Average power in Amplitude Modulation
4 replies · 5K views · last reply
onceinalifetim
how the overall power becomes lesser when one side band is taken away by the bandpass filter and also how it limits the bandwidth of the signal
there is will be the trade off between power and bandwidth. Vdc and Vm are peak values of the carrier and modulating sine waves. the power in the carrier and sidebands can be calculated the power formula..
In single-sideband operation (SSB) the carrier and one of the two sidebands are removed. Since power exists in the carrier and both sidebands, removing two out of the three signals reduces the transmitted power in relation to the power in the remaining sideband. And the absence of the carrier and the other sideband makes room for other SSB signals.
hi.. thanks for the reply..
may i know how does it effect the limits the bandwidth go the signal? i still very confuse about this point.
hi..
do you have any links that i can read?? thanks
As I said, removing the carrier and one of the sidebands makes bandwidth available for other signals.
I suggest a search on "amplitude modulation". You need to start with what's called "ordinary amplitude modulation" which is like what your AM radio uses. Then you can see how AM-SSB differs from ordinary AM, including power in the carrier and the sidebands.
