Aspect's Experiment Was Flawed
  • Level: Graduate
  • Thread starter Thread starter Maestro
    Experiment
125 replies · 28K views
Can a signal that travels faster than light in principle explain instantaneous action at a distance.It takes little or no energy to change the polarization of a photon so a signal
would not need much energy and would be hard to detect.When a photon interacts with a detector or polarizer it must transfer some momentum to the detector or polarizer and cause them to accelerate slightly.Electric charges would give off electromagnetic radiation if they were accelerated but is there equivalent gravitational radiation
when a mass such as a detector or polarizer is accelerated?If so, this could be a communicating signal between photons in Aspect's experiment.I know nobody can prove something can travel faster than light, but in principle wouild that be helpful to restoring causality?
Sure, but an FTL signal is nonlocal, that is it violates relativity. Quantum mechanics explains the experimental results without violating relativity, but you have to give up the notion that the particle "really" had a polarization before they were measured. Quantum mechanics says not; it says they were in a superposition of polarization states, which was neither one nor the other nor both, but rather something different made of the two possible states and already correlated at the time the particle pair was created.
The standard formalism of QM does not give an explanation for quantum entanglement,the interpretations do,via the ontologies proposed.Unfortunately as of now there is no satisfactory answer,[quantum entanglement]is,still,quite a mistery.We have the following options:
1.The observed statistical correlations are 'nonclassical' not 'nonlocal',the wavefunction is only a mathematical tool (the point of view of Bohr and Heisenberg),'c' (the speed of light which may vary,slowly,in time) is the maximum,so that there are no instant connections.This is the main view today among copenhagenists,trying to retain full coherence with SR (it's about the requirement of no preferred frame of reference-NOT about the alleged superluminal transmissions involved,as I've argued before this is a red herring,at least in the case of hidden variables interpretation).The drawback is that it offers no real explanation for the observed correlations (see for example Bohr's answer to EPR paradox,not satisfactory).Everett's many worlds interpretation also qualify here for it does not require nonlocality,c being also a limit (here the assumption of counterfactual definiteness is rejected-this amounts to retaining locality and reality but with the expense of basically rejecting free will).
2.There exist nonlocality,the wavefunction is real,stretched in space,so that the entangled particles still form a single system (superposition of states) even when far apart,allowing instant connections,the 'collapse' of the wavefunction is responsible for the complementary values of spin measured.Thus nature is 'wired' by allowing instant connections but we cannot use this link to send information superluminally.This view is held by a minority of copenhagenists.
3.Superluminal connections exist,nature is somehow 'wired',possible outside our spacetime,though we cannot use those connection to send information superluminally (see Bohm's interpretation of quantum potential,though,strictly speaking,it is rather a philosophical attempt,not part of the interpretation itself).There exist non local hidden variables (it is widely accepted that Aspect's experiment rule out only the premise of locality) or advanced and retarded waves (as implied by the transactional interpretation of QM).In Bohm's interpretation the quantum potential (an effect of a subquantum unified domain) is responsible for the connection at distance observed,causality is retained.
QM My Be Flawed in Particle Wave Theory
Much as in the past Electron flow was thought to flow negative to positive as well as even how lightning begins. Current QM seems to not assume possible reverse flows.
The concept of tracers preceding the actual return bolt of lightning as well as that electrons now have been proven to flow NOT from negative to positive but in fact from positive to negative make it probable at least that maybe waves ALWAYS are present in reverse flow when involved in the standard double-slit experiment behavior of particles/waves.
This would also show how Aspect's experiment had a shortcoming, but which nonetheless does not conflict with Bell's theorem.
Here is one interesting solution to particle/wave separation.
http://www.yankee.us.com/TEW/TEW96paper.html
Unfortunately, Lewis Little's "Theory of Elementary Waves", being a local "hidden variable" theory, is unable to explain the double-delayed choice experiments. (That's just one problem with it.)
What nonsense is this? What does this have anything to do with QM? If electrons flow from positive to negative potential, it is CLASSICAL E&M that is in trouble! But then again, you would have known this had you had any formal lessons in E&M.
Why are people still obsessed with the Aspect experiment done in the early 70's? Have these people been asleep since then and completely overlook a whole zoo of experiments since then that have improved upon that experiment by orders of magnitude, and with different scenarios?
There's nothing worse than a quack, but a quack with out-of-date information.
Zz.
