Bell theorem loopholes and local realism
823 replies · 154K views
SpectraCat said:
Still, if ever I make it to Texas, I will look you up and buy you a couple brews, just to keep you quiet! :-p
That works for me... :biggrin:
SpectraCat said:
Heh! I haven't conceded that I actually lost those beers yet :wink: ... but I can only carry on so many arguments at one time ... I hope to pick up ours again later.
Better yet: Oktoberfest in Germany as the location of 'The First National XXVIIth Industrial Summit For The Regulation of Swatches' could be a place to discuss physics in addition to the nature of swatches, and swatch regulation. Perhaps the argument as to wheh a swatch becomes a SAMPLE could be seen as the line between the macroscopic and microscropic in physics? Maybe I haven't slept in over 36 hours and my brain is playing tricks on me? *plays kazoo; runs away* :smile:
SprectraCat said:
Just to be clear here, in a standard Bell test, *both* polarization components are measured at A and B. So, as long as you are not equating 0 with "no detection event", then I agree with your statement. What the value of 1/2 signifies to me is that, at detector A, a result of "H" is observed half the time, and "V" is observed for the other half of the events; they are never observed simultaneously. Here "H" and "V" refer to two orthogonal polarization directions.
In the tests (eg. Aspect '82) I was thinking of, the counter-propagating optical disturbances incident on the polarizers are assumed to have identical polarizations. A detection attribute of "0" means no detection. The probability 1/2 means that the rate of detection at A and B with polarizers in place is 1/2 the rate of detection at A and B without polarizers. (And, since we're considering an idealization, the value 1/2 means that for N counter-propagating pairs emitted it's expected that N/2 detections will be registered at A and N/2 detections at B.)
SpectraCat said:
... the cos2Θ relationship will not hold for unentangled particles.
It might. For example, consider the standard (a la Aspect) Bell test setup, then add a polarizer between the emitter and the polarizer on each side. Let the transmission axes of these two additional polarizers be always aligned and changing randomly. Now the counter-propagating disturbances transmitted by the first set of polarizers are identically polarized, but not entangled. Then the resulting angular dependency will still be cos2Θ, but the probability or normalized rate of joint detection will be .125(1-(2cos2Θ).
SpectraCat said:
What I have been saying is that for entangled particles, the likelihood of obtaining a coincidence between paired results at A and B depends in a predictable and non-random way on the relative choice of detection angles, which we have been calling Θ.
I guess we're on the same page then.
ThomasT said:
... due to the assumption of common properties imparted to counter-propagating disturbances via emission, then if the value of Θ is known to be 0 or π/2, then if the attribute at A is known then the attribute at B for the pair can be deduced (and vice versa).
SpectraCat said:
I would phrase this differently. I would say that, in any setup, one can attempt to make a prediction of a measurement result at detector B, based on the observed result at A and the relative detection angle Θ. In the case of entangled particles, one will find upon comparing paired measurements that the chance that their prediction was correct is either cos2Θ, or 1 - cos2Θ, depending on particular type of entanglement. (As you say, these values become 0 and 1 for the choices of Θ you have been focusing on.) In the case of unentangled particles, one would find that the chance of their prediction being correct is independent of the choice of Θ.
But please consider what happens in both of our pictures when we change Θ by an infinitesimal amount from one of these values (0 or π/2). In my case, the chance of the prediction being correct changes by an infinitesimal amount .. in your case the results become "completely random", to use your words.
I think my phrasing is pretty clear (and yours is somewhat confusing). Keep in mind that we're considering idealization of Bell test. What can be deduced about B given knowledge of A and Θ?
SpectraCat said:
I have said that I thought that such arguments make no sense for the reasons that we have been discussing. The whole Alice and Bob thought experiment I have devised is intended to show that the "inherent contradiction" you mention regarding the experimental design of Bell tests does not exist.
Let's try again. I'll ask some questions beginning with:
Do you understand that P(A,B) = P(A)P(B), the definition of statistical independence, is also the definition of Bell locality?
DrChinese said:
A poor reference indeed. You may as well be quoting yourself.
Whether it's poor or not, it serves its purpose. Indeed, why did I need this reference in the first place? Not to convince you, but to prove that I complied with the forum rules and did not push any personal theory.
