Bicycles and Mechanical Advantage
77 replies · 29K views · last reply
Orodruin said:
No.
Can you explain?
UMath1 said:
Can you explain?
Again, this is a very basic mechanical issue that suggests you need to go back to study the basics of mechanics of forces and torques before attacking the bicycle wheel. It is even unclear why you would think that the force on the ground from the wheel would be different from the force from the ground on the wheel. As you say, they are force pairs so they must be equal in magnitude and nobody has said anything to suggest that this is not the case in this thread.
There is sliding friction in the chain bushes as the chain goes from straight to curved.
Rolling resistance (In Newtons) is the heat created in the deformation of the tyre, it is deemed to be a constant value regardless of the speed on the road, simply put, it is : m * g * Crr
Dont forget air drag as well, which becomes the dominating force eventually as the speed builds.
If you consider a fixed force (f, in Newtons) on your crank, then calculate the crank torque (t) from f * r
( r = crank radius in metres )
Say you have a crank with 40 teeth and a rear wheel with 20 teeth then the rear wheel torque (T) will be :
T = t * ( 20 / 40 )
The rear wheel driving force (F) you get from :
F = T / r
( r = rear wheel rolling radius )
You can apply the above to all the gear ratios you have.
UMath1 said:
...wouldn't that then mean that...
Orodruin said:
No.
UMath1 said:
Can you explain?
It's actually up to you to justify the implications you suggest.
UMath1 said:
I understand that static friction is never overcome. The force of static friction must be present in order for the wheel to roll without slipping. What I mean is, the force of static friction has a moment arm on the wheel and thus provides a counterclockwise torque on the wheel. Therefore, in order for a stationary wheel to begin rolling forward a net clockwise torque must be provided. The only way this is possible is if the torque from the chain is greater than the torque from static friction, right?
Now my question is that if the chain's torque is greater than the torque from static friction, wouldn't that then mean that force imparted from the bicycle wheel on the ground would be greater than the force of static friction? But that can't be true, because the force imparted by the bicycle wheel on the ground must be equal to force from the ground on the wheel as per Newton's 3rd Law.
I'm not sure if you really understood the constant speed scenario, but you aren't applying what you learned. Why haven't you updated the diagram to show the acceleration forces?
So here's my understanding of the constant speed scenario. There is no net torque or net force on the bicycle wheel.
Hand-drawn free-body diagram of a bicycle wheel on a ground line, with chain force and axle force shown and static friction and rolling resistance at the contact point, plus torque and force balance equations.
Now in the case of the accelerating bicycle, the force needed for the bike to accelerate comes from static friction. However, the torque needed for the wheel to angularly accelerate comes from the chain.
Hand-drawn free-body sketch of a bicycle wheel on a slope with labeled chain and static friction forces, rolling resistance, and axle, with equations: sum of torque = I alpha, torque chain > torque friction, sum of F = m a, F_sf > F rolling resistance, F_chain = F_axle.
The issue I am having is from my understanding the force the bicycle imparts on the road is dependent on the torque it receives from the chain. For example, if the gear is 5 m radius and the wheel has a 25 m radius. Then if you pedal with a force of 10 N, the bicycle wheel will impart a force of 2 N on the ground. Then what about when the torque from the chain is more than the torque from static friction. Say for example, the maximum static friction on the bike is 10 N and you pedal with a force of 100 N. Then the bicycle wheel would impart a force of 20 N. But that would go against Newtons 3rd Law.
Rolling resistance force still has a wrong point of application.
For the accelerating case torques aren't balanced, because the angular velocity is changing.
No, the wheel would eventually slip, if you pedal too hard.
Exactly! The torques aren't bakanced. The torque of the chain is greater than the torque of static friction because angular velocity is changing. Now my question still remains: isn't force imparted by the bicycle wheel to the ground dependent on the torque it receives from the chain? If yes, then when the torque of the chain is greater than the torque of static friction, how does Newton's 3rd Law make sense? Wouldn't imply that the force of imparted by the bike is greater than the force imparted by the ground?
No. Force (or torque) pairs are always equal and opposite at the point of application. For the bike you are describing, there are two pairs:
Chain <> wheel
Wheel <> ground
Again, the parts of each pair are equal and opposite. But in a free body diagram, you only analyze what is happening to the object (the forces applied to it), not what it is doing to others. In the constant speed case, those forces (or torques) sum to zero, but in the accelerating case they do not, unless you add a term for inertia.
For example, if you push a block across the floor, the forces applied to it are:
Push + Friction = ma
Bringing inertia in for the bike is somewhat difficult because you have both linear and rotational inertia here.
What does Newton's 3rd Law have to do with this?
Can you explain the implication you are suggesting?
What I mean is, wouldn't you be able to calculate the force the bicycle imparts on the ground by simply knowing the force applied on the pedal, the gear moment arm, and the bicycle moment arm? Now to get the bike to start accelerating, the torque generated by the chain needs to be more than the torque generated by static friction. Now if I tried to calculate the force imparted by the bicycle wheel it would come to be greater than the force of static friction. That's the issue I am facing.
See the way I understand it is that static friction is the force that reacts to the force of the bike wheel, not the other way around. If that's true, then what about when the force of the bike exceeds the maximum possible static friction?
It can't. It will slip, as already explained to you.
What is your issue with that? I see nothing wrong there.
Youve been told the answer to that question several times now. I don't understand why you keep getting stuck on questions you already know the answers to. You seem to be stuck in some sort of a loop and i can't see why.
The issue with that is, because the force of static friction and the force imparted by the bike on the ground are an action-reaction pair. Then if they are not equal, how does Newton's 3rd Law apply?
But they are equal and nothing anyone else has said conflicts with that.
How many times do we need to tell you that they are equal before you will internalize it and stop asking? [/exasperated]
UMath1 said:
... what about when the force of the bike exceeds the maximum possible static friction?
The wheel slips, it loses traction.
You keep saying this and you keep getting the answer that they are equal. You will not get any further by insisting on something that you have been repeatedly told is not true. Again, this all seems to stem from fundamental misuderstandings of basic mechanical concepts, which is why I have recommended going back to study the basics of free body diagrams, forces, and torques.
Since we will not get anywhere until that has happened and the OP has been answered several times over, this thread is closed.
