Auto-Closing Gate (Relative Acceleration problem homework)
The discussion revolves around a physics problem involving an auto-closing gate, where two identical parts of the gate are connected by masses and pulleys. The original poster seeks to understand the motion of the masses relative to the gate parts and how this relates to the time taken for the gate to close.
  • Participants discuss the motion of the masses as the gate closes, with some suggesting that the masses move downwards on the inclined plane. Others explore the implications of symmetry and the reference frame used for analysis.
There is active engagement with various interpretations of the motion of the masses and the forces involved. Some participants have provided guidance on analyzing the problem from different reference frames, while others are working through equations to describe the system's dynamics.
Participants note constraints such as the requirement to work in a ground frame and the absence of friction in the system. The original poster has also mentioned the lack of explicit instructions regarding the forces acting on the masses and the setup of the problem.
  • #31
So i can't use the displacement to find the acceleration?
  • #32
You can use distances, not displacements.
  • #33
And the quantity of the accelerations are same? Right? I mean if the acceleration if mass m is 'f' and the mass M is 'a' then |f|=|a| right?
  • #34
Is there a name for that concept? Using distances to find acceleration in relative acceleration?
  • #36
The quantities of acceleration of two masses are same right?
  • #37
The distance from the central point to the pulley plus the distance from the pulley to the sliding mass is constant. Thus the second derivatives of those distances are equal and opposite. The first of those two is indeed the scalar acceleration of the gate, but the second is not the scalar acceleration of the sliding mass. Rather, it is the acceleration of the mass relative to the gate.
  • #38
So if i take " x +(x+y) " woild that be a constant?
  • #39
No, you were right to say that |x|+|y| is constant, but ##\ddot {|y|}## is not the magnitude of the acceleration of the sliding mass in the ground frame. It is the magnitude of its acceleration relative to the gate.
  • #40
Yeah i just relaized that is there a way to get displacement from middlepoint to the mass and get x (x as mention before) both a constant?
  • #41
So'll have the mass's acceleration in relative to ground
  • #42
Just add the accelerations vectorially.
amass relative to ground=agate relative to ground+amass relative to gate
  • #43
Thank you so much. I just managed to understand relative acceleration much more than i knew earlier. Thank you so much. I've found the same problem which has given the answer and i got it. Thank you.
  • · Replies 17 ·
  • · Replies 35 ·
