Attention Paid To Accelerating Reference Frames Overthrows SR
153 replies · 15K views
There's a whole grab-bag of reasons why we conclude D = 0. The problem is that D doesn't have to be zero in the thought experiment.
Or, I suppose we can conclude that there is no distance between mirrors and photon guns instead of there being no inertial reference frames with relative velocity c.
Hurkyl said:
There's a whole grab-bag of reasons why we conclude D = 0. You presumed D was not zero, though, in the thought experiment, did you not?
Yes, D is nonzero by stipulation. We have a big experiment set up in our lab, involving a laser gun, and a distant mirror. We are absolutely certain that not (D=0) in reality. But here we are investigating theory. And as we are investigating theory, we have come across something odd. We have come across the result that:
[tex](\Delta t = 0) \wedge (D=0)[/tex]
(the wedge symbol ^ means AND)
We now quickly ask ourselves how we arrived at this obviously incorrect result.
Let us briefly tabulate all unclosed assumptions:
1. c=c`
2. v=c
Thus, we are here:
If c=c` and v=c then (D=0 and not (D=0)).
(Keep in mind, that at the beginning of this reasoning event, we stipulated as true, that not (D=0). Then, during this reasoning event, we opened the scope of several assumptions, which allowed us to conclude that D=0. We can now close the scope of all the assumptions, to arrive at a statement which is true, and not true by assumption. Just plain old true.)
Then we use reductio ad absurdum to quickly get here:
not (c=c` and v=c )
Then DeMorgan's law of conjunction gets us here:
not (c=c`) OR not (v=c )
And here is where I wanted to be, watching the world wake up to history.
Kind regards,
The Star Thrower
If this is all you're trying to prove, we could have gotten here much sooner, and in a much less sloppy manner. Oddly enough, if you've paid attention, you'd've noticed we've been telling you not(v=c), so you wouldn't have wasted all this time proving the above statement which we already take to be true.
You have been telling me that not (v=c) is true?
No, that is not what we currently can be said to know epistemologically speaking. We do not know that not (v=c). What we know is this:
Current Knowledge: not (c=c`) OR not (v=c)
P.S. This is not all I am trying to prove, I will prove not (c=c`). Additionally, the sloppy manner you speak of has tremendous pedagogical value.
Hurkyl said:
This whole thought experiment is supposed to be done in the context of SR, remember? And since SR => not(v=c), it is thus true that not(v=c).
I guess I should repeat my point, it is a logico/deductive one.
A theory of physics is a conjunction of many statements. If anyone of the statements is false, the whole theory is internally inconsistent.
The special theory of relativity is composed of many statements obviously. Some of which a reasoning agent is certain is true, and some of which a reasoning agent is not certain of the truth value of.
Suppose a theory of physics T consists of exactly 8 statements whose truth value we are uncertain of. We can define the portion of the theory which is uncertain to be the conjunction of these 8 statements. The rest of the theory we are certain of, and we cannot be certain of that which is false, hence the rest of the theory is consistent.
[tex]\Im = S_1 \wedge S_2 \wedge S_3 ... \wedge S_8[/tex]
Now, if the uncertain portion of this theory leads us to a contradiction, then we know that at least one of the eight statements is false, though we will not yet know which one.
Let us define the special theory of relativity to be a theory of physics which consists of exactly one uncertain postulate, namely its fundamental postulate:
The Fundamental Postulate Of The Special Theory Of Relativity
The speed of a photon in any inertial reference frame is 299792458 meters per second.
Now, I introduced a do-able experiment, designed to measure the speed of light in two inertial reference frames moving relative to each other at a constant speed v. (This is exactly the 'thought experiment' to consider, in order to falsify SR)
Now, we reached the following true statement:
not [ c = c` and v=c ]
Where c,c`, and v were defined for this experiment.
The previous statement is logically equivalent to the following statement:
If c=c` then not (v=c)
But the case where v=c is where two photons are fired at right angles to one another, and this experiment is do-able in reality.
You have a dilemma on your hands, I do not.
