Big O notation (for calculus, not computer science)
The discussion focuses on the intuitive interpretation of Big O notation in calculus, specifically regarding the expression f(x) = O(x^(-1/4)). Participants clarify that O notation typically requires a specified limit for the independent variable, which can lead to different interpretations depending on whether x approaches zero or infinity. It is noted that while f(x) can be bounded by a constant multiple of x^(-1/4), its growth rate may not align with that of n^(-1/4) due to potential oscillatory behavior. An example is provided to illustrate that f can be O(x^(-1/4)) while exhibiting a different growth rate. The conversation emphasizes the importance of specifying the context in which Big O notation is used.
kungal
I understand the formal definition for big O notation but is there an intuitive interpretation?. For example, if
Code:
f(x) = O(x[SUP]-1/4[/SUP])
is it reasonable to say that for large n f(x) grows at the same rate as
Code:
n[SUP]-1/4[/SUP]
Thanks in advance
Your first line is meaningless.
An O-notation requires a limit to which the independent variable is supposed to go.
The O's should actually be Op's (my mistake) and x is a set of random variables. I don't think this changes the nature of the question drastically.
Note that the result f(x) = Op(x-1/4) is quite common so it can't be a meaningless statement.
Yes it is.
Is it meant that f(x) is O(x^(-1/4) ) as x goes to zero, or as x goes to, say, infinity?
That is two entirely different situations, and needs, therefore, to be specified.
Hence, the meaninglessness of your first line.
I hate to disagree with Arildno but it is common practice (though perhaps "abuse of notation") to use just O(f(x)) to mean "as x goes to infinity".
Well, if that is the general default notation, I'll make a note of that.
In my own applied maths books, they dutifully make explicit what limiting operation we are speaking about
I'm glad we've cleared that up but is it reasonable to say that
if f = Op(n-1/4) then for large n f grows at the same rate as n-1/4?
Not at all.
f might, for example, become more and more strongly oscillatory as x goes to infinty, even though f's magnitude will be bounded by some constant multiplied by x^(-1/4).
For example, let
f(x)=Ax^{-\frac{1}{4}}\cos(x^{2})
This f is definitely O(x^(-1/4)), but its rate of growth will, be:
\frac{df}{dx}\to{-2A}x^{\frac{3}{4}}\sin(x^{2}), x\to\infty
Thanks
Well, O's should actually be Op's (my mistake) and x is a set of random variables.
  • · Replies 19 ·
  • · Replies 36 ·
  • · Replies 24 ·
