Average Power Output for 260000 kg Jet at 9200m Altitude
The discussion centers on calculating the average power output of a 260,000 kg jet after it reaches a cruising altitude of 9,200 meters and a speed of 235 m/s. The initial kinetic energy is zero, and the final kinetic energy is calculated as 7,179,250,000 Joules. However, the calculation neglects the change in potential energy, which is crucial for determining the total work done. Participants suggest incorporating both the change in kinetic energy and potential energy into the work equation to find the correct power output. The conversation emphasizes the importance of considering all forms of energy in such calculations.
spockjones20
620 seconds after starting its take-off, a 260000 kg jet reaches its cruising altitude of 9200 meters and flies with a speed of 235 m/s. Neglecting friction, what has been the average power output of the engines?
ΔKE = Work
Power = Work/time
Initial KE = 0
Final KE = .5*260000*235^2 = 7179250000
Power = 7179250000/620 = 11579435.48 Watts
Can someone see an issue with what I am trying to do here? I tried to type in this answer but apparently it is wrong.
ΔKE = Work
Power = Work/time
Initial KE = 0
I haven't checked your math, but I can see you left out the change in potential energy.
Ok. Would that go into the work equation?
I believe so.
Try this: ΔKE + ΔPE = Work
and see what happens.
