Bell's Theorem and Counterfactual Definiteness
In summary, despite what some may argue, Bell's Theorem and Aspect's experiments do not definitively prove that quantum theory is nonlocal. The violation of Bell's inequalities only shows that theories that are both local and realistic cannot be correct. The concept of "counterfactual definiteness" refers to the ability to speak meaningfully about the definiteness of measurement results, even if they were not actually performed. There is some debate about whether quantum theory is truly nonlocal or if we just need to abandon certain assumptions, such as "counterfactual definiteness," in order to reconcile it with locality. Ultimately, the issue may come down to personal beliefs and interpretations.
Jolb
419
29
Bell's Theorem and "Counterfactual Definiteness"
Bell's Theorem and Aspect's experiments pretty much show that quantum theory is nonlocal--the violation of Bell's inequalities show that somehow the wavefunction is acting on the entangled particles faster than c.
However, I've heard that Bell's inequalities violate either locality or "counterfactual definiteness."
Now I'm very confused about what that means. Is that complete garbage or is there some possibility that quantum theory is local and we just need to abandon "counterfactual definiteness" instead? I thought quantum theory was already counterfactually non-definite, being as though you can't simultaneously measure complementary properties (like position and momentum) due to the Heisenburg uncertainty principle.
What does "counterfactual definiteness" mean in that context?
Actually, I thought Bell's theorem at best showed that a hidden variable theory which reproduced the results of QM would be non-local.
I was under the impression that QM, as it stands, is compatible with locality - though there are some difficult issues about whether all interpretations of QM (in particular those with wave function collapse) are indeed non-local
No, it shows that theories that are both local and realistic can not be correct.
I am pretty sure that "counterfactual definiteness" refers to what is commonly knowns as "realism", realistic theories/interpretations basically assume that objects exist and have properties even when they are not measured.
Hence, a violation of Bell's inequality is still compatible with local theories, as long as you give up realism. Of course it is also compatible with non-local, non-realistic theories (which some claim are supported by experiments)
Accepting the Wikipedia version of "counterfactual definiteness," this sounds correct. http://en.wikipedia.org/wiki/Counterfactual_definiteness:
In some interpretations of quantum mechanics, counterfactual definiteness (CFD) is the ability to speak meaningfully about the definiteness of the results of measurements, even if they were not performed.[1]
Compare this to the EPR criterion for reality, which is most likely where we get the physics/QM version of the term "realism" from:
If, without in any way disturbing a system, we can predict with certainty (i.e., with probability equal to unity) the value of a physical quantity, then there exists an element of reality corresponding to that quantity.
The two are equivalent because taking an actual measurement would disturb the system. To meet the EPR criterion, you must be able to speak about what the result of a measurement definitely would be if it were taken - you need counterfactual definiteness. Of course, actual reality may not necessarily conform to Einstein's view of what realism is, so be careful not to read too much into the terminology. Everyone thinks that the job of physics is to describe reality, or at least to model it as best as possible, even those who deny "realism."
Alll of the above replies are correct, as is your viewpoint. The issue is the language more than anything. Some people don't like the term "realism" and prefer "counterfactual definiteness" instead. You could use the term "Is the moon there when no one is looking" and get the same effect (Einstein used this analogy). Any way you describe it, it has 3 characteristics: a) the specific observable is NOT measured; and b) it should have a specific value; and c) the probability of it having that value should be between 0 and 1.
A lot of people assume QM must be non-local because of Bell; however, as you point out, simply accepting reality as matching the HUP avoids having to discard locality. Most folks think these positions are a matter or personal choice.
No, they don't show this.
The locality condition (manifested as factorability of joint, entangled state representation) in Bell-type lhv formulations contradicts the statistical dependence between the separated data accumulations. However, this statistical dependence (which is a necessary byproduct of the pairing process) is entirely due to local transmissions/interactions vis, eg., coincidence circuitry.
The Bell locality condition is also incompatible with standard qm formulation (not factorable, nonseparable) of joint, entangled state.
But this doesn't make standard qm a nonlocal theory any more than violations of Bell-type inequalities indicate that Nature is nonlocal.
What is Bell's Theorem?
Bell's Theorem is a fundamental concept in quantum mechanics that states that no physical theory can reproduce all of the predictions of quantum mechanics while also satisfying certain reasonable assumptions about the nature of reality. In simpler terms, it shows that quantum mechanics cannot be explained by local hidden variables, and therefore, the nature of reality is inherently probabilistic.
What is Counterfactual Definiteness?
Counterfactual Definiteness is a concept that refers to the idea that all physical properties of a system have definite values, even if they are not measured or observed. This concept is often used in discussions about Bell's Theorem, as it is one of the assumptions that is violated in quantum mechanics.
Why is Bell's Theorem important?
Bell's Theorem is important because it provides a fundamental understanding of the nature of reality and the limitations of classical physics to explain quantum phenomena. It has also been experimentally verified, which further solidifies its importance in the scientific community.
What is an example of a Bell's Theorem experiment?
One example of a Bell's Theorem experiment is the Bell test, which involves measuring the correlations between entangled particles that have been separated over a large distance. These correlations cannot be explained by local hidden variables, thus supporting the predictions of quantum mechanics.
How does Bell's Theorem relate to the Einstein-Podolsky-Rosen (EPR) paradox?
Bell's Theorem is closely related to the EPR paradox, as it addresses the same fundamental question about the nature of reality and the limits of classical physics. The EPR paradox was proposed as a thought experiment to challenge the validity of quantum mechanics, and Bell's Theorem provides a mathematical proof that supports the predictions of quantum mechanics over classical physics.
  • Quantum Physics
18K
  • Quantum Physics
