Basic thermodynamics, reversible engine process
The discussion revolves around a thermodynamics problem involving a reversible engine process, specifically analyzing the work done in a cycle and the changes in internal energy across different stages of the process.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the classification of the processes (isobaric and isochoric) and the implications for work done in each segment of the cycle. Questions are raised about calculating the work done and changes in internal energy for each part of the cycle.
Some participants have provided guidance on calculating work and internal energy changes, while others have shared their attempts at finding values for pressure, volume, and temperature at various states. There is ongoing exploration of the relationships between these variables, but no consensus has been reached on the final answers.
Participants are working with specific values for pressure and volume, and there is an emphasis on using the ideal gas law. Some constraints include the need to express results in terms of given variables rather than numerical constants.
connorc234
http://i.imgur.com/jmLqca9.jpg
pic of question
W = p x dV, Q = dU + W etc
I know what the different stages are, a-b and c-d are isobaric, d-a and b-c are isochoric
and I believe the answer to a, the net work done in one cycle, is zero as dV is zero.
but the further questions I'm lost. can anyone help or point me in the right direction?
pic of question
The net work done is not zero. Let us go through each part step by step.
1, First, since the given values are p0, V0, we must find the values of pressure volume and temperature of each of the corner states, in terms of these values. Can you do that, and write them down?
pic of question
The net work is not zero. How much work is done from a to b? from b to c? from c to d? from d to a?
Continuing from there, you should first calculate the work done in each process in the cycle, and then add them to give you the answer to a. Let me know if you are comfortable with that.
ok i used pv=nRT taking R to be 8.31
p and V are known at all times so I just found the temperatures for each point.
a - pV/8.31
b - 3pV/8.31
c - pV/8.31
d - pV/24.93
then for the work since 2 are isochoric they are zero... the others
a-b W=2pV
c-d W= -2pv/3
adding them gives 4pV/3
is any of that right? haha
b to c and d to a both zero work since isochoric afaik
a to b W=2pV
c to d W= -2pV/3
This is all correct so far. In your equations for the temperatures, leave the R in (for now), instead of substituting the 8.31. Now, from your results for the temperatures, what is the change in internal energy ΔU from a to b? from b to c? from c to d? from d to a?
Chet
Chet
I appreciate your help, but I was able to complete the question by myself after you guys got me rolling. I'm fairly confident I got the right answers.
Thanks again, Connor
Excellent. Congratulations!
  • · Replies 22 ·
