Distance traveled by pi mesons in special relativity
The discussion centers on calculating the distance traveled by pi mesons before they decay, given their proper average lifetime of 2.6 x 10^-8 seconds and a speed of 0.9c. Participants clarify that the distance must be calculated from the perspective of an external frame, such as Earth, rather than the meson's rest frame. The correct approach involves applying time dilation to determine the time experienced in the Earth frame, which is essential for calculating the distance traveled using the formula L = L_0 sqrt(1 - (v/c)^2).
  • Understanding of special relativity concepts, particularly time dilation.
  • Familiarity with the proper lifetime of particles and its significance in relativistic physics.
  • Knowledge of the Lorentz transformation equations, specifically L = L_0 sqrt(1 - (v/c)^2).
  • Basic understanding of the concept of rest frames in physics.
  • Study the implications of time dilation in special relativity.
  • Learn how to apply the Lorentz transformation to various scenarios in physics.
  • Explore the concept of proper time and its applications in particle physics.
  • Investigate the behavior of particles at relativistic speeds, particularly in high-energy physics experiments.
Students of physics, particularly those studying special relativity, educators teaching particle physics concepts, and anyone interested in the behavior of subatomic particles at high velocities.
jaejoon89
The proper average lifetime of pi mesons is 2.6*10^-8 s. If a beam of these pi mesons is moving with a speed of 0.9c, then
with respect to rest frame of the pi meson, how far does it travel before it decays?
L=L_0 sqrt(1-(v/c)^2)
T=T_0 sqrt(1-(v/c)^2)
I thought it was 0 because it's not moving with respect to itself. My teacher says this is a trick question... so I was wondering if zero is not the case even though it seemed at first simple enough.
why it should be zero?? .. well, I`ll give you a hint:
you are give the average lifetime of the pi meson (which represents the proper time) , can you first find the time dilation then go on from there to find the distance of travel?
So the time it travels before decaying wrt the rest frame of the meson is just the L value (not L_0)?
On the other hand... How far does anything move in its own "rest frame?" Isn't that 0?
hmmm , i don't get what you are pointing to .. but as i told you , since you are given the average lifetime(proper time) and the speed of the pi meson you can first get the time needed to calculate the distance you are asked to get .. and why you have to do so?
it is simply because you are now in a rest frame of the pi meson (say i.e this frame is the earth) and from that frame you have to calculate the distance which the pi mesons tranvels .. so what do you need ? you need to find the time with respect to the new frame .. does what i say makes sense now? .. try once again and tell me if you still have any questions ..
I agree with you. And your teacher did say it's a trick question.
No, the pi meson is moving with respect to the Earth, at 0.9c. The pi meson rest frame is not the Earth frame.
What is the velocity of anything, by definition, in it's own rest frame?
I apologize for confusion, and thanks Redbelly98 for clarifying this question ..
