Ball goes down a frictionless ramp
5 replies · 6K views · last reply
M1ZeN
A hollow ball goes down a frictionless ramp. The ball starts at a height of 5 m. The ball has a radius of 4 cm and a mass of 0.5 kg.
(a) What is the final velocity of the ball at the ball at the bottom of the ramp if it just slides down the ramp to a final height of 0 m. (Assume no rolling)
(b) If the work done (by gravity on the ball) was used to rotate the sphere instead, what would the angular velocity of the ball be?
I have no clue. I went through the section in my textbook that seems to relate to this practice test problem but they none of them seems to be anything I could use.
Again, being I can't find any formulas or equations to work with. I don't know where to start with the values given.
Thanks
Hi there,
Since your questions asked for the "work done", I presume that you are studying the chapter dealing with energy. Remember that a frictionless problem boils down to the mechanical energy conservation principle.
Cheers
I see. That definitely rang a bell.
So simply, I could just break the problem down with K(i) + U(i) = K(f) + U(f) and in turn that would substitute to be (1/2)MVi^2 + mgyi = (1/2)MVf^2 + mgyf
Also, for part b, would I just use for angular velocity w = sqrt(g/r)?
No; I think what you need to use for b is conservation of energy where there are 2 forms of kinetic energy, rotational and translational:
mgy=1/2mv^2+1/2(I)w^2 So you need to compute I for a hollow ball (I=2/5mr^2).
Now altho it may look hopeless, one eqn with 2 unknowns it is not. The translational velocity (linear) and rotational or angular velocity are related how? Use this to substitute v with w (angular velocity).
The work done by gravity--and thus the final kinetic energy--in both cases in the same. In the first, all the energy is translational KE; in the second, rotational KE. What's the formula for rotational KE?
I interpret part (b) a bit differently than denverdoc did. I don't think it's asking for the rotational speed of a ball rolling down the hill (which is a more interesting problem). (If that is what it's asking, then it's very poorly worded!)
Doc, I see your point. I thought it was ambiguous and decided on the more "interesting" interpretation. Your likely right as it does say "convert."
