Atwood machine, solve for angular acceleration
To solve for angular acceleration in an Atwood machine involving two masses and a pulley, it's essential to relate the angular acceleration of the pulley to the linear acceleration of the masses. The net torque on the pulley equals the moment of inertia times the angular acceleration, while the net force on the masses equals their mass times linear acceleration. The linear acceleration of the masses is directly related to the angular acceleration of the pulley through the radius of the pulley. Understanding that the tangential acceleration at the pulley’s circumference is equal to the linear acceleration of the masses is crucial for solving the problem. Clarifying these relationships helps in accurately determining the angular acceleration.
aznboi855
The goal is to solve for angular acceleration with the end variables being m1,m2,m3, R, r, g.
M2 > M1.
An atwood machine is a pulley with 2 masses, one on each side.
Tnet = I * angular acceleration
Fnet = ma
I know you have to solve for both the masses and the pulley itself, but how do you relate them?
How does the angular acceleration of the pulley relate to the linear acceleration of the masses?
It's the same?
aznboi855 said:
It's the same?
:confused: How can an angular acceleration be the same as a linear acceleration? (But they are simply related though.)
I must've misunderstood your question, I simply thought that because the mass is having a linear acceleration downward, therefore causing the pulley to have an angular acceleration, they must be the same :S. I'm bad at this angular stuff :(.
Angular acceleration the change in angular velocity over time, and angular velocity is the change in angle over time... so... I still can't relate them :S.
Hint: Given the angular acceleration of the pulley, what's the tangential acceleration along its circumference?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