Now let us ask ourselves what is exactly controversial in the Santos' quotes I offered? The first quote about the contradiction between the equations of QM and the theory of measurement of QM? But we don't need to believe Santos, as I offered other references confirming this. Furthermore, you yourself "freely admit" the measurement problem in QM. So I just don't quite see what's controversial about the first quote.
Second quote? It says that "standard proofs of ‘‘Bell’s theorem’’ rest upon the theory of measurement". But can we really say with a straight face that we can get the expression for the correlations in QM without the theory of measurement of QM? I don't think so. If you do, then how exactly can you get this expression? You cannot get it from UE, because it is very difficult to compute UE for the particles plus the measuring instruments. Nobody does that to prove Bell. And there is nothing in QM but UE and the theory of measurement. And, as I said, you cannot just use the Malus law until you prove it based exclusively on the postulates of QM (otherwise the correlations will not be based on QM, so it will not be proven that the Bell inequalities can be violated in QM). Furthermore, you cannot use the theory of measurement to prove the Malus law, otherwise the second Santos' quote will still stand.
DrChinese said:
Santos is a sad figure (in my personal opinion), whose grand contribution is to convince a few good people that "all loopholes should be closed simultaneously" (a questionable conclusion).
Then let me ask you again (I don't remember which time it is - my understanding is I have not heard your opinion on this point), what's exactly wrong with my Euclidean geometry "proof", if it's "questionable" that ALL assumptions of a theorem must be fulfilled simultaneously to ensure its conclusion stands?
DrChinese said:
His referenced result is not generally accepted any more than Santos' stochastic mechanics hypotheses, all of which have been soundly critiqued. Gosh, they were published too! You'll have to do a lot better than this.
I have proven with this reference that I did not offer any personal theory. Could you please indicate which Santos' quote you personally disagree? The first? The second? Both? Again, I offered other references confirming the first quote and I offered some arguments (in this and the previous posts) confirming the second one.
You cite sources because:
1.) you claim to have them
2.) Why should anyone care about a baseless opinion in THIS forum (try general)
3.) The rules are the rules.
Your "source" serves no purpose; it only goes to the argument that you're just filling pages with your baseless sophistry, now girded by the baseless sophistry of one other person. You constantly attempt to pivot on the question and keep the rhetoric going, but this is not the point of a PHYSICS forum. Cite a meanginful source, answer the questions you've been asked, or take DrChinese's advice and leave the thread if not physics as a whole.
EDIT: Using Santos, who has no personal or professional crediblity or gravitas, is as close as you come in rhetoric to using a real straw man. A real man, if not really made of straw :smile: . As Santos is not respectable, and you have freely aditted the "utility" of your citation the issue returns to your personal beleifs.
Aspect '82, while groundbreaking, is not up to date ... you no longer need to discard half the samples, as I pointed out in my post.
I don't understand this yet ... I will think about it some more and respond. I am pretty sure that this case should be distinguishable from true entanglement, but I don't quite see how (yet).
Great!
The probability of observing a coincident detection event within the experimental definition of such an event, as I have said.
I certainly agree that it is part of the definition ...
SpectraCat said:
Again, just to be clear, this is the case for an entangled source only ... the cos2Θ relationship will not hold for unentangled particles. If you use your earlier example of two independent, randomly polarized counter-propagating beams, then for *any* choice of measurement angles at A and B, you will observe P(A,B)=P(A)P(B)=1/4 (that is, paired detection events satisfying any particular choice of "H" and "V" at both A and B will be observed one quarter of the time).
It might be interesting to note that as it seems the same source that is used for generation of entangled pairs can be used to generate completely factorizable state i.e. P(A,B)=P(AH)P(BH)+P(AV)P(BV) that can be described using polarizator angles of Alice and Bob but can not be described using only relative angle.
akhmeteli said:
You see, I can live with nonlocality, no problem at all. I'm just curious: why should I?
Because there are many proofs that the world is nonlocal, even though none of these proofs is the Proof. (I hope you understand what I mean. If you don't, despite all the efforts of me and other contributors here, then I cannot find any new way to explain it to you.)
akhmeteli said:
... no experimental demonstration of violations of the genuine Bell inequalities.
