Better way of finding particular integral
  • Thread starter Thread starter Zell2
    Integral
To find the particular integral for the differential equation y'' + ay' + k^2*y = A cos(bx) sin(cx), the right-hand side can be rewritten as a sum of sine functions, but this leads to complex algebra with multiple terms. The two main methods for finding a particular solution are undetermined coefficients and variation of parameters. Undetermined coefficients require the right side to be a function type solvable by linear equations, while variation of parameters can handle any right-hand side but is often messier. An alternative approach involves assuming a solution form like B cos(bx) sin(cx), which also introduces additional terms upon differentiation. Ultimately, both methods will yield multiple components, and the choice of approach may depend on which form simplifies the problem best.
Zell2
I'm trying to find the particular integral for a second order linear differential equation:
y''+ay'+k^2*y=Acos(bx)sin(cx)
given a<<c and b<<c
It's straight forward to rewrite the right hand side as the sum of two sines, consider each seperately and then add the solutions since it's linear, but this leads to 4 separate terms and the algebra's a bit messy. So I was just wondering is there a better way to deal with products of functions on the right hand side?
Thanks
No there isn't. There are, basically, two ways to find a particular solution for a nonhomogeneous linear equation: undetermined coefficients and variation of parameters. In order to use undetermined coefficients, it is necessary that the right hand side be one of the types of functions one can get as a solution to a linear equation with constant coefficients, exponential, polynomial, sine or cosine, or products of those. In order to use that for this problem you have to do just as you say here: write sin(x) cos(x) as a sum. Variation of Parameters works for any right hand side but is typically much messier.
You could slice and dice some other ways, but you will finish up with 4 parts however you go.
For example you could start by assuming the solution was of the form B cos(bx) sin(cx) (B is an unknown constant) since you obviously need that for the "...+k^2y = A cos(bx)sin(cx)" part of the equation. When you differentite you'll find you also need terms like sin(bx)sin(cx), sin(bx)cos(cx), cos(bx)cos(cx)
Or you could use exponential functions with 4 terms like e^i(b+c)x, e^i(b-c)x, etc.
Take your pick - one form may be nicer than the others for the rest of your problem.
Thank you,
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
