Average Length of Life of Two Exponentially Distributed Components
The discussion revolves around the average length of life of two independent electronic components governed by an exponential distribution with a mean of 1. Participants are exploring the probability density function for the average length of life and discussing related calculations of mean and variance.
  • Participants discuss the derivation of the probability density function, with some attempting to integrate and differentiate to find the correct form. Questions arise regarding the interpretation of the average length of life and the implications of using (y1+y2)/2 versus (y1+y2).
The discussion is active, with participants providing insights and corrections to each other's reasoning. There is acknowledgment of the need to clarify the average length of life in the context of the problem, and some participants express uncertainty about their calculations while seeking further understanding.
Participants are working under the constraints of homework guidelines, which may limit the amount of direct assistance they can provide to one another. There is an emphasis on ensuring that the definitions and setups are correctly understood before proceeding with calculations.
kjartan
1. Suppose that two electronic components in the guidance system for a missile operate independently and that each has a length of life governed by the exponential distribution with mean 1 (with measurements in hundreds of hours).
(a) Find the probability density function for the average length of life of the two components.
(b) Find the mean and variance.
2. f(y) = e^(-y) for y>=0
For (a), I obtained, f(u) = u*exp(-u) for u>=0. Still an exponential distribution.
The back of the text had f(u) = 4u*exp(-2u), where f has a gamma distribution with α=2, β=1/2.
Thanks for any and all help!
How'd you come up with your result of f(u) = ue-u?
Thanks for taking a look!
What I did was this.
f(y1) = e^(-y1), and f(y2) = e^(-y2), since the general form for an exponentially distributed random variable is f(y) = (1/[tex]\beta[/tex])*e^(-y/[tex]\beta[/tex]). Where the mean is beta, and we are given that the mean is 1.
Then, since y1 & y2 are independent, f(y1,y2) = f(y1)*f(y2).
Thus, e^(-y1)*e^(-y2) = e^(-(y1+y2)).
Then, the distribution function, P(Y1+Y2<u) is given by
[tex]\int^{u}_{0}[/tex][tex]\int^{u-y2}_{0}e^(-(y1+y2))[/tex]dy1dy2 = 1-ue^(-u)-e^(-u)
Then, to get the density function, we differentiate with respect to u, obtaining:
f(u) = ue^(-u)
I think you just need to calculate the average length of life as (y1+y2)/2, not simply (y1+y2).
Ok, almost there . . .
So, since we have (y1+y2)/2, we switch the upper limits of integration as such:
[tex]\int^{2u}_{0}[/tex][tex]\int^{2u-y2}_{0}e^(-(y1+y2)/2)dy1dy2[/tex]= 4(1-e^(-u)-ue^(-u)).
Then take d/du, obtaining:
4ue^(-u)I must be tired, I'll have to take another look at this to figure out what I'm doing wrong . . . need to obtain 4ue^(-2u) . . .
Thanks! I think that's the crux of the problem that I was missing, now I just need to fill in the last detail . . . I appreciate your help.
The joint probability density doesn't change; only the limits do.
Whoops! Thanks!
Ok, now finally . . .
integrating e^(-(y1+y2)) with our new limits of integration and then taking d/du, to obtain
f(u)=4ue^(-2u)
Presto!
Thanks! Ok, so I should have paid more attention to their use of "average" in the question, I kind of read over that.
I appreciate your help, I stared and stared at that problem and could not figure out what I had done wrong.
  • · Replies 18 ·