But we do have experimental demonstration of what-you-would-call non-genuine Bell inequalities. These experimental results are easily explained by nonlocal QM (combined with some approximations, of course), but are very difficult to explain with local laws of physics. Perhaps not impossible, but very difficult.
akhmeteli said:
So we are left with no-go theorems, such as the Bell theorem. But if it uses approximations as assumptions, that opens a hole for locality. Is this hole wide enough or too narrow? I don't know. Do you?
I think it is the crucial question: Is this hole wide enough or too narrow? We do not have an exact measure of the wideness of this hole, but most physicists agree, even some of those you cited as a support of your views, that the hole seems rather narrow. So, if you ask me to estimate the likelyhoods that nature is nonlocal or local, my subjective estimate would be something like 99:1. What would be yours?
akhmeteli said:
You were very kind to call one of my ideas "interesting", and I am grateful to you, but that idea was based on a rigorous result. Actually, we all do what we can, not what we want.
With that I agree. But that idea cannot be applied to the real world without some approximations that make it non-rigorous. Which, for me, does not make your idea less interesting.
It looks like my opportunity to post at the forum is about to end. I feel hard-pressed, though, to (at least attempt to) close off as much as possible of what I have opened up.
Many posts ago, the first part of Bell's argument (in Bell's original paper) was summarized as follows:
Proposition 1: locality Λ PC Λ CF → local determinism ,
where
CF ≡ counterfactuality
and
PC ≡ perfect anti-correlation for equal settings .
The idea is that the above proposition can be joined to the second part of Bell's argument (in Bell's original paper) which can be summarized as:
Proposition 2: local determinism → D ,
where "D" is a certain condition (which turns out to be inconsistent with Quantum Mechanics).
So, there are two 'theorems', a weak one and a strong one:
Weak Theorem: local determinism → D ;
Strong Theorem: locality Λ PC Λ CF → D .
___________________
zonde said:
Let's say I too see this proposition as valid but not exhaustive ...
Zonde, it has been quite a while. ... But I see you are still around.
zonde said:
... (I would feel more comfortable if I somehow could make sure that all the abstract terms in this proposition have unambiguous meaning).
I see two distinct 'levels' at which one can work in order to establish the validity of "Proposition 1".
One of these levels, I call the "object-level". At the object-level, one analyzes the scenario in terms of outcomes and potential outcomes as they may (or may not) occur in the given physical situation.
However, at this level, the argument suffers from ambiguity due to a lack of clarity in the definition of its essential terms. Just look at the definitions of "locality" and "CF" which one has to work with. These definitions are expressed in terms of words of informal, ordinary language.
For "locality", we have Einstein's words:
The real factual situation of the system S2 is independent of what is done with the system S1, which is spatially separated from the former.
And what about "CF"? At the object-level, "CF" becomes none other than "CFD", that is, "counterfactual definiteness", which as Stapp (the conceiver of the notion) explains is:
For each particle on which a measurement is performed, a definite value would have been found if a different spin component had been measured on it instead (although we cannot know what the specific value would have been) and, furthermore, the complete set of such values (measured and unmeasured together) can be meaningfully discussed.
But there is another level at which one can work to establish the validity of "Proposition 1". I call it the "meta-level". Here, one analyzes the scenario in terms of the joint-probability-function as it would be calculated at the level of a physical theory. At this level, "locality" can be defined in unambiguous, mathematical terms (i.e. in terms of "Bell Locality", which I took a step towards defining back in post #239 (but I have not yet followed up on it)), while "CF" turns out to correspond to "the permissibility of exploring the causal structure of a physical theory".
___________________
zonde said:
I would say that PC is not a requirement for local determinism. So we can say: locality Λ CF → local determinism.
"Locality Λ CF" alone is not enough. As far as I can tell, "PC" is essential to the argument, in which case there is not even a substitute for it.
zonde said:
That's because PC is certain arrangement of things that applies to one situation but doesn't apply to other.
I can't tell what you're getting at here.
___________________
zonde said:
What I don't like about this theorem of QM is that it is placed as restriction on all possible LR theories even when this theorem is not experimentally verified.
Zonde ... you are starting to lose me. I would think that "PC" ought to be a feature of any theory. Is "PC" not just the expression of conservation of angular momentum for a system whose angular momentum was initially zero?
zonde said:
Let's say we can formulate LR theory that says:
a) If measurement of the component σ1∙a, where a is some unit vector, yields the value +1, then measurement of σ2∙a must yield the value -1 or no value at all at least half the time.
b) If measurement of the component σ1∙a, where a is some unit vector, yields the value +1, then low efficiency measurement of σ2∙a must yield the value -1 with very high probability and value +1 with very low probability or no value at all. But as measurement efficiency increases relative probability of +1 value increases rapidly.