Kind regards,
StarThrower
Thank you!
StarThrower, despite all the math that has been thrown around you have only restated the same thing over and over again which is that you believe inertial reference frames can have v=c. Unless you address this SPECIFICALLY, you are not making progress, all you have done so far is tell us why SR is invalid if v=c.
Sure, we can fire two photons at right angles. However, this experiment which is doable in reality is not the thought experiment we were discussing. Where are the clocks attached by a rod? Where is the inertial frame of reference? Where is the triangular photon path?
The case where v=c is do-able. The theory of SR says that the experiment is not do-able. Therefore, SR has been falsified.
Kind regards,
StarThrower
Clock B is a photon, and clock C is a photon. Under SR's assumption, they move at the same speed relative to the photon gun. Hence, the distance between them isn't changing, in other words photon B isn't moving relative to photon C. So it is as if photon B and photon C are attached by a rigid rod according to SR. That having been said, the rest frame of the photon gun was stipulated to be an inertial reference frame. So there is at least one inertial reference frame. Now, consider the do-able experiment.
Two photons are simultaneously emitted from the origin, at right angles in inertial reference frame F1.
To be clear, photon A travels in the j^ direction (direction of increasing y coordinates), and photon B travels in the -i^ direction (direction of decreasing x coordinates.
The photon gun is located at the origin of F1 obviously, and there is a clock at rest there, clock A, which ticks in units of seconds. Now, 299792458 meters in the j^ direction, there is a mirror stationed. Every time a photon has been fired at that mirror, it took two seconds to return to the photon gun, as measured by clock A.
Similarly, let there be a 2nd mirror stationed 299792458 meters in the -i^ direction.
Under the operating assumption of SR, when we fire the two photons, they should return to the photon gun simultaneously.
Clearly, the two photons are in relative motion during the experiment. I now ask a very simple question.
What is the speed of photon A relative to photon B?
The result which you must inevitably get, is that:
[tex]\Delta t = \Delta t^\prime[/tex]
Kind regards,
StarThrower
Hurkyl said:
On what grounds do you assert that?
I've done the experiment.
Regards,
StarThrower
Excellent! What was your experimental setup? What were the lengths of the sides of the triangle? What was the the reading on the clocks at each event of interest? What was the experimental error?
And what bearing does the experiment have on the internal consistency of SR?
I'm also curious on how he attained an inertial reference frame during the experiment...
The distance to the mirror was about 20 feet or so, and an oscilloscope was used to make a time calculation. The laser used was helium neon. As for all the juicy details, I don't remember them now. But, you don't need them anyways, to check the internal consistency of SR. All you need to do, is compute the relative speed of two photons fired at right angles to one another simultaneously.
As someone correctly pointed out, SR says the relative speed should be c. So under the single assumption of SR, the triangle in the rest frame of the photon gun is an equilateral triangle. Thus, the angle is 60, when it is 90 in reality. Thus, the theory of relativity ends in contradiction. It is internally inconsistent.
Kind regards,
StarThrower
P.S. Of course you do need to prove that the photon's frame is inertial. :smile:
Er, so the oscillosope was moving at light speed?
And what definition are you using for "relative velocity of photons" and what bearing does it have on the validity of SR?
You seem to have lost all of your attention to detail. Don't you find it telling that you get sloppy every time you try to make your conclusion that SR is inconsistent?
The experiment was designed to simply measure the speed of light. We couldn't even get 299792458 exactly. There was only one mirror, there didn't need to be two. There was only one clock, and it was at rest in the lab frame.
But of course you are just sidestepping the issue.
Two photons are emitted from the origin of inertial reference frame F1, at right angles. What is their relative speed?
Assume the fundamental postulate of SR is correct.
Thus, each photon is moving at speed 299792458 meters per second relative to the photon gun.
Finish the analysis, tell me what the relative speed of these two photons is, assuming SR is correct.
Kind regards,
The Star
You claimed to have carried out the thought experiment we were describing, with v = c. Whether or not I'm sidestepping, you are being intentionally misleading, at best.
