How Do You Calculate Beam Deflection for an I Beam on Lorry Trailers?
The discussion focuses on calculating beam deflection for an "I Beam" positioned across two lorry trailers under a uniformly distributed load. The beam is supported by simple supports, which resist vertical loads and are similar to roller supports, allowing for upward force application. It is confirmed that the bending moments at the ends of the beam are zero due to this support configuration, facilitating hand calculations for deflection analysis.
  • Understanding of beam mechanics and deflection principles
  • Familiarity with "I Beam" structural properties
  • Knowledge of support types in structural engineering, specifically simple and roller supports
  • Basic skills in performing hand calculations for beam deflection
  • Research beam deflection formulas for "I Beams" under uniformly distributed loads
  • Study the differences between simple supports and roller supports in structural analysis
  • Learn about calculating bending moments in beams
  • Explore software tools for structural analysis, such as SAP2000 or AutoCAD Structural Detailing
Structural engineers, civil engineering students, and professionals involved in the design and analysis of trailer support systems will benefit from this discussion.
Colin Thompson
Hello,
I am looking for some advice on calculating the beam deflection on a setup described below.
There is an "I Beam" sitting across the back of two lorry trailers with a uniformly distributed load in the middle of the beam.
I am slightly confused as to what type of support this would be if the beam is resting on the back of a flatbed to allow me to perform some hand calculations?
Any advice would be appreciated
Colin Thompson said:
Hello,
These are called simple supports, and assuming there is no friction to support lateral loads, they are similar to roller supports in that the simple support resists vertical loads, such that their forces act in one direction upward on the beam.
Doesn't this also mean that the bending moments are zero at the ends of the beam?
Yes
10K