Okay. ... Now I'm lost.
Eye_in_the_Sky said:
1) Do you believe you understand the concept expressed by the following statement?
Alice and Bob's outcomes are governed by local determinism.
2) Do you consider the following statement to be true?
On the basis of the single assumption of "local determinism of Alice and Bob's outcomes", one can derive a Bell inequality.
akhmeteli said:
I think so
I think so
How about this next statement, would you say that it is correct?
The assumption of "local determinism of Alice and Bob's outcomes" is independent of any assumptions concerning the truth or internal consistency of Quantum Mechanics.
akhmeteli said:
I think I disagree with this statement. Indeed, if QM is true and internally consistent, then the Bell inequalities can indeed be violated, so local determinism is eliminated. Therefore the assumption of local determinism does not seem to be independent of the assumptions of truth and consistency of quantum mechanics.
Thank you, akhmeteli, for answering my questions. Originally, it appeared to me that there may have been some misconception in the way you were thinking about Bell's Theorem. But from the answers you have given, I do not detect any such misconception.
Indeed, we both agree:
and
QM → ~D ,
where D is a certain condition.
So finally I am able to understand your position. Essentially, you are saying that the QM prediction of "~D" might be WRONG, and if so, then Bell's Theorem is of LITTLE significance.
But I think that even if this QM prediction did turn out to be wrong, Bell's Theorem would nonetheless be HIGHLY significant. It would still be telling us that two of THE MOST MAJOR world-views EVER to be found in the HISTORY of SCIENCE are FUNDAMENTALLY INCOMPATIBLE.
[The only remaining question (for me, at least) is whether or not one can derive the condition "D" from premises which are logically weaker than the premise of "local determinism" ... thereby strengthening Bell's Theorem.]
Hm
Imagine that QM is not discovered yet (but SR is discovered)
However, there are many EPR Alice/Bob experiments and tons of data
I was thinking that in that case it would be possible to rule out local theories, even without QM, just based on the experiments. AM I wrong?
Dmitry67 said:
Hm
Maybe... but you'd be creating QM based on the predictions you'd expect a given non-local theory to match. People would probably laugh you out of the room in the absence of QM too. Logically I see your point, but practically, not so much.
Ambiguity in this definition is that experiments are done with ensembles. SQM formalism refers to ensembles too. But in discussions single photons are used instead of ensembles.
So what leaves a doubt is if photons from ensemble at different times occupy the same place should this be treated as "locality" or not. But this is quite specific so I think it shouldn't cause problems in most cases.
That's clear. But does it mean that deterministic chaos is completely excluded by this definition?
It's hard to accept that deterministic chaos somehow contradicts local realism.
"Locality Λ CF" alone is not enough. As far as I can tell, "PC" is essential to the argument, in which case there is not even a substitute for it.I can't tell what you're getting at here.
"PC" is essential for Bell's argument but is it essential for local realism?
And how you define "PC"?
Say if light is linearly polarized and then it goes through polarizer with the same orientation of polarization axis as for light. All light is passing through polarizer - perfect measurement.
Now polarizator is oriented at different angle and measurement becomes probabilistic.
Are you saying that local realism requires that probability for individual photon can depend only from properties of photon and in no way from context?
Now if we have chaotic context that determines probability and say we include some controllable factor that contributes to context. Now the the outcome will become predictable but only marginally. We can not eliminate chaotic context we can only override it with controllable factors to some extent.
Therefore I say "PC" are not realistic.
This is no surprise that facts can be more easily explained using less restrictive rules than more restrictive rules.
Well if we talk about that I can explain anything using one rule - God wished it to be so. Are you satisfied with that explanation?
Why did you respond to a valid point with the ultimate in reductio ad absurdem?
All references are not equal, so please, you know better. Santos has been soundly plastered in his defence of LHV theories.
There is a measurement problem in QM, but it is not the kind of problem you imply. It is more of a theory scope issue. And it has nothing to do with Bell. As previously mentioned ad nauseum, if QM is wrong... so be it. But that does not change the fact that QM and LR are incompatible, which is the Bell result.