Probably the same reason why some people are obsessed with the Michelson-Morley experiment (1880s), or the Hafele-Keating experiment (1970s). :frown:
So, if we apply Zapper's suggested criterion for distinguishing pottery magic (thank you Chronos) from maverick capers (thank you Garth) - i.e. publication in (physics) peer-reviewed journal - would Little's idea stay here, or should it be moved to TD? The link which ZOverLord gave us (and Welcome to Physics Forums ZOverLord!) mentions 'Accepted for publication in Physics Essays' - was it published? Is Physics Essays a peer-reviewed journal?
Any further discussion of Little's work should probably be moved to TD.
I think it was published in Physics Essays. A glance at the table of contents of past issues would suggest that their peer review policy is quite liberal. :bugeye:
"Articles submitted for publication will be reviewed by scientific peers. Realizing the interchangeable roles of authors and reviewers, the positive aspect of the reviewing process will be retained by providing the authors with the reviewers' comments. Authors should judge which part of the reviewers' suggestions are appropriate to improve the quality of his or her paper. The editor, who is responsible for the Journal, will allow a large degree of freedom to the authors in this process."​
(From www.physicsessays.com.)
Take note that Physics Essays has a history of publishing "fringe" physics. I do not know of anyone who is a referee for this journal - or maybe they are too embarrass to admit it. Either way, this doesn't bode very well for that journal.
It is also a journal that isn't easy to find. Most institutions do not subscribe to it, either electronically or hardcopy. This in itself should tell you how "important" it is.
Zz.
ZapperZ said:
Hey, I like your website. It looks quite useful in the sense that you have the historical collection of the EPR stuff. I am definitely putting your site as one of the links in the Yahoo e-Group that I run, so thanks for the effort.
Zz.
Zz,let us know more about your e-group--what's its name--how to join it
Yes, this is how I understand what Gell-Mann calls "the modern interpretation of quantum mechanics" is supposed to work.
Also, in a short overview article Zurek wrote called "Decoherence and the Transition from the Quantum to the Classical", he says:
And the experiments that show that such nonseparable quantum correlations violate Bell’s inequalities (Bell 1964) are demonstrating the following key point: The states of the two spins in a system described by | Φc > are not just unknown, but rather they cannot exist before the “real” measurement (Aspect et al. 1981, 1982). We conclude that when a detector is quantum, a superposition of records exists and is a record of a superposition of outcomes—a very nonclassical state of affairs.
http://arxiv.org/abs/quant-ph/0306072
A superposition of records is an interesting conclusion! I think understanding what superpositions really mean is important in understanding EPR and the like. :smile:
This is the VERY reason why one cannot just learn physics, and especially QM, in bits and pieces. You cannot understand why an EPR-type experiment differs from simple classical conservation of angular momentum if you do not understand quantum superposition/Schrödinger Cat-type experiments. There is an interconnectedness of QM that is essential as a single, coherent picture. It has always been the single most source of frustration (at least on my part) when someone picks on one aspect of QM but did not bother understanding all the connected ideas surrounding it.
You can't understand physics this way, and you certainly as hell cannot understand quantum mechanics this way.
Zz.
I haven't read through most of this thread, but it reminded me of the experiments done earlier this year, by Shahriar Afshar (sp?), on a slit apparatus, where he detected a photon without collapsing its wavefunction . Another experimenter later came up with a rebuttal, but I think his experiment was intrinsically different in the way he identified the path of the photon.
Haven't really followed up on this though, so does anyone know what the final word on this is ?
The damn thing still hasn't appeared in any peer-reviewed journal yet, in spite of all the advanced hype. :)
Zz.
To follow with the "non-classical" points mentioned by ZapperZ and others above...
Bell's Theorem has portions which relate to both locality and reality. Specifically, the likelihood of a correlation X in a "classical" world must be:
0 <= X <= 1
Every time you try to restore classical determinism - in any form - you still run into this point because the empirical evidence does not support the above constraint. In other words, it is not just that the angle between the polarizers determines the results of the experiment. It is "as if" the original photon polarity was exactly matched (or anti-matched) to one or the other of the polarizers, and no other polarizer angle setting.
