The Role of Batteries in Electrical Circuits
The discussion centers on the role of batteries in electrical circuits, comparing them to pumps in hydronic systems. A battery provides energy to charge, with its electromotive force (emf) acting as a driving force for electron movement, akin to pressure in a fluid system. The battery is seen as a static energy accumulator, similar to an inflated balloon, while the generator is likened to a pump providing kinetic energy. It is clarified that while the battery does push electrons through the circuit, it also contributes energy to the flow. Additionally, the direction of electron flow is opposite to the conventional current direction, as electrons move from negative to positive while holes move in the opposite direction.
raddy59
I have a physics book that describes a battery in a circuit as like a pump that provided energy to the charge (e.g. a 1.5 volt battery gives 1.5 joules of energy to each coulomb of charge).
Am I right in assuming that the energy in a circuit is directly derived from the chemical/electrical energy generated by the battery?, Or does the battery provide the difference in emf that drives the movement of the charge?
maybe the "pump" analogy is giving me a wrong idea?
Just need to clear this up in my head 'cos I can't move on until I do
Electric circuits and their elements , and units are sometimes compared to hydronic systems. EMF = pressure, capacitor = membrane, ampere = l/sec etc The pump that provide kinetic energy, would be better compared to an electric generator. The battery, a static energy accumulator, would be better compared to an inflated air ballon.
Yuri
The battery - does it provide the power, or does it push the electrons through/around the circuit to operate the lights/heaters etc?
Hydronic e.g. - would the "batter", does it introduce water into the system or just push the water impulse)?
Because pressurised water cannot carry much energy (being incompressible), but air can (compressible), I take as example the inflated ballon. But both water and air behave as fluids - as well as electrons.
Emf is force (either in the generator, and in the battery) that forces electrons to move in a conductor. Pressure (either in the pump, and in the ballon) forces molecules to move in a pipe /duct.
Yuri
So the electrical energy generated in the battery - does it bring anything to the mix, or just provide impulse. Does it add to the flow of electricity through the circuit apart from a push?
Another point - is it true that the direction of electrons is opposite to the direction of the charge?
Thanks for your replies
The charge "pushes" and keeps going the flow of electrons as soon as there appears a circuit between the poles, and the more is the charge, the more electrons get involved in this process, named "electric current".
Electrons jump from the orbit of one atom to the orbit (the "hole") of a neigbouring atom. Electrons carry the negative charge, the holes carry the positive charge. It is used to say that the current moves from plus to minus, but actually, the electrons are swapping atomic orbits from minus to plus (it is the "holes" that keep moving from plus to minus)
I am afraid, however, nobody will ever see an electron - the idea of electric current is a (most) plosible one among the probably many others.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 58 ·
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 26 ·