If you don't understand that QM IS CAPABLE of making predictions, then you haven't heard anything everyone has been telling you. I don't care what Santos said, he has a major ax to grind and wants to discredit any aspect of Bell, Bell tests, QM, etc. it takes in order to convince everyone he is "right" whatever that means. So far, he has been wrong about every single Bell experiment, has made zero correct predictions, and has added zero to our understanding of entanglement - a state he denies exists.
SpectraCat said:
Ok, so I think I finally understand why it has been to hard to understand your point of view here, at least in my case. You are actually challenging the foundations of the standard formulation of quantum mechanics, by attacking one of the core postulates. This is of course fine, but it would have been helpful if you constructed your arguments in that context from the beginning, rather than focusing on the Bell theorem, which is actually just collateral damage from your primary attack.
In truth, there is nothing wrong with Bell's theorem, because he simply takes for granted the postulates that are part and parcel of SQM ... that is what one is *supposed* to do with postulates, when working within a theoretical framework. On the other hand, you refuse to accept one of those postulates, as you have stated consistently from the beginning, and of course this is the really the only logical grounds on which to challenge an otherwise correct mathematical proof/derivation.
EDIT: As I said above, this is fine, but it is hardly mainstream in this case. While the "measurement problem" has been debated long and hard in quantum mechanics, I think most people would still concede that this has not so far proved to be a practical problem for either measurements, or for theoretical predictions derived from the accepted postulates.
Your challenges on the experimental side of things are also hard for me to accept, but as we have already realized, that is because I tend to accept the fair sampling assumption as valid, while you do not. We have each stated our case, and I guess neither has been convinced by the other ... we will simply have to wait for improved detection efficiencies to resolve this matter I guess.
So, while I tend to view your challenge to SQM as rather quixotic, who is to say that I am correct? All I can say is that the postulates of SQM have served us rather well to this point, and there are no clear-cut cases where they have been found to be false. Perhaps there is a point to be made that they are somehow self-contradictory, but so far that is not a widely held view. I have no problem "rationalizing away" the seeming contradiction that you raise, because the unitary evolution postulate pertains to the microscopic quantum system, whereas the measurement postulate pertains to the interaction of the quantum system with a macroscopic detector.
SpectraCat,
Thank you very much for a fair summary. While you disagree with me, it looks like you don't find this thread a waste of time anymore, and I am happy about that.
Unfortunately, I don't have time to reply to your specific comments right now. I'll try to do that later.
and
QM → ~D ,
Eye_in_the_Sky,
Thank you very much. I am happy that you understood my position.
And I fully agree that the Bell theorem is highly significant no matter what. It pushes standard quantum mechanics to the extreme (and I'd like to emphasize that what you wrote relates to standard quantum mechanics), and this is a great way to test a theory.
I think I understand what you mean. But then I may say that there are many proofs (rather than Proof) that the world is local, such as: the absence of signal nonlocality; microcausality in quantum field theory; the absence of experimental violations of the genuine Bell inequalities; holes in no-go theorems, and so on.
Fair enough. However, I mentioned the astonishing mathematical trick (published by other people) that makes nonlinear differential equations in 3+1 dimensions look like linear unitary evolution equations of quantum field theory in the Fock space. This mechanism suggests that the explanation may be easier than it seems. I'll try to e-mail you about a specific implementation of this mechanism
I cited those physicists just to support my view that LR has not been ruled out yet (I know that Shimony, Zeilinger, Genovese don't believe in LR at all, but that is why their honest assessment of the experimental situation is especially valuable), and, judging by your "subjective estimate", you agree that it has not, although you find LR highly unlikely.
As for my "subjective estimate", you see, on the one hand, I only have scientific basis to state that LR has not been ruled out, and I don't want to start a flame, but now that you ask, I admit that my "subjective estimate" is the inverse of yours. Again, I readily admit that I cannot support this estimate, so it's purely subjective. I fully agree that "We do not have an exact measure of the wideness of this hole". Furthermore, my estimate can change drastically in the future to reflect new experimental and theoretical developments.
Thank you very much. But you can be sure that, emphasizing the value of rigorous results, I had no intention to "offend" approximate approaches - of course, physics is impossible without them.
It leads me to another question.