You don't get these results from the "Theory of Elementary Waves" as I read it. He doesn't really discuss this point while trying to sell his interpretation. Moreover, it no more predicts the observed polarity than the man in the moon in specific cases. So where is his claimed local determinism anyway? (As an aside, Lewis Little also claims that General Relativity does not stem from the curvature of space-time.) Ultimately, this paper goes nowhere when it acknowledges Bell as correct but denies Aspect. This is just another paper doing that same job, and all fall victim to the same reality:
a) Aspect is repeatable;
b) The results are clearly in line with the predictions of QM;
c) The results are outside the predictions of classical locality;
d) The greater the precision of the experiment, the greater the disagreement between classical and quantum worlds.
There are no "action on a distance terms" in the Standard Model
It would simply render the path integral mechanism useless by inter-
connecting all points in space-time.
We have to do with an QM interpretation issue here and there is
a certain element of denial of the QM laws which then leads to
these "action on distance" conclusions:
What QM says:
Position and Momentum are not defined arbitrary accurate simultaneously.
The spread in one is reversely proportional to the spread in the other.
What people often think: (the denial in my opinion)
Yes, but somehow the both must be still there accurately. And we've
got the freedom to decide which one we measure accurately. Only if
we measure one accurately then we can not measure the other one
accurately.
So, In this interpretation it becomes a measurement issue. And then
the problem arrises that the measurements do not only exclude each
other locally, but also at any distance.
Heisenberg's position/momentum and time/energy relations are best
handled as a property of the Fourier Transform. There are many
ordinary situations which are governed by the same rule: The spectrum
analyser on your audio set can not determine the audio spectrum in
an infinitesimal small amount of time. There's nothing mysterious here.
If momentum is defined by a Fourier component then Heisenberg's
law follows automatically. If taken literally then there's no way that
"somehow, both must be still there accurately"
If two particles obtain the same spread (during entanglement) in
their spin components, then the outcome of the experiments will
show the correlation we see in today's experiments without the
need for any action on a distance.
Each individual particle must be presumed to have a certain
spread in one physical quantity, and an opposed spread in the
other associated quantity.
The spread in, for instance, position is lost if a particle hits the
wall at an exact x,y position. This doesn't mean that the spread
was not there. It's wrong to say that we have chosen to
"measure the position exact" It could have hit the wall at another
nearby position.
The x,y measurement has an error from the average position and
only repeated measurements will reveal the size of the error and
the spread. There is no way that the experiment can reduce the
spread the particle had during flight. (at the expense of the
spread of the momentum).
Still, it's this interpretation, that we have chosen to measure the
position exact, that leads to the idea that "both quantities must
somehow still be there accurately" and "we can choose which of the
two we measure exact at the expense of the other"
Regards, Hans.
Zz.
What ! :eek: I looked around and couldn't find it anywhere, but thought I wasn't trying hard enough.
You mean this?
http://www.irims.org/quant-ph/030503/
Hmmm... Afshar's experiment is a bit like the standard textbook two-slit experiment but with wires in the dark bands, then remove the screen and adding interferometer arms to keep the particle's superposition until a much later detection.
The "detection" of the interference pattern by not interacting with the wires involves... er... no interaction, so it doesn't sounds like a true violation of complementarity to me.
danitaber said:
I would like to take a moment to remind everyone of the basic fact that Quantum Mechanics does not explain the world we live in, it just accurately describes it. It is much like an owner's manual or (and this is overused, but I'll use it again) a recipe. The point is, it works. The previous posts do a better job of explaining why and how, so I'll leave that to them.
Maybe I'm wrong but you can see QM is absolutely epistemological just looking at the math. One could think that once the answer you have from asking (measuring) one system (at the quantum level) means nothing. As the answer comes as an eigenvalue of this operator related to the measuring, you just have the same asking in a new form, because an eigenvalue may be pictured as a representation of the operator in the correspondent eigenspace. So you just have the same asking in a new form. But the whole system collapses to the corresponding eigenspace so it's not just a new form of the asking. Otherwise you coldn't have the eigenvalue as the desired answer, once the eigenvalue would not be a representation of the operator. You end this line by thinking that to measure is to shape the system in some eigenspace of the operator that corresponds to the variable you want. Trying to figure out the quantum mechanics is impossible if you take a realistic classical view. To measure is just like to ask somebody. The answer were not previously in his head, but comes as he starts to think about. Now the one has a personal position about the theme of the asking. Nocommuting operators is just like to ask the answer of a paradox. Simply the answers of the paradox are contraditory, what means are based on alternative grounds. It's like to have two operators that don't have the same eigenspaces. I think almost all of the weird things about quantum mechanics can be pictured if you try to use human minds os something like it to explain to the laymen.
