How Does Static Friction Affect Bicycle Acceleration?
The discussion revolves around the effects of static friction on the acceleration of a bicycle on level ground. Participants are examining the forces acting on the bike and rider, particularly focusing on the role of static friction in maximizing forward acceleration without slipping.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants are discussing the components of a free body diagram, including weight, normal force, and frictional forces. There are questions about the dependency of static friction on the weight distribution between the wheels during acceleration and how the center of gravity shifts.
The discussion is active, with participants seeking clarification on their interpretations of the free body diagram and the calculations related to frictional forces. Some guidance has been provided regarding the inclusion of propulsion forces and the total mass in calculations, but no consensus has been reached on all aspects of the problem.
Participants are operating under the assumption of a 50/50 weight distribution when not accelerating, and there is an acknowledgment of the complexity introduced by the shifting center of gravity during acceleration. The discussion also touches on the implications of rolling friction being negligible.
7.11brown
Consider a biker riding on level ground as shown. She wants to have the maximum forward acceleration possible, which means experiencing the maximum horizontal force without her wheels slipping. Draw the free body diagram for the bike accelerating forward.
F=ma
kinetic friction is zero
there would be weight going down from each wheel (dependent on the balance of the rider), a Normal Force from each going up, rolling friction on the front wheel and static friction in the direction of acceleration on the rear wheel
Is that correct? Would the force of static friction only be dependent on the weight the rider puts on the rear wheel?
The force of friction would also depend on how much the center of gravity shifts to the rear when she accelerates. For example suppose when not accelerating the bike/rider has a 50/50weight distribution. But when it accelerates, the CG shifts rearward which increases the weight on the rear wheel. It could then be 60/40 or some other ratio.
Just to make sure, my description of the free body diagram looked correct? If so, when calculating the frictional force, it would just be equal to the y component of weight on the rear wheel (assuming rolling friction is negligible.)? We are assuming a 50/50 weight distribution.
When using F=ma to find the acceleration of the bike and rider, would that mass be equal to the total mass since that is what is accelerating?
Thanks
"there would be weight going down from each wheel (dependent on the balance of the rider), a Normal Force from each going up, rolling friction on the front wheel and static friction in the direction of acceleration on the rear wheel"
Since you mention the weight going down and the normal force from pavement going up on each wheel, shouldn't you also mention the propulsion force that equals the friction force due to weight on rear wheel times coefficient of friction? Also in this vein, should you mention both forward and backward forces on front wheel. Don't forget, the front wheel is accelerating angularly so there is a torque term (due to angular acceleration) that equals the friction term.
"When using F=ma to find the acceleration of the bike and rider, would that mass be equal to the total mass since that is what is accelerating?"
Absolutely. It's the rider's mass plus the mass of bicycle.
  • · Replies 19 ·