Say, we found a mapping of our physical spacetime P and any system in it into some other (abstract) space A. There is 1:1 relationship between P and A.
If theory is nonlocal in P but local in A, would you call such theory local or not?
Example: We map surface into line, R2 into R1
Theory, which is local in R2 is non local in R1.
There is a whole thread devoted to this idea:
https://www.physicsforums.com/showthread.php?t=285019
Demystifier said:
Akhmeteli, I have no objections to your last post. It's fair enough.
Thank you very much!
You might say the signal locality is evidence of locality, but the rest of what you say is wrong - again. If you want to reject evidence that goes against your personal opinion, please do not label it as science. Just call it for what it is: a quasi-religious view.
There are in fact hundreds of experimental violations of "genuine" Bell Inequalities. There is no hole in the GHZ no-go. And how can a hole in a no-go theorem be evidence for locality anyway? That doesn't even make sense. Please explain how photons that are not - and have never been - in each other's light cones can become entangled. According to local realism, that should not be possible. I notice that no matter where this thread goes, you avoid these difficult questions, and resort to the weakest references as part of your hand waving.
The first set of polarizers unentangles, but polarizes identically, the counter-propagating disturbances
Factorability of the joint probability expression defines Bell locality.
akhmeteli said:
But then I may say that there are many proofs (rather than Proof) that the world is local, such as: ... the absence of experimental violations of the genuine Bell inequalities...
Just to demonstrate a specific example that this makes no sense. The below reference was submitted this week by a highly respected research group. It demonstrates nonlocality, see the title. Now, according to your thinking, this is actually evidence of locality rather than non-locality as it states. Are you following any of this, or am I wasting my time? I don't expect you to change your position, rather to simply stop writing what has already been refuted here.
http://arxiv.org/abs/1003.0432
Testing nonlocality over 12.4 km of underground fiber with universal time-bin qubit analyzers
Felix Bussieres, Joshua A. Slater,Jeongwan Jin, Nicolas Godbout, and Wolfgang Tittel
(Dated: March 1, 2010)
"We experimentally demonstrate that the nonlocal nature of time-bin entangled photonic qubits persists when one or two qubits of the pair are converted to polarization qubits. This is possible by implementing a novel Universal Time-Bin Qubit Analyzer (UTBA), which, for the First time, allows analyzing time-bin qubits in any basis. We reveal the nonlocal nature of the emitted light by violating the Clauser-Horne-Shimony-Holt inequality with measurement bases exploring all the dimensions of the Bloch sphere. Moreover, we conducted experiments where one qubit is transmitted over a 12.4 km underground fiber link and demonstrate the suitability of our scheme for use in a real-world setting. The resulting entanglement can also be interpreted as hybrid entanglement between different types of degrees of freedom of two physical systems, which could prove useful in large scale, heterogeneous quantum networks. This work opens new possibilities for testing nonlocality and for implementing new quantum communication protocols with time-bin entanglement."
I don't think that is an accurate description, not without some additional qualifying statements. In fact, I am not sure it is right ... how can you be so sure that the first set of polarizers breaks the entanglement? It certainly seems logical, but is there an experimental result confirming this? I originally thought as you did for this case, but I started looking for experimental verification, and it all seemed ambiguous. As far as I can tell, the only thing that can be said for sure is that detection of one member of an entangled pair breaks the entangled state, and I don't think it has been proven that interaction with a polarizer is the same as detection. (Actually, I would be happy if the polarizer interactions were proven to be equivalent to detection, because it would drastically strengthen my position in an argument with DrChinese that I have been having in another thread!)
Having said that, let's assume that you are correct, and the first set of polarizers does break the entanglement. In that case, the first set of polarizers will completely block all coincidence measurements if the source is the typical choice of a type-II PDC, which generates HV-VH type entanglement (Bell state). As you can see, if the entangled state is disrupted by the first set of polarizers, only one of the counter-propagating photons will be transmitted (although we don't know which one); the other will be blocked with 100% efficiency. For HH+VV type entanglement (which is not what is used in typical Aspect-style experiments), you would get 100% transmission in both directions ... I guess this is what you are talking about?
Now, the latter case means that both photons acquire a fixed polarization angle [tex]\phi[/tex] relative to the lab frame. The detection probabilities are now dependent on the detection angles at A and B relative to the lab frame, call these [tex]\theta_{A}[/tex] and [tex]\theta_{B}[/tex]. So, for any single measurement, the individual probabilities of detection events at A and B are given by Malus's law as:
[tex]cos^{2}\left(\phi-\theta_{A}\right)[/tex] and [tex]cos^{2}\left(\phi-\theta_{B}\right)[/tex]
So the probability of a coincidence is given by:
[tex]cos^{2}\left(\phi-\theta_{A}\right)cos^{2}\left(\phi-\theta_{B}\right)=\frac{1}{4}\left\{2cos^{2}\left(\phi-\theta_{A}\right)+2cos^{2}\left(\phi-\theta_{B}\right)+cos^{2}\left(\theta_{A}-\theta_{B}\right)+cos^{2}\left(2\phi-\theta_{A}-\theta_{B}\right)-2\right\}[/tex]
Now, I believe that your construction also had the angle [tex]\phi[/tex] as random and variable throughout the experiment, so that means that for a large sample size, Alice's observations will amount to integration of the above expression over all possible values of [tex]\phi[/tex], which yields:
[tex]\frac{1}{4}\int^{2\pi}_{0}\frac{d\phi}{2\pi}\left\{2cos^{2}\left(\phi-\theta_{A}\right)+2cos^{2}\left(\phi-\theta_{B}\right)+cos^{2}\left(\theta_{A}-\theta_{B}\right)+cos^{2}\left(2\phi-\theta_{A}-\theta_{B}\right)-2\right\}=\frac{\left[2cos^{2}\left(\theta_{A}-\theta_{B}\right)+1\right]}{8}[/tex]
EDIT: I just noticed that you also give this same expression in an earlier post, so it looks like we are both approaching the problem the same way. Still, my conclusion seems different than yours ...
So, while this expression contains the cos2theta term (theta being the relative angle, or thetaA-thetaB), it is not equal to it. Most importantly, this expression never goes to zero for any choice of theta. So as I hypothesized, there will still be a measurable difference between the entangled and unentangled cases, even with your more elaborate unentangled source.
Ok, I'll accept that if it moves things forward.
DrChinese said:
What is wrong with you?
1. Bell points out about perfect correlations, which is also present in EPR. This does not require any further discussion, it is an experimental fact and accepted by all: entangled particles exhibit this, and no assumption is required.
I am not quite sure what you're trying to say and don't want to guess. Care to explain?
DrChinese said:
UE and PP are irrelevant to Bell, and I challenge you to produce a reference otherwise.
I gave you the reference. I gave you the arguments indicating you need UE and PP or something like that to obtain the QM correlations in the Bell theorem. You don't like the author of the reference. You don't want to discuss his quotes or my arguments. I certainly can live with that.
DrChinese said:
2. Do you not read anything I (or anyone else) says? I said that QM predicts the cos^2(theta) relationship for entangled particles. It does not predict otherwise.
I reject this last statement ("it does not predict otherwise"). This is what the QM theory of measurement predicts. QM unitary evolution predicts something different: according to UE, there is no irreversibility, so no measurement is ever final. Thus, QM predicts at least two different things, not one, for the same phenomenon.
DrChinese said:
So who cares how that is arrived at if you think QM is wrong (an embarassing position by the way)?
People care. Not everybody is as flexible as you with logic to "freely admit" problems with QM theory of measurements and express indignation when somebody says that standard QM is, strictly speaking, wrong. I am not the only one who wants to know exactly what is right in QM and what is wrong. When people rigorously show that QM theory of measurement is just an approximate consequence of UE, it matters, because we then know that we cannot trust QM theory of measurement 100%, as you seem to do (while "freely admitting" problems with it :-( )
DrChinese said:
Bell says QM conflicts with LR, really, how hard is that for you to understand? It is absurd to repeat the same statements over and over in post after post.
I do understand that standard QM conflicts with LR. I repeat, I do understand that. What I am trying to explain is: standard QM conflicts with itself as well, so LR does not have more problems than standard QM itself.
DrChinese said:
You don't have to agree with QM to know this is the prediction and there is no other (if so, what is it?).
I agree this is a prediction of standard QM. And I disagree, there is other prediction based on UE only. I cannot rewrite the results of Allahverdyan's articles here or rederive them for any experimental setup you may wish to "challenge" me with to tell you "what is it"- the "other" prediction.
