Ball in gravity: how high does the ball go? Initial velocity?
In summary, a baseball pitcher hurls the ball up in the air. Its height in feet t seconds after the throw is given by h(t)=5.9+69t-16t^2. How high does the ball go? What is its initial velocity?Are you familiar with derivatives?All you have to do is maximize that function and evaluate the derivative of that function at 0. In summary, using Holly's method, you can solve for the height of the ball when it is at its maximum height without derivatives.
mayo2kett
23
i know this is a really simple problem but I'm kinda stuck on it since i don't know what to do with the equation I'm given :eek: ...
Having won the game, a baseball pitcher hurls the ball up in the air. Its height in feet t seconds after the throw is given by
h(t)=5.9+69t-16t^2
cookiemonster
Thowing the ball up: h=initial height + v0*t - (1/2)gt^2. That's the usual gravity accel equation-thing.
69 is the initial velocity. It must be feet per second, because 16=1/2 of 32 and g=32 ft/s^2, or so they say. 5.9 is the initial height, they gave it to you.
The total time from when it goes up and comes back to the initial height is when height=initial height,
so,
height-initial height = 0 = v0 * t - 1/2 gt^2, solve for t, the time.
When you get that, 1/2 of that is on the way up to its max height.
So put 1/2 of that time into the first equation to get the max height.
Holly's method allows you to do it without derivatives. That is, you just compare it to the standard form of the "kinematical equation."
i have learned derivatives but i was trying to learn how using the formula...
i now understand how to get the initial velocity and height ( i didn't know they gave then to me like that), but I'm a little stuck on the max height... this is the work i did:
0 = 69t-(1/2)(9.81)t^2
t=14.067
(1/2)14.067=7.03
then:
h=hi+ v0*t - (1/2)gt^2
h=5.9+69(7.03)-(1/2)(9.81)(7.03)^2
=248.56
but this answer seems to be wrong... I'm not sure what i did, was it just a multiplying error?
You have to identify the numbers in the kinematic equation, which is strictly mathematical (pre-physics, if you will). You are imposing unwarratned physics. Perhaps it would help you to imagine that you are on some alien planet. Then, consider the kinematical equation in the form that holly suggested. (Of course, also as holly pointed out, this is representative of Earth in the units given, but it is a good exercise to consider the more fundamental meaning of the kinematical equation.) In other words, 9.81 is inappropriate in this case.
ok so i understand why i shouldn't included gravity in this but how else can i solve for t?? i think I'm making this much harder than it should be, but i never learned anything about kinematics...
whouldn't it just be easier if i took the derivative of this: h(t)=5.9+69t-16t^2
so: h(t)'=69-32t
but what do i do from here to get the max height? our physics teacher has only taught us using formulas...
t=14.067
(1/2)14.067=7.03
then:
=248.56
What you did wrong was to put your own value for g in the equation. The original equation was perfectly fine. Why did you put g = 9.81?
As Holly explained, this equation uses feet for distance units, not meters. So g = 32 ft/s^2.
To use Holly's method, do this. Find the times where the height is the original height. Why? That equation is trivial to solve! You were on the right track, but you modified the given equation for some reason.
So: 0 = 69t-16t^2 = t (69-16t)
The solutions are t = 0 and t = 69/16 = 4.31 sec.
Now you take it from here. Using the original equation for height, of course!
so: h(t)'=69-32t
The maximum height is where the derivative (the velocity!) is zero. Find the value of "t" that gives zero velocity. Then find the height at that time.
Do it both ways and compare your answers. They'd better match.
you guys are awsome thanks so much... i understand what i was doing wrong now, i just didn't understand holly's explanation correctly... we've never learned that gravity could be anything besides 9.81. :)
Make sure you aren't including me in your "thanks," because I didn't learn any of "my" method by myself. Turin, marcus, Doc Al, cookiemonster and the other Brains of the forum showed me how to do it before. It's these Brains I am mighty thankful for...when one of them answers you, you can rest easy...THEY ARE GREAT!
I think you earn the primary credit for this one, holly. It is an arrogant person who assumes self sufficiency for their own knowledge.
Yeah, really. You think we figured all this out on our own? You're just doing what we're doing, so all's fair!
cookiemonster
1) What is the formula for calculating the height of a ball in gravity?
The formula for calculating the height of a ball in gravity is h = (vi^2 * sin^2 theta) / (2g), where vi is the initial velocity, theta is the angle at which the ball is thrown, and g is the acceleration due to gravity.
2) How does the initial velocity affect the height of the ball?
The higher the initial velocity, the higher the ball will go. This is because the initial velocity is directly proportional to the maximum height the ball will reach.
3) Is the angle at which the ball is thrown important in determining its maximum height?
Yes, the angle at which the ball is thrown is important in determining its maximum height. The higher the angle, the higher the maximum height. However, if the angle is too high (90 degrees), the ball will not travel horizontally and will fall straight down.
4) Does the mass of the ball affect its maximum height?
No, the mass of the ball does not affect its maximum height. The only factors that affect the maximum height are the initial velocity, angle, and gravity.
5) How does air resistance impact the maximum height of a ball in gravity?
Air resistance can slightly decrease the maximum height of a ball in gravity. This is because air resistance acts as a force that opposes the motion of the ball, causing it to lose some of its initial velocity and therefore not reach as high of a height as it would without air resistance. However, for most practical purposes, the impact of air resistance on the maximum height can be considered negligible.
