Basic Kinematics - shouldn't there be a constant?
3 replies · 1K views
Taulant Sholla
a=dv/dt, v=dx/dt, x=integ(vdt)
We were given the above problem and solution. Everything seems very straightforward. My question is this: should the function for acceleration also include a constant, e.g.
[/B]
None of the given initial conditions seem to indicate that a(0)=0.
Thank you!
On the contrary: it is easy to see that ##a(0) = {d\over dt} (\alpha - \beta t^2) \Bigr |_{t=0} = 0##
It is not wise to use the same symbol ##\alpha## for two different things :rolleyes:
A constant only appears if you are given e.g. a velocity and need to calculate the position.
If you have the position as a function of time, the velocity is unambiguous: no constant.
Mutatis mutandis for acceleration and velocity.
When you find the acceleration you take the derivative of the velocity function. Only when you integrate a function do you have to add a constant.
Ach - yes, thank you. Pretty embarrassing :oops:
