Baseball Curveballs: Explanation & Bonus Tips
  • Thread starter Thread starter physicsgrade11
    Baseball
A curveball's movement can be explained using the Bernoulli effect, which simplifies the understanding of how air pressure differences cause the ball to curve. When a baseball is thrown with clockwise spin, the air moves faster on one side, creating lower pressure and resulting in a rightward curve. The discussion also touches on the Magnus effect, which is related but more complex, and is exemplified by soccer player Beckham's bending shots. There is curiosity about the possibility of a ball curving in two directions, but no clear information is available on that phenomenon. Understanding these principles can enhance the explanation of how curveballs work in baseball.
physicsgrade11
For a question on one of my assignments, we have to explain how a curveball works. I have been reading a lot on the internet on it, but he says that we do not need the magnus effect to explain it (which all the sites weem to use). Also, he said for bonus we could explain how it is theoretically possible to throw a curve ball that will curve twice?
Any help would be appreciated:smile:
Basic "curveball" curving is usually explained through the Bernoulli effect. Bernoulli and Magnus are related, but the first is simpler.Do some reserach on the English footballer Beckham who is famous for a spectaacular "bending" curve. For this you will need to know about the Magnus effect.
Okay. I had the answer for the curveball I was just having a little trouble understanding it. Does this make sense?
Assume a baseball throws the ball (forwards) with the ball spinning clockwise. Then on the right side of the ball the velocity of it's spin would be in the same direction of the flow of the air and on the left it would be in the opposite direction of the flow of air. So relative to the ground the velocity on the right side of the ball is faster. Which means that the pressure is lower on that side and higher on the left side.
So the ball will curve to the right?
No luck finding anything about the ball that will curve one way then start to curve the other?? anyone even heard of this?
Thanks
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