The only definition of relative speed of which I'm aware does not apply to this situation. Would you care to provide one?
You know what they say... you can lead a horse to water, but you can't make him drink.
And no I'm not getting sloppy. I have led you to where I wanted to. Consider two photons fired at right angles to one another. Assume SR is correct. What is their relative speed?
Regards,
Star
Hurkyl said:
The only definition of relative speed I'm aware does not apply to this situation. Would you care to provide one?
Speed in an inertial frame = distance traveled in inertial frame divided by time of travel in inertial frame
Regards,
StarThrower
Hurkyl said:
Ok, so that's speed in an inertial frame. What's relative speed?
Suppose that two objects are not moving relative to each other.
The distance between them in any frame is unchanging.
In this case, the relative velocity v is zero.
Case II: not (v=0)
Suppose that two objects are in relative motion. Thus, the distance between them is changing.
Choose one object to be at rest, at the origin of its own frame of reference, say F1. Since the two objects are in relative motion, the distance between them is changing. Thus, the coordinates of object 2 are changing in F1.
Let the position of object 2 at the current moment in time, in F1 be denoted by (x,y,z).
Define the position vector of object 2 in F1 as follows:
[tex]\vec{r} = xi + yj + zk[/tex]
Let there be an infinite number of clocks in F1, one at every point. Let all the clocks be synchronized.
Let (x1,y1,z1) be the position of object 2 in F1, the moment when all clocks read 1. Let (x2,y2,z2) be the position of object 2 in F1, the moment when all clocks read 2, and so on.
The relative speed of object 1 to object 2 can be defined as follows:
[tex]|\vec{V}| = \frac{|\vec{r2} - \vec{r1}|}{2-1}[/tex]
Or we can define time of travel using arbitrary clock readings. Let object 2 be located at (x1,y1,z1) when all clocks read A, and later, let it be located at position (x2,y2,z2) when all clocks read B. The clocks increase in their readings, tick at the same rate (by hypothesis), hence B>A. The relative speed of object 2 to object one is the magnitude of the objects velocity vector which is:
[tex]\vec{V} = \frac{\vec{r2} - \vec{r1}}{B-A}[/tex]
Kind regards,
StarThrower
Keep in mind, that the above definition is only useful when the relative speed is constant in time. If the objects are accelerating relative to each other, then the denominator must be vanishingly small.
According to some reference frame, I presume you mean?
This doesn't apply to photons. Would you care to provide a definition of relative speed that does work for photons?
Yes it does.
Kind Regards,
StarThrower
P.S. Certainly you can analyze the motion in a reference frame in which the photon is at rest. Whether or not that frame happens to be inertial is a totally separate issue.
Tom Mattson said:
So this is what this thread has boiled down to?
OK, fine.
No, it doesn't.
There is no reference frame in which the photon is at rest.
Incorrect Tom. You can choose any object in the universe you wish, and fix a rectangular coordinate system to it.
What you are concerned about is whether or not such a reference frame is an inertial reference frame, well I have news for you... if the photon isn't being subjected to a force, then it is.
Kind regards,
The Star
StarThrower said:
Incorrect Tom.
:rolleyes:
You can choose any object in the universe you wish, and fix a rectangular coordinate system to it. Makes sense to place the object at the origin of the system/reference frame. Then you get to the concept of "worldline" but I'm not going there.
Whatever. If you fix a rectangular system to a photon, then that rectangular coordinate system will be moving at the speed of light in anyone's frame.
What you are concerned about is whether or not such a reference frame is an inertial reference frame, well I have news for you... it is.
If you consider an inertial reference frame to be one that can always be brought to rest by a change of coordinates, then I have news for you: A photon cannot be placed at the origin of such a frame.
Notice I changed that post slightly. It now reads:
If the photon isn't being subjected to an outside force, then that photon is in an inertial reference frame.
Kind regards,
StarThrower
So? What does that have to do with the fact that you cannot consider the photon as the origin of a stationary frame?