I think the final conclusion is: You can't have a reductionist or materialist approach if you want to grasp the fundamental concepts of the contemporary physics.
thank you.
I'm quite possibly repeating, but the number of experiments and bodies of knowledge supporting QM is legion: chemical bonding, molecular dynamics, theory of mattter -- solid state physics, superconductivity, superfluids, semiconductors; ATOMIC spectra, nuclear composition, the Lamb Shift, Casimir force, and on and on and on.Like it or not, QM will be around forever, modified ? Probably. Any change in the interprretation of QM will have a lot of explaining to do. There is an astonishing stability and solidity to QM, as it has been practiced. It's a great theory, maybe the best ever.
Regards,
Reilly Atkinson
How about those "accidentals"?
DrChinese said:
... it is not just that the angle between the polarizers determines the results of the experiment. It is "as if" the original photon polarity was exactly matched (or anti-matched) to one or the other of the polarizers, and no other polarizer angle setting.
This would be true if the experiments really did behave as claimed, but doesn't the title of this thread imply that they don't? In any event, my own studies have confirmed that there are enough loopholes in all the actual experiments to allow for explanations using ordinary ideas about polarisation and the accepted way in which light, as an electromagnetic wave, interacts with polarisers.
I agree that Lewis Little's ideas don't help, but why are you assuming that Aspect's experiments really did support quantum mechanics? I had hoped that you had realized that there were serious flaws.
(a) is true and so, in a sense, is (b), though it might have been interesting to see more results using different settings for parameters such as beam intensities and detector efficiencies. (c), however, is not, since the results analysed were not the raw data but the data after subtraction of "accidentals". There is very good reason (as people in the field now agree) to think that this is not, in the context of Bell tests, a legitimate procedure. It can be shown (see http://arXiv.org/abs/quant-ph/9903066) that the raw results in Aspect's first experiment did not exceed the Bell limits. It is extremely likely that those of the third experiment did not do so either, but the data to check this is not available. The only experiment in which the subtraction played no significant part was the second, and this one, using 2-channel polarisers and the CHSH test, was subject to the "detection loophole". As my work (confirming that of Pearle in 1970) has shown, the use of this test and low efficiency detectors is not valid. See http://arXiv.org/abs/quant-ph/9611037 and other papers on my web site.
The net result is that none of Aspect's three experiments can be said to have truly violated Bell's inequality. None of the tests can be considered to be valid unless one accepts a number of assumptions that are, to a local realist, unacceptable.
I don't know on what grounds you claim (d). Knowing how the detection loophole works, something that does seem clear is that increased detector efficiency will increase the gap between the quantum theory prediction and reality! With 100% efficiency, no Bell inequality will (unless other loopholes are introduced!) be violated.
Caroline
Caroline
Hi Caroline!
a) & b) we are in sufficient agreement on.
c) The results of the experiments are clearly outside the predictions of local reality. That is why the Aspect experiment is important and why you look for loopholes. Your argument is that a closer look at the evidence might indicate that the raw material might somehow show a different story, if you were allowed to exclude some of the runs. But the papers stand, and as such, you really can't argue that evidence has not been presented.
d) With the recent Innsbruck experiments showing greater precision and showing greater disagreement with your predictions, you really have to ask yourself how the greater disagreement is occurring if you are right all along. In other words, a reasonable person would have a hard time justifying a contrary position as the margin of error gets smaller but the differences get bigger. If your position is valid, greater counting efficiency should return us to the zone in which there is no violation of the Bell Inequality. That clearly isn't happening. Funny: the bias you allege in the experiments just happens to take us to the QM predictions, even though there is no obvious connection.
I freely acknowledge that there are tacit assumptions in the Bell Tests. Perhaps this should have been e). These may turn out to be loopholes, maybe not.
In other words: you could be right about Bell test loopholes. Perhaps future evidence will indicate that fair sampling is not happening. Or that the accidentals make the difference. Further, it possible that once the hypothesized loopholes are plugged, local reality will emerge as a valid possibility again. But I think that my a) b) c) d) are a fair and accurate summary of where things are today, and you clearly have a big hurdle to overcome.
Recent Bell test experiments
ZapperZ said:
You DO know that EPR-type experiments have progressed SIGNIFICANTLY beyond the Aspect experiment, and that more accurate tests by Zeilinger & Co. have produced even more accurate confirmation of QM, don't you?
