Best shape to flip or spin in Water?
  • Thread starter Thread starter society
    Shape Spin Water
The discussion revolves around finding an optimal shape that can spin or flip in water solely under the influence of gravity, with the goal of evenly distributing a dye or ink throughout the fluid. Participants explore various shapes and concepts, considering factors such as density, buoyancy, and the mechanics of fluid dynamics.
  • One participant has experimented with various shapes, including maple seeds and propellers, but has not achieved the desired spinning or flipping effect.
  • Another participant suggests using an external magnetic field to assist with flipping, but this is not permissible in the context of the project.
  • A participant proposes the idea of using a shape that releases gas, like CO2, to enhance movement and dye distribution in the water.
  • There is a suggestion to embed spring shapes within the dye tablet to create agitation as it dissolves, potentially aiding in dye distribution.
  • One participant considers the feasibility of a pellet with increasing density towards the center, which could float initially and then sink as it dissolves, although concerns about manufacturing consistency are raised.
  • Another participant proposes a saw blade-like shape with holes to create a low-pressure area that could draw in liquid, enhancing dye distribution.
  • Discussion includes the idea of a pinwheel shape as a modification of a propeller to optimize the spinning effect.
  • A humorous suggestion is made about genetically engineering sea-monkeys to excrete dye, highlighting the creative and playful nature of the brainstorming process.
Participants express a range of ideas and hypotheses, but there is no consensus on the ideal shape or method to achieve the desired effect. Multiple competing views and suggestions remain unresolved.
Participants acknowledge limitations in controlling density and weight of the dye tablet, as well as the variability of liquid conditions, which complicates the design process.
society
So I'm not sure if this is the right place - and its a crazy question - but I am trying to get something to spin and/or flip when I put it in a beaker of water, just by its own weight and gravity. I have tried a maple seed shape, propeller shapes, simple curls, sprials, Rocchetti pasta shapes, but they all don't spin or flip fast enough. Does anyone out here know what the ideal shape would be? I know that the density will be an issue relative to the mass? But aside from that I need to know were to start , before trying to dial in the variables. Any ideas? By the way, a propeller type shape worked well but only with 4 blades and above. I have not been able to get anything to flip end over end yet. Any ideas?
It has to be quite small , like say the size of a penny or a dime.
-Cheers.
-Cheers.
Can you use an external field, like a magnetic field to flip it at some depth? Can you post more details about the overall problem? An inverted dart will flip at some depth...
I can't use any external forces. Only gravity and the shape. I can't get too specific about the project, but the basic premise is that I need to release a dye/ink in fluid , in such a way that it will give the best overall consistent color throughout. So I was going to apply a water soluble colored coating to a shape which spins or flips at a controlled rate and the act of spinning or flipping will allow the coating to be released throughout the whole body of water consistently before landing at the bottom. Make sense? In other words, if I just drop a tablet into a beeker of water, the dye will primarily collect/release at the bottom of the beaker, and not throughout the whole volume. Unfortunately, I don't have the luxury of changing the density or weight of the tablet too much, or even adding other compounds to make it disolve faster etc... so the shape is the only way I could think to control the fall.
-thanks
-thanks
Can you use something that releases CO2 or some other gas mixed in with the dye tablet? The bubbling action should help the solid dye to dissolve more evenly. Maybe even something like a little rocket-shaped tablet, with the CO2 bubbling out of one end to make the tablet move around in the liquid...
Alternately, you could embed some spring shapes in the solid tablet, so that as it starts to dissolve, different parts of the spring are released, causing agitation of the liquid and better disolving of the dye.
I have an assumption, but I'd better check to be sure. This is something to be mass produced in huge quantities, right? That would mean that it has to be as simple and cheap as possible to manufacture.
There's an idea tickling around in the back left corner of my brain, but I don't think that it'll work. I'm going to throw it out there anyhow, just in case. If it does work, you could just use the dye without a carrier shape.
What I'm thinking of is forming the pellet with increasing density toward the centre, with the outer layer having enough buoyancy to float the thing. As the pellet dissolves, it would gradually sink as that buoyancy decreases. Any hope for that?
Thats nice! But yes you are correct in the mass production assumption. It would be quite hard to control the density to achieve that level of accuracy, also because the liquid will change slightly between use cases. This is one reason that I was trying to use a carrier. My hope was that the carrier Shape could be controlled easier than the carrier material - relative to the liquid conditions.
But I like your thinking! That hadn't crossed my mind yet.
I see. Hmmm... I'm going to go think on this some more.
That sounds like a pretty ingenious approach, Claws. Multiple outlet points would certainly increase the distribution. I never considered that.
My thought before seeing that was to suggest trying various pitches on the 'propeller' shapes to optimize sink rate vs. rotation, but I like yours better.
Wow! Moonbear showing up here just gave me another idea, since she's a biologist. You could genetically engineer sea-monkeys to excrete dye...
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 17 ·
