Basic Fluid Energy: Pressure, GPE & KE
  • Context: Undergrad
  • Thread starter Thread starter BobP
    Energy Fluid
The total energy of a fluid in fluid dynamics is expressed as either P + ρgh + ½ρ(v^2) or P - ρgh + ½ρ(v^2), depending on the sign convention used for gravitational potential energy. The first equation assumes height (h) is measured upward, while the second assumes it is measured downward. In practical applications, particularly in haemodynamics, it is advisable to use the equation with the plus sign for clarity, treating h as positive in the upward direction. Understanding these conventions is crucial for correctly applying Bernoulli's Law in examinations.
  • Fluid dynamics fundamentals
  • Bernoulli's Equation
  • Gravitational potential energy concepts
  • Basic calculus for fluid flow analysis
  • Study Bernoulli's Equation applications in haemodynamics
  • Learn about sign conventions in fluid mechanics
  • Explore the derivation of energy equations in fluid dynamics
  • Investigate practical examples of pressure and energy calculations in fluid systems
Students and professionals in fluid dynamics, particularly those focusing on haemodynamics, engineers, and anyone involved in analyzing fluid energy systems.
BobP
In fluid dynamics, the total energy of a fluid can be given as:
Pressure energy + gravitational potential energy + KE
or
P + ρgh + ½ρ(v^2)
But I have also seen the expression
P - ρgh + ½ρ(v^2)
NOTE the minus sign in the second equation.
Which is correct? Why are both equations used
Thank you
or
P + ρgh + ½ρ(v^2)
P - ρgh + ½ρ(v^2)
Thank you
In the first equation, h is measured upward, and, in the second equation, h is measured downward.
Chet
Chet
Ok, so in an examination how do I know which to use?
PS I am studying haemodynamics (energy of blood in the body)
You pick whichever makes more sense. At the end of the day, any particle (fluid or otherwise) should gain potential energy if it is moved in a direction against gravity. So if one pet of a fluid flow is "above" another with respect to gravity, then moving that direction should make the ##\rho g h## term larger no matter which sign convention you choose.
d
Fingers crossed it will make sense in the exam!
It's really pretty simple. When in doubt, pick the one with the plus sign and treat ##h## as positive in the "up" direction. I've honestly never seen it used the other way.
In the usual applications of Bernoulli's Law one compares the pressure at one point to that of another to the flow rate and height at one point to that of another. Thus
P1 -P2 = ½ρ(v22 -v12) +ρg(h2 - h1)
One only has to look at the data to enter the proper values.
In exams you will need to find the difference in total energies. Not absolute energy. So using proper sign conventions h can be positive negative or zero. Depends on the reference frame.
Thanks all for your replies!
  • · Replies 24 ·
  • · Replies 18 ·