Yes, I most certainly do know about recent experiments. I also know that the search for truly valid one (euphamistically termed a "loophole-free" one) is continuing, and have just finished a paper based on:
R. García-Patrón Sánchez, J. Fiurácek , N. J. Cerf , J. Wenger , R. Tualle-Brouri , and Ph. Grangier, “Proposal for a Loophole-Free Bell Test Using Homodyne Detection”, Phys. Rev. Lett. 93, 130409 (2004)
http://arxiv.org/abs/quant-ph/0403191
This experiment (in marked contrast any other recent one) does really look at if it would be loophole-free. Unfortunately, though, the argument they use to suggest that the light is going to be "non-classical" has serious flaws. I can show that the symptom they are going to use as an indicator of non-classicality is a natural consequence of the way homodyne detection works. The experiment will not, therefore, settle the matter one way or the other, as both quantum theorists and local realists will agree (once they've understood my paper!) that the whole thing is classical. Neither side will be surprised to find that the Bell test is not violated.
I'll be posting the paper soon on my web site, when the experts concerned have had a chance to review it.
Caroline
DrChinese said:
Hi Caroline!
[Correction: "The published results are clearly outside the predictions of local realism." But more of this later.]
Hmmm ... But you've got this the wrong way around! It is Aspect who, by subtracting accidentals, is effectively trying to exclude some of the runs. As my paper (http://arXiv.org/abs/quant-ph/9903066) explains, the raw data available (from his first experiment, though the same applies logically to his third) was well within the region expected under local realism. The same can be said of the first experiment published by the Geneva group showing long-distance correlations. They did not analyse the raw data, which did not infringe the Bell inequality. In later papers they published both raw and adjusted results, in recognition of the fact that I was right: the adjustment was suspect.
As far as I know, no recent experiment has used adjusted data, but what they have done instead is use tests that rely on the fair sampling assumption.
Greater counting efficiency would help in some experiments, and, by counting something completely different but to which (if my analysis is correct) Bell's argument still applies, the latest proposed loophole-free tests (http://arxiv.org/abs/quant-ph/0403191 -- see other message) manages to achieve 100% efficiency in that every pair that is analysed produces a +1 or -1 result. They apply a "belt and braces" approach, having "event-ready" detectors as well as effectively 100% efficiency.
However, in most actual experiments there are other possible loopholes. How can you claim a "Bell test has been violated" when the assumptions on which that test is based are either clearly (in the view of realists) not valid or, at least, recognised as suspect?
This is a matter of logic rather than the need for more experimental evidence, though the latter does come into the story. There are tests relating to "fairness" that could be done but are, in my opinion, either not being done at all or not being done appropriately. It is no use testing for constancy of the sample using only the angles used for the Bell tests, since everyone agrees that these are likely to be constant. They need to look at the total counts for the intermediate angles.
OK! I've devoted over 10 years of my life to it so far and am prepared to continue until death or glory!
Caroline
I think the viewpoint of Zurek and Omnes and quite possibly others like Gell-Mann and Hartle is that in EPR and similar experiments, there is a superposition of measurement outcomes in the measuring devices. This superposition then decoheres and one measurement result occurs. Or both occur if you like your many-worlds real. A lot like Schrödinger's Cat.
But that's really just my impression at the moment. :smile:
I'm wondering if a ideal von Neumann experiment could recreate a superposition in EPR and what this would mean. Something for me to think about, I guess.
That's close to my opinion on the issue, in that the von Neumann measurement occurs when the final observation of correlation is executed (the transported distant "measurement results" remain in superposition). I've discussed this a few times here before some months ago...
cheers,
Patrick.
Caroline
Caroline,
I think what you are trying to do with the Bell tests is very noble, and certainly not a waste of your time. I don't always agree with your characterization of the state of the debate, though.
In medicine, experiments are routinely done on groups of people that are not randomly selected in the purest sense of the term "random". The question always arises, is it a fair sample? Because it is nearly impossible to get a true random sample, experimentalists do their best and are always looking to improve their sampling methods. Even without a true random sample, and without a rigorous proof theirs is a fair sample, the results are considered useful. It is still good science. That does not mean it can't be improved upon, and it does not mean some incorrect results may later be laid at the feet of a biased sample.
The same applies with the Bell tests. You can say all day long that the sample is biased, but you actually have shown nothing more that the results COULD POSSIBLY be biased enough to render an erroneous conclusion. But you really aren't showing any actual bias in the results.
