Asymptotic behaviour of bessel functions
The discussion centers on the asymptotic behavior of Bessel functions, specifically the relationship between the Bessel function ratio and an exponential expression when \alpha_n is significantly larger than one. The user seeks clarification on a statement from their notes regarding the expression involving Bessel functions and its approximation. They observe a connection between the arguments of the exponential and the Bessel functions, questioning whether this is a coincidence or if it reflects a deeper mathematical identity. The user also notes an intended approximation sign that clarifies their inquiry. Overall, the conversation highlights the complexities of understanding Bessel functions and their asymptotic properties.
lavster
Hi,
as part of my maths course i am learning about bessel functions. But this is something that I am not fully comfortable with - there seems to be a lot of tricks.
There is a statement in my notes that when \alpha_n>>1,
\frac{J_0(i^{\frac{3}{2}}\alpha_n\frac{r}{a})}{J_0(i^{\frac{3}{2}}\alpha_n)} = (\frac{r}{a})^\frac{1}{2}exp[-\sqrt{i}(1-\frac{r}{a}\alpha_n]
i know that \sqrt{i}=\pm\frac{1}{\sqrt{2}}(1+i), which i think will help show this statement. I've also noticed that the argument in exp[] is the bit in the brackets of the bessl function in the denominator minus the bit in the brackets of the bessel function on the numerator. and the multiplying factor of exp in the RHS sems to me the bits in the brackets of the bessel function deivided by each other...
can anyone tell me if this is merely coincidence or whether there is a mathematical trick or identity that helps to show this?
sorry if this is confusing...
thanks, lav
there is meant to be an approximately equal sign between the first fraction (inbvolveing the bessel functions) and the fraction with r and a to the power of 1/2...
11K
