Best rocket-stopping method
  • Thread starter Thread starter Rocket Maker
    Method Rocket
The discussion revolves around methods for stopping a model rocket during its ascent without using reverse propulsion. Participants explore various techniques, including mechanical and aerodynamic solutions, as well as considerations related to competition rules.
  • Homework-related
  • Some participants suggest using a tether cable to stop the rocket, with one proposing a fishing line mechanism that plays out from a spool.
  • Others propose using an inverted parachute or high drag air brakes that deploy from the sides of the rocket.
  • Concerns are raised about the practicality and cost of lightweight servos needed for deploying air brakes.
  • One participant mentions that air drag could assist in deploying brakes if designed correctly, but warns of potential destructiveness.
  • Another participant discusses the rules of the American rocketry competition, questioning the necessity of stopping the rocket mid-flight to meet duration and altitude targets.
  • Some participants emphasize the importance of designing the payload and booster sections carefully to meet competition constraints.
  • A unique idea is presented involving the use of an airbag from a vehicle to create a drag effect, with considerations about the dynamics of combustion gases and fabric tension.
Participants express a range of ideas and methods without reaching a consensus. There are multiple competing views on the best approach to stopping the rocket, and the discussion remains unresolved regarding the most effective method.
Participants note potential violations of competition rules regarding externally generated signals, and some ideas may depend on specific interpretations of the rules or practical feasibility.
Individuals interested in model rocketry, particularly those participating in competitions or exploring innovative stopping mechanisms for rockets.
  • #31
They run until empty.
You can, however, select how long they run when you buy them. This is one reason I advised the OP to fly a lot of rockets,
  • #32
You generally have several options in a given “class” of motor to tune your performance.
Most of these motors are black powder derivative fuel grains that are pressed inside the cardboard body tube of the motor and use an end-burning design.
And the burn time is usually no more than 2-3 seconds even on the big motors. Tuning rocket apogee height will be much easier by adjusting the weight, not the motor.
  • #33
Thank you for all of the suggestions.
Vanadium 50 said:
@Rocket Maker you need to be a lot more forhcoming - peope are trying to help you and you're only willing to type terse, nearly information free answers.
I don't see how stopping a rocket in flight will help you reach altitude or duration goals. You should start by explaining that before moving on to the how.
The altitude goal is we lose one point for every foot we go over 790 feet, so this is why I am asking and for the time limit the faster we can start going back down the better because we have to up and down within 44 seconds.
I have been flying Estes rocket kits so I have been using mostly C6-5s with the Riptide rocket kit.
  • #34
Flyboy said:
... must have sufficient inside diameter to hold an egg of up to 60mm length sideways ...
I wonder why the egg must be put in "sideways". It definitely doesn't help with keeping the center of mass on the axis.
  • #35
It just says there needs to be space to hold it sideways. no?
Anyway, if you want less altitude, a sudden stop is bad for the egg. Better to use a smaller engine. One could also add weight.
So, what is the variation in height for "identical" launches? Seems you would want to know that.
  • #36
For flights on the same day, I think the biggest driver in different apogees will probably be the motors. They’re cheap and simple, but there’s going to be some minor variation. Shouldn’t be too much of a difference in apogee, though. Bit of a wild-ass guess, but at that height and weight of the rocket… +/-10-15 feet, tops? Not sure if production batches are labeled, but getting motors from the same batch would be my suggestion for matching performance.
That said, differences in temperature, humidity, altitude, and wind will absolutely make changes to the rocket performance and will need to be accounted for.
  • #37
Quick comparison:
* Accelerate quickly to 70 m/s, then be in free fall to reach 241 m: 7 seconds
* Accelerate quickly to 100 m/s, then be in free fall to reach 241 m: 2.8 seconds but you reach that altitude at 70 m/s that you now need to cancel.
(neglecting drag in both cases here)
There isn't much time you can save on ascent. Deploying a parachute while still ascending could give you better control over the altitude, however.
  • #38
The point is not for us to lecture him. The point is for him to get out there measuring sruff so he can see what influences what and by how much.
  • #39
Honestly, there is a simple solution. You want the rocket on the ground sooner? Open the chute later,
Obviously, there are limits.
  • #40
It sure seems like stopping in midair is a lot harder (more complex, less reliable) than selecting the right size engine for the mass of your rocket.
The hard part of that is knowing what the thrust profile of model rocket engines is, but I bet someone has measured that.
  • #41
The manufacturer has a sheet.
  • #42
Thank you for all of the suggestions I will be talking with my team and looking through the thrust profiles of different rockets.
  • #43
Sure, but how repeatable is it? And at what level of detail?
  • #44
It looks like they do get fairly detailed in the specs.
  • #45
Yeah, that's pretty nice. I wonder if they would give you the actual data so you could use it in a numerical model. If so, you could get a pretty decently accurate estimate of altitude based on a pretty simple ##\sum F = ma## model that incorporates thrust and drag in real time. Just tweak the overall mass until you get the height you want. The issue would be repeatability of the motor, i.e., what's the uncertainty band on those curves?
  • #46
Which is why I friggin' asked him. Lordy.
  • · Replies 21 ·
  • · Replies 18 ·