OK, I think everyone recognizes this.
But the march of science in this area is moving away from your personal position of local realism - for which you lack even a shred of actual evidence of equal stature to the Aspect or Innsbruck tests. After all, if you are right, why do 100% of test results of local realism point AWAY from it? In other words, you cling to a position for which there are NO supporting tests and argue against a position for which there is at least SOME strong evidence. Who is really biased here?
I think your assessment of the state of Bell tests misses the mark by a wide margin, even though you make some valid points.
-DrC
DrChinese said:
Caroline,
Have you read my Chaotic Ball paper? A recent version can be found at http://arxiv.org/abs/quant-ph/0210150 .
We are not talking about the ordinary kind of sampling bias here, where the experimenter is free to choose his sampling method. The sample is effectively chosen for him, and, if something like the assumption I make in my model is anywhere near correct, it is always going to be biased and will inevitably cause an increase in the Bell test statistic. If the detection loophole is simply assumed away (as is the general practice) then this means that the interpretation is being biased in favour of quantum theory.
This is absurd! Until Aspect inaugurated use of the CHSH test in 1982, it was generally understood that this bias was unacceptable. Other versions of the Bell test were used. Though the experiments all had loopholes, this obvious source of bias was avoided.
I think you know my answer! Agreed, there is no hard evidence for my case, other than all the phenomena we have ever encountered in other contexts. All our everyday experience tells us that everything is local and real. Quantum theorists seem to be like man in the middle ages, prepared to believe that something over which he does not yet have full experimental control must work by magic. There must be dragons out there, where he has not yet explored.
But to get back to reality, there could be supporting tests. For the past 10 years I have been trying to tell experimenters what needs to be done in order to prove that the loopholes really are there and that alternative local realist explanations really do exist.
Proving the detection loophole open is easy -- as could have been known since 1970. All you need do is repeat the experiment with different detector efficiencies and see whether the Bell test statistic increases, stays the same, or decreases as efficiency increases. Quantum theory predicts that it stays still. Local realism predicts that, other things being equal, it will decrease.
Testing for other loopholes is equally straightforward. The reason the tests have not been conducted is, I think, that most of the people who have contributed to the literature on the subject have been theorists. They have not felt qualified to comment on the experimental details. Most have never even heard of the "subtraction of accidentals" loophole, or stopped to think whether or not the system for deciding whether or not we have a "coincidence" might be introducing bias.
Time will tell!
Incidentally, if you want to know just a little more on the experimental side, you could do worse than consult wikipedia. Last summer I contributed a few pages, the key one being http://en.wikipedia.org/wiki/Bell's_Theorem . From here links cover the main variations on the Bell test, actual experiments and, last but not least, the various loopholes.
Caroline
1. We are not talking about the ordinary kind of sampling bias here, where the experimenter is free to choose his sampling method. The sample is effectively chosen for him, and, if something like the assumption I make in my model is anywhere near correct, it is always going to be biased and will inevitably cause an increase in the Bell test statistic. If the detection loophole is simply assumed away (as is the general practice) then this means that the interpretation is being biased in favour of quantum theory.
2. Incidentally, if you want to know just a little more on the experimental side, you could do worse than consult wikipedia. Last summer I contributed a few pages, the key one being http://en.wikipedia.org/wiki/Bell's_Theorem . From here links cover the main variations on the Bell test, actual experiments and, last but not least, the various loopholes.
Caroline
1. Your model is pure speculation (I don't mean that as an insult). As such it is not proof and it is certainly not a counter-example to Aspect's actual experimental evidence. You have to admit that there may in fact be no significant bias against local realism in Aspect's samples or methods - you just think there could be.
2. I want to talk to you about that. I looked at what you have done in Wikipedia to the Bell's Theorem page and was quite disappointed. In my opinion, you have essentially hijacked what should be a non-controversial page and used it to further your own non-mainstream ideas. Bell's Theorem is barely mentioned or discussed!
I fully support the spreading of your message - even though I personally disagree with its content - because I think that it helps to keep everyone on their toes. As you know, I even link to your site from my own page EPR, Bell & Aspect: The Original References. But I think Wikipedia's Bell Theorem slot is the wrong place for it and your content there probably violates the POV neutrality policy. I hope you will voluntarily shift your contributions on the subject there to a more suitable slot and return Bell's Theorem back to how it was.
