ATTWOOD'S MACHINE (rope + pully)
16 replies · 3K views · last reply
twenty5
Determine the force of gravity acting on the masses (we want to end up with 9.8m/s2---> My situation : A rope with 2 different masses hanging on each side, is held by a pulley. The heavier mass falls towards one end. (teacher said something about the mass having to cancel out afterwards) or so.
d=v1t +1/2at2
I think we can use Newton's second law, F=ma
t=0.9s
d=0.36m
v1=0m/s
I used d=v1t +1/2at2 and got acceleration which came out to be .889m/s2
I was wondering what steps I can take now
How does the measured acceleration relate to the acceleration due to gravity (g)?
You'll need to apply Newton's laws to analyze the system. Apply F = ma to each mass.
awesome ^^ i just tried that juuust right before you replied haha thanks Now I know I am sort of on the right track^^
Doc Al said:
Show exactly what you did and where you got stuck.
ok So,
step 1:
d = v1t +1/2at2
got acceleration = .889m/s2
Mass A:
FA=ma
FA=0.889a
Mass B:
FB=ma
FB=0.889a
I got stuck right there, like what can I do with it? can I find net force because If I subtract FA and Fb, it'd be 0N O_O, but since I am 100% sure that the Net force isn't 0, what do I do? because Newtons second law states that, if the object is at rest, or at a constant velocity, the net force is 0. but the mass is acceleration towards the floor =P so it cannot be 0
ehhh... anything? I am still stuck there lol...been working on it and still working on it ^^
You must first identify the forces acting on each mass, find the net force on each (symbolically), and then apply Newton's 2nd law (∑F = ma) to each. You'll get two equations (one for each mass) which you will combine.
I don't think you can finish it without knowing something about the masses.
The wording is inconsistent, too - it asks for a force, then says it should have units of acceleration. Could you check the question again and make sure it has been copied word for word?
Also:
twenty5 said:
ok So,
step 1:
d = v1t +1/2at2
This makes sense, assuming you solved for the acceleration correctly.
Mass A:
FA=ma
FA=0.889a
Mass B:
FB=ma
FB=0.889a
But I don't know what you're doing here. Each mass is different, so call them m1 and m2. Your equations will look something like:
∑F(on m1) = m1*a
∑F(on m2) = m2*a
Note that if m1 has an acceleration of a downward, then m2 must have an acceleration of a upward.
MMMM, i just found out that we can use a value for mass...
m1 = .1kg
m2 = .2kg
and now I need to figure out how to get g = 9.8
Oh, now you can do it knowing the masses!
Sum of forces = ma, where m is the total mass.
Put in an mg for each force.
ok I got... for the sum of forces is the following...
FA= mg
FA= .1g N
FB= mg
FB= .2g N
FNET = FB - FA
FNET = .1g N
Fsum of forces = .3g
.1g = .3g?
and now I don't know how this will get me to 9.8 ^^
mmmmmmmmmm
I also tried doing...
Ftotal force = ma, where I subbed in the a that I obtained from before...
0.1g = 0.3*0.889
g = 2.6m/s2...
But If I heard the teacher correctly, I believe I heard I'm supposed to get 9.8 or something lol
sum of forces = ma
.2g - .1g = .3*0.889
you can easily find the ACCELERATION of gravity.
No, it isn't working out to 9.8 as you would expect . . . on Earth.
Your question says find the FORCE of gravity - not sure what that means in this case since there are 2 different masses so two different forces of gravity. Check the wording again?
Delphi51 said:
sum of forces = ma
sorry, the question just says
Attwood's Machine - Measure Acceleration, calculate g.
I also did the experiment physically too =P
I made a pulley with a rope and a mass on either end. and I just let it drop, timed it, and measured the distance =P
Are you sure the values of time and distance are accurate? Given those two masses g should be equal to 3a.
