Atwood machine with variable mass
7 replies · 4K views
titansarus
We have an Atwood machine like the picture below. one side (left) is a bucket full of water which has a hole on the bottom and the water is flowing with rate ##dm/dt = \alpha = const##. The initial mass of bucket with the water is ##m_0##. On the other side (right) we have a box with constant mass ##m_1##. We also know the speed of water relative to the system at every time is a constant number ##v_0## (It is given in the question). we want to find the speed of each box (which is equal in opposite directions) at every time ##t##. In fact we want to find ##v(t)## (##v## as a function of ##t##).
Note: Pulley and rope and etc... are all frictionless - massless and completely ideal. And the pulley is fixed to somewhere (maybe wall or roof, so it doesn't move)
After solving the equations of momentum for an arbitrary system of initial mass ##M##, I get the formula
##M dv/dt = F_{ext} + v_{rel}~~ dm/dt##.
in this question ##v_{rel}## and ##dm/dt## are both known constants. But I don't know what to do with ##F_{ext}##. Is it for the whole system? Is it just for the bucket? What is ##M## in the question: ##m_0## or ##m_0 + m_1##? What should I do to get a integrable equation?
The least confusing approach is to assign a variable T=T(t) to the tension and consider the two suspended masses separately.
Now how to work with this T? I wrote ##m_1 g - T = m_1 a## and ##T - m(t) g = m(t) a## . Now maybe by dividing both sides, we get something like ##m_1 g - T / (T - m(t) g) = m_1 / m(t)## , we get an equation for T(t) in terms of ##m_1## and ##m(t)##. It is ##T(t) = 2 m_1 m(t) g / (m_1 + m(t)) ## Also ##m(t) = m_0 + \alpha t## (##\alpha## is negative).
Now I think I must write something like ##m_0 dv/dt = (T - m(t) g) + v_0 \alpha~~~## ? Is it OK? from this I get ## m_0 dv = (T - (m_0 + \alpha t) g)~dt + v_0 \alpha ~ dt##
I used wolfram alpha to evaluate this and I get:
\left(-\frac{2 g m_1^2 \log (\alpha t+m_0+m_1)}{\alpha}-\frac{1}{2} \alpha g t^2+\alpha v_0 t-m_0 g t+2 g m_1
t\right)
= m_0 V(t)## by assuming that ##v## of the system was at ##t=0## was zero. And we get ##V(t)## from here. Is it Right? Does it really get that complicated?
No, you should have used that earlier:
v0 features in the force balance on m0.
When you have that right, your first step should be to eliminate T.
I think you mean something like: ##m_0 dv / dt + (m_0 + \alpha t) g - v_0 \alpha = T##, right? Now should I substitute this in ##T - m(t) g = m(t) a## or maybe ##m_1 g - T = m_1 a##? Or should I write something like ##m_1 g - m(t) g = (m_1 + m(t)) a##? Or maybe both?
I evaluated what I said in post #5 (above post) and substituted T in the equation that has m(t) and multiplied them by ##dt## and I got a huge formula like: ##
\frac{2 \alpha^2 t {v_0}-4 g {m_1}^2 \log (\alpha t+{m_0}+{m_1})-g (\alpha
t+{m_0}+{m_1})^2+6 g {m_1} (\alpha t+{m_0}+{m_1})}{2 \alpha} = m_0 v(t)
##or actually this according to wolfram alpha:
If I substituted that in the equation with m1, it might get a little smaller but it will still be a big equation.
A few problems there.
What is the mass on the left at time t?
Write the equation in the form ΣF=ma; that helps in getting the signs right.
I also get a log function, but I don't think you should have had quadratic terms. Please post your working next time.