DrChinese said:
You don't have to be a genius to figure out that LR must respect Bell's Inequality once Bell's Theorem is considered.
Again, I agree, LR must respect the (genuine) Bell inequalities.
DrChinese said:
And that is different than QM.
And I question this. You can only prove that using both UE and QM theory of measurement, which contradict each other. Therefore, you can only state that LR cannot reproduce ALL predictions of QM - this is your phrase. But as long as S(tandard) QM contains mutually contradictory elements, this inability to reproduce all predictions of an internally inconsistent theory is not a problem of LR, but a problem of SQM
DrChinese said:
3. Again, reference please.
Again, I gave you a reference. I gave you the arguments. You don't like them and don't care to discuss? Fine with me.
DrChinese said:
4. nightlight? You must be kidding, right? He never said this that I recall.
He questioned that the Bell inequalities can be violated in QM, unless you use PP, which he rejected. He quoted Kowalski's results to suggest that linear equations of UE in Hilbert space can be a disguise for nonlinear differential equations in 3+1 dimensions. So, again, I mostly follow his reasoning.
DrChinese said:
And I disagreed with almost everything he said. nightlight is a diehard local realist who ignores Bell test results and disagreed with Bell, as I recall.
I did not say you praised his posts:-)
DrChinese said:
But never did I hear a comment that QM was "wrong" because of mutually contradictory elements. But perhaps you can correct me on that point, I would welcome that.
You did not hear that from nightlight or from anybody? I am not sure about nightlight. But I gave you other references to the contradiction between UE and QM theory of measurement, and you seem to agree there are problems in this area.
DrChinese said:
5. Laughable! You completely mischaracterize the nature of Zeilinger et al's position on loopholes by quoting out of context. It is true that Zeilinger would like to see a "loophole-free" demonstration of a Bell test, but that is for significantly different reasons than you describe. Zeilinger has already ruled out local realism in numerous OTHER experiments, need I re-reference these? GHZ is a good starter, and there are plenty of others. So it is not about LR being viable or not to him!
I fully agree that Zeilinger is no fan of LR. As for my "quoting out of context"... Look, with all due respect, I am not going to learn Zeilinger's articles by heart or look for a quote confirming YOUR point of view - that would be really rich. So I gave you a quote. You want to prove that Zeilinger believes LR has been ruled out by experiments - give me a direct quote with such claim, and we'll discuss it, don't give me a reference to a dozen articles where I am supposed to find confirmation of your point of view.
DrChinese said:
Further: the measurement problem - which I acknowledge freely - is hardly a flaw in QM. May as well say GR is wrong too at a singularity because of division by zero.
Look, I know next to nothing about GR, but it is my understanding the singularity is regarded as an indication that GR will be corrected in this point by a future theory. Wouldn't it be natural to think that same logic is in order for QM?
DrChinese said:
You clearly like to turn back the clock hands with meaningless semantic diversions. How about a little useful science to go with your words? Noone - least of all me - claims QM answers all questions about all things. I think the same conclusion is in order where there is a c It is a model, and it is a very useful one. You have only to lay on the table a model that matches and exceeds it to get my attention. Short of that, you are nothing but HOT AIR.
If I suggested that you do a little useful science and support YOUR hot air with a loophole-less experimental demonstration of violations of the Bell inequalities, I guess you would call my suggestion "empty rhetoric", although you seem to be sure we'll live long enough to see such a demonstration. Why should not I apply this term to your suggestion?
Is it possible to say that LR is ruled out experimentally and ignore all agruments about internal problems in QM?
It is possible, but not with absolute certainty. This is because the detectors have a very low efficiency, so the experimental statistics refers to a very small sample of actual particles. In principle, it is possible that this small sample is not a typical sample, but a sample with very special properties, making the illusion of violation of Bell inequalities. Nobody knows a good reason why this sample would not be a typical one, yet such a possibility in principle exists.
This is like president elections. Before the actual counting of all votes, usually there is a preliminary counting of a small sample of all votes. Usually it is a good representative of all the votes, yet the victory of one president candidate over the other cannot be proclaimed before the actual counting of all (or at least of the majority of all) votes.
Akhmetely is like a president candidate who believes that he will win the elections even though all statistics on small samples say the opposite. It's true, such a president candidate may still win, but statistically it is very unlikely.
