Biggest differences between aerospace and mechanical engineering?
The discussion centers on the differences between aerospace engineering and mechanical engineering, exploring aspects such as coursework, career paths, and the applicability of each degree. Participants share personal experiences and considerations regarding their educational choices and interests in these fields.
  • Some participants note that aerospace engineering focuses on air-borne objects, while mechanical engineering encompasses a broader range of topics, including thermal fluid sciences and materials science.
  • One participant mentions that the examples used in teaching are a significant difference, with aerospace examples often relating to flight and aerodynamics.
  • Another participant suggests that if someone is certain about working in aerospace, the specific degree may not matter as much, while others argue that a mechanical engineering degree offers more flexibility in career options.
  • Concerns are raised about gender representation in mechanical engineering, with one participant expressing hesitation about pursuing the field due to perceived demographics.
  • It is discussed that both fields cover similar foundational sciences, but aerospace engineering may require more programming and focus on fluid dynamics.
  • Some participants assert that mechanical engineers can work in aerospace, while aerospace engineers typically do not work outside of that field.
  • There is a mention of the variety of subjects covered in mechanical engineering, including thermodynamics, dynamics, and control systems, which some participants feel are not limited to machines.
  • One participant emphasizes that the distinction between the two degrees is largely based on the application of similar principles to different contexts.
Participants express a mix of opinions, with some agreeing on the similarities between the two fields while others emphasize distinct differences. The discussion remains unresolved regarding the best path for those uncertain about their specific interests.
Participants mention varying coursework and experiences based on different universities, indicating that the educational approach may differ significantly. There is also a lack of consensus on the importance of degree choice for future career opportunities.
kdoyle13
I've recently considered going back to college for engineering. What are the biggest differences in aerospace and mechanical engineering other than aerospace being focused on air born objects? I think I've really taken an interest on the side of aerospace engineering.
If you are an aerospace engineer what do you do?
What do you like most about your job?
How did you find the coursework throughout school, easy, difficult, challenging?
Thanks, just trying to get some insight!
The biggest difference is the examples used to teach the subjects. They are based on the same sciences (mechanics).
would it be better to get a bs in mechanical then?
The general rule I always tell people is that if you know for a fact that you want to work in aerospace, then it doesn't really matter. If you are on the fence, consider mechanical. I was on the fence. I did mechanical. It sure didn't hurt me getting job offers at aerospace companies or getting into an aerospace Ph.D. program.
I may be leaning toward mechE then. still not sure, more researching to do. thank you!
I'm currently an ME student. I like it because, as mentioned, I do have lots of options after I graduate. I originally wanted to do aero, but frankly I've developed interests in other areas now and will likely be pursuing those.
As far as coursework, I've been told aerospace focuses more on fluids and fluid flow. With ME you have a couple classes on fluids but will do more kinematics, machinery, materials sort of stuff. I've also been told that aerospace requires significantly more programming for whatever that's worth.
i'm thinking about ME too. But my friend told me almost only guys will take ME, which actually hindered me from taking ME because I'm a girl. what i wan to know is, is ME deals with only machines? what else can i do if i am a graduate of ME? I'm actually interested in aerospace, however you guys just said that both of them are almost similar, making me feeling scared of deciding already.
ME doesn't deal with only machines. It deals with anything and everything involving the thermal fluid sciences (fluid mechanics, thermodynamics, heat transfer, etc.), materials science (solid mechanics, metallurgy, continuum mechanics, etc.), dynamics (controls, machine design, etc.) and many hybrid areas that mix the previous three. I am sure I am forgetting things, too.
Aerospace engineering has the same three basic areas, but focuses on their aerospace applications.
I don't see where anyone mentioned that you study aerodynamics in aerospace engineering??
Aerodynamics is a subset of fluid mechanics, so it was covered. In fact, one may even say aerodynamics is fluid mechanics applied to aerospace. :biggrin:
o, so i have to study both ME and aeroE if i wan to work in aero field?
No. Many places they are distinct degrees. They are just based on the same sciences, often with similar classes using slightly different examples. That said, many MEs do work in aerospace. There aren't a lot of AEs working outside of aerospace though.
It's all basically the same, so it really doesn't matter.
As long as you don't get a degree in cheese engineering and don't look like a scruff. You'll have a reasonable chance of getting any engineering job with any engineering degree.
Edit: Within the same 'class' of stuff. So anything you can fix with a hammer.
thanks~ does MechE involves a lot of drawing and designing?
Some do, some don't. I've been in aerospace for 35 yrs. In my current job, we have 3 guys doing strictly aero work. About 150 are doing various aspects of mechanical, many with aero degrees. About 30 are doing design drawing. All aspects of mechanical are represented.
I am doing a MechEng degree at the moment (part time) but I also work for a large aerospace company.
I chose Mechanical Engineering as I thought it would be more broad and give me a wider insight to engineering, I felt that Aerospace Eng would be too focused on aerospace. However in almost all of my classes we seem to have Aero guys. Like someone said before, the examples used in class are the main difference and also a few of the modules.. such as Theory of Flight and Aerodynamics. I regularly get lecturers asking if there are any aero guys in the room, if there is they will do an example about planes, if not then its normally cars!
Also, to reitterate, Mechanical Engineers don't just study machines. I am currently or will be doing Thermodynamics, Fludis, Stress, Dynamics, Machinine Design, Material Science, Heat Transfer, Control Systems, Operation Managment, Group Project Management. Different uni's will differ though I'm sure.
12K
