simplify this line?
Hi.
Yes I already have P=B.C + A.C + A.B
Isn't this the simplest it can be whilst conforming to De Morgan's laws?
Hi,
I have already designed it with AND and OR gates however I can't understand how to convert this to NAND
Sorry guys just been told that we can use a 3 input NAND and solved it.
C and B connected to NAND 1
C and A connected to NAND 2
B and A connected to NAND 3
Then all 3 NAND's connecting to a final NAND
Many thanks for all your help!
B
So, just for fun, why not complete it with just 2ip NANDs !
Takes me 7 NANDs (and maybe 2 minutes), but I don't use any DeMorgan or Boolean algebra, so there may well be shorter ways.
Why not! Could you show me your solution? I'm really not getting it!
Ok. Of course, when I typed it up, I found an error and now it is 8 gates!
I've done a drawing and also an Excel spreadsheet which I think may be helpful.
Drawing is attached. I can't attach the Excel (AFAIK), but I've attached a screenshot.
My thinking was, the first level of nands will be low if both inputs are true, so I need any of the outputs to be low.
Second layer, if all inputs are high, output will be low, so I need either of them to output high, showing an input was low.
Now is where I made my error and had to correct it by inverting these outputs.
If I invert them, then I need either inverted output to be low.
The final nand is high unless both its inputs are high, so it is high if either input is low.
I know that is probably confusing! It's hard to explain my thinking process.
1 - I just believed it must be possible
2 - 3 inputs mean 3 pairs so 3 nands. That gives me signals showing a pair of 1's
3 - I've got to get it down to 2, so try combining with just 2 nands and see what I get
4 - Now I've got a 1 if any of the pairs was good.
5 - Nand is no use to spot a single 1, so invert them to spot a single 0
6 - Final nand is high if either input is 0.
Final bit of info. I tried to do an LTspice circuit of this, but could not manage that(!), so I went to my old friend Excel. The screen I show is the result. AB&C are the inputs, E,F&G are the first level Nands and so on.
So the formula in column E is =Not(And(Ax,Bx)) using Not(And) because there is no Nand.
Column I is =Not(And(Ex,Fx))
Column L is = Not(And(Ix,Ix)) just to show I'm not cheating! I could have simply put = Not(Ix)
And final column O is =Not(And(Lx,Mx))
I have highlighted the rows which should give a True (1) output.
No doubt the methods taught in your course are better and I do use some of them sometimes. But I really like to see what is going on, if I can. The comment someone made about using LTspice is probably very good advice. Make up circuits in whatever modelling system you can (even Excel!) and play around.
28K
