- 4
ThomasT said:Ok ...
Right, but P(A,B) won't be cos2Θ.
There will still be a statistical dependence between A and B if the (unentangled) counter-propagating disturbances have a common cause and the data are matched wrt this criterion. For example, where setup Q has (emitter - polarizer 1 - polarizer 2 - detector) on both sides, and polarizers 1 are aligned and the setting is changing rapidly and randomly so as to produce identical random polarization for each counter-propagating pair.
These are the only two settings wrt which you can predict B given A, and vice versa.
In the ideal, when Θ = 0 then P(A,B) = 1 (detection attributes for A and B are always identical), and when Θ = 90 degrees then P(A,B) = 0 (detection attributes for A and B are always opposite).
This is true even wrt an entangling source.
Actually, it is. To illustrate:
The polarizers at A and B are misaligned but not by 90 degrees. A has just registered a detection. Will B also register a detection wrt this pair or not?
None of what you are saying makes any sense .. in one breath you say that for entangled particles, the coincidence rate between A & B depends on cos2theta, and in the next breath you say that A & B are "completely random" for any choices of theta besides zero and pi/2. These statements are mutually contradictory. Of course I agree that except for those choices one cannot predict with certainty the outcome at B, given A. However, you can notice that the coincidence rate depends on theta, and that means that the results are not 'completely random". Look at it this way ... in my Alice & Bob example, if Bob used a type-II PDC for source P, and Alice measures compares measurements at theta=30º and theta=60º (theta here is the difference between the polarizer settings), then she will see coincidence rates of 25% and 75%, respectively. If he uses your randomly polarized example for source Q, Alice will see the same results for any value of theta.
Finally, it is a bit of a semantic point, but there is no way to get theta values of exactly zero and pi/2 experimentally .. there will always be at least a finite error. So by your argument, all of the A & B data sets in all the Bell test experiments ever carried out are "completely random" or "uncorrelated", or whatever you call it. Do you really believe that is true?
