Average force exerted on the ball
22 replies · 3K views · last reply
nysnacc
Text problem: The 0.45-kg soccer ball is given a kick with a 0.12-s duration that accelerates it from rest to a velocity of 12 m/s at 60° above the horizontal.
Screenshot of a homework question reading: What is the magnitude of the average total force exerted on the ball during the kick? Express your answer with the appropriate units.
Homework problem text on the left asking for the magnitude of the average force on a ball kicked by a player, with a strategy hint citing an impulse equation; on the right, handwritten (t2 - t1) ΣFav = mv2 - mv1.
∑Fav = mv2 - mv1
We have to separate v in x dir and y dir?
Why? (Note that it starts from rest.)
but are part one and part two asking the same thing?
No. One asks for the average total force on the ball. The other part asks for just the force exerted by the foot.
For the average total force on the ball (1st part). what equation should i use?
For the (2nd part) force exerted by the foot, the equation is F = (mv2- mv1 ) / Δt
No, that will give the average total force on the ball.
For part 1,
F = 1/ Δt * ∫ F dt ?? which is (mv2- mv1 ) / Δt ??
For part 2,
F = (mv2- mv1 ) / Δt - mg (cuz the question said subtract the weight)
nysnacc said:
For part 1,
Yes.
nysnacc said:
For part 2,
Careful. Forces are vectors, so here you need to consider the directions of each.
For part 2
(mv2- mv1 ) / Δt (going up)
mg (going down)
what should i do with the 60 deg which is given?
That's the direction of the average total force on the ball.
nysnacc said:
Part 1, F = 45 N
Part 2 F = 41.236 N?
I'm not sure whether the hint given in the question is simply wrong or is assuming the weight, being a downward force, will be expressed as a negative quantity. Ask yourself this: does the presence of gravity increase or reduce the force needed from the boot to achieve the given velocity?
Secondly, forces are vectors. You cannot add (or subtract) forces acting in different directions by adding their magnitudes.
#2 i have F = Fav (cos i + sin j) + mg (-j)
= (Fav cos )i + ( Fav sin - mg ) j
nysnacc said:
why is my #2 not correct?
You made a mistake with the sign of the weight vector.
##\vec{F_{total}} = \vec{F_{kick}} + \vec{F_{weight}}##
To find the force of the kick you must subtract the weight vector, but the weight points down.
