Basic Hydraulics: Flow, Pressure, Force, Area, Energy
This discussion focuses on the fundamental principles of hydraulics, specifically energy conservation, pressure, flow, and their interrelationships. The total energy in a hydraulic system is the sum of potential and kinetic energies, remaining constant in a closed system. Pressure is defined as force distributed over an area, and flow is the mass of fluid moving per unit time. The relationship between flow and pressure differential is crucial, as flow decreases with increased restriction, while pressure increases, demonstrating the conservation of power in hydraulic systems.
  • Understanding of basic physics concepts such as energy, force, and pressure.
  • Familiarity with hydraulic systems and their components.
  • Knowledge of flow rates, including mass flow rate and volumetric flow rate.
  • Basic comprehension of pressure differentials and their effects on fluid dynamics.
  • Research "Bernoulli's Principle" to understand the relationship between pressure and flow in fluids.
  • Study "Hydraulic Power Calculations" to learn how to calculate power in hydraulic systems.
  • Explore "Orifice Flow Equations" to analyze flow rates through different sized openings.
  • Investigate "Fluid Dynamics Basics" for a deeper understanding of how fluids behave under various conditions.
This discussion is beneficial for students, engineers, and technicians seeking a foundational understanding of hydraulic principles, as well as anyone involved in designing or maintaining hydraulic systems.
thender
Hello, I am trying to get a grip on the basic relationships in hydraulics. I do not need the advanced math and engineering, compensation for frictional losses, and fluid viscosity and turbulence effects. Just a good basic understanding.
The first concept that comes to mind is the concept of energy, I believe the total energy in a system is the sum of the potential and kinetic energies. And that energy within a system is the conserved property. Like the amount of work that can be done, has been done, and is being done if added up should always be the same in a closed system.
Another concept is Pressure. I believe that pressure describes force distributed by a fluid over an area. Force is something that can be measured for a fixed area. Like if I have 100 PSI and apply it to something with .5 square inches, it generates 50 pounds of Force.
I consider flow to be the mass of a fluid per unit time that moves past a point. I think that's the volumetric flow rate.
A related concept is the velocity of the flow.
Flow seems to be related to the pressure differential between two points.
And by this point I've lost my grip.
Using a basic example, if I open the faucet outside and let water flow out of a garden hose, it will come out steadily, if I then restrict the hose by placing my thumb over the end, the water gushes out violently.
I don't believe that restricting the hose with my thumb changes the total energy in the system.
I think that the water sprays out farther because its force increased, and its force increased because the same pressure was applied to a smaller area.
Flow probably decreased. If I compare a faucet that is only slightly cracked open, it will just drip, compared to one fully open that is gushing, I think the flow is inversely related to the restriction.
I'm lost.
In the same system I can have high pressure, low flow output, or high flow, low pressure output. So I think flow * pressure = power (conserved).
And I think flow is proportional to the difference in pressures and the area. A higher pressure differential should result in more flow for an orifice of the same area. And a larger orifice should increase flow. So flow = pressure1 / pressure2 * area.
Thus putting my finger over the end of a garden hose reduces the effective area the pressure differential is applied across, which reduces the flow, and increases the pressure, result - spraying water ten feet.
HELP! I need basic working theory!
  • · Replies 21 ·
  • · Replies 19 ·
