Can Work-Energy Formula Be Used to Solve Ball-Spring Collision?
  • Thread starter Thread starter walking
    Ball Spring
The forum discussion focuses on the application of the work-energy formula in solving ball-spring collision problems. The initial attempt involved calculating the work done on both the ball and the spring, leading to an incorrect expression for the final velocity. The correct approach requires the use of conservation of momentum alongside the work-energy principle to account for energy stored in the spring. The accurate final velocity formula is derived as ##\frac{v_im_b}{m_s+m_b}##, highlighting the importance of considering all energy transformations in the system.
  • Understanding of the work-energy theorem
  • Familiarity with conservation of momentum
  • Basic knowledge of kinetic energy calculations
  • Concept of energy storage in elastic systems
  • Study the work-energy theorem in detail
  • Explore conservation of momentum in collision scenarios
  • Learn about elastic and inelastic collisions
  • Investigate energy storage mechanisms in springs
Physics students, educators, and anyone interested in mechanics, particularly those studying collision dynamics and energy transformations in elastic systems.
walking
A ball collides with a spring and they stick together at maximum compression of the spring. Find the final speed of the spring.
Conservation of momentum
I completely missed the collisions approach when I first tried to solve this and tried using the work-energy formula. I am wondering if this approach can be made to work? Here is my attempt:
So I let the work done on the ball be ##W_b## and work done on spring be ##W_s##. Then $$W_b=\Delta K = \frac{1}{2}m_b v^2-\frac{1}{2}m_bv_i^2$$ and $$W_s=\Delta K=\frac{1}{2}m_sv^2-0=\frac{1}{2}m_sv^2$$, where the final velocities are equal due to sticking together. Now I said that since the only force acting on spring is from the ball and the only force acting on the ball is the spring, then intuitively ##W_b=-Ws##. So $$\frac{1}{2}m_b(v_i^2-v^2)=\frac{1}{2}m_sv^2$$ or $$(m_s+m_b)v^2=m_bv_i^2$$ or $$v=v_i\sqrt{\frac{m_b}{m_s+m_b}}$$. But this is wrong unfortunately (answer is ##\frac{v_im_b}{m_s+m_b}## which I know how to obtain using the collisions approach).
While you think you found the work done on the spring, what you actually expressed was the change in KE of the gun. And you set the decrease in KE of the bullet equal to the increase in KE of the gun. Ah, but some of that energy gets stored in the spring -- you left that out.
(You do need to use conservation of momentum as well.)
  • · Replies 33 ·
  • · Replies 20 ·
