Bemoulli equation ( flow in pipe)
  • Thread starter Thread starter donniemateno
    Flow Pipe
3 replies · 4K views
donniemateno
the bemoulli equation states that the energy per unit weight for a frictionless slow is constant.
water at:
30degree c = 0.801kgm-1s-1
80degree c = 0.357kgm-1s-1
Radiator 15kw
delta T= 5degree c
cp = 4.2kj/kgk
pipe diameter 40mm
is the flow in the pipe laminar or turbulent at 30 and 80 degree respectively
what are the friction factors?
i have the followin equation.
reynolds number = velocity of fluid x density x diameter of pipe divided by viscosity of fluid.
so i have 5x4.2x0.40 divided by0.801 = 10.48for 30
and 5x4.2x0.4 divided by 0.357= 23.53for 80
have i gone completely wrong as i was taught anything over 2000 is turbulant flow and anything under 2000 was laminar
I learned 2300 whas the dividing line but 2000 might just be another good guide value.
From what I see in your calculation of the Reynolds number you seem to have multiplied 5 C * 4.2 kJ/kg*K to calculate the fluid flow in meters/sec ? Check the units
15 x 0.801 x 0.4 divided by 4.2 = 1.144?
just using my formula the first part is the velocity of the fluid. i havnt been given this. do i rearange the formula or??
You have inserted 4.2 of what excatly for the density? Please refer to Wiki for a proper definition of the dimensionless Re-number.
In units: (m/sec * kg/m^3 * m) / (kg/m*sec) = kg*m/sec / (kg/m*sec) = [-] unitless
Check your answer using this type of units control.
