Bilinear maps: showing nondegenerate in second variable
  • Thread starter Thread starter MimuiSnoopy
    Variable
The discussion revolves around proving that the bilinear map B: V* x V -> F is non-degenerate in the second variable, meaning that if B(alpha, v) = 0 for all alpha in V*, then v must be zero. Participants express uncertainty about how to demonstrate this property and whether knowledge of symmetry or skew-symmetry is relevant. There is also a mention of confusion regarding the definitions of linear functionals and their evaluations. The thread highlights the challenge of understanding the proof without access to provided answers from the university.
MimuiSnoopy
Let V be a n-dimensional vector space.
Let B: V* x V -> F (field) be the bilinear map defined by B(alpha,v) = alpha(v). Show that B in nondegenerate in the second variable. (4 marks)
I know that B is non-degenerate in the second variable if; B(alpha,v)=0 for every alpha a member of V* which implies that v=0.
My attempt was writing out the definition I know (applying it to the variables given). I do not know how to show that it is true for the bilinear map given.
The other thing I know, but not sure if it helps or not, is that if B is symmetric/skew then we can define the radical so that B is non-degenerate on each variable iff radB={0}. But I'm not sure if I need this or not.
I am currently working through some of the past papers I did for my second year units at university, trying to understand the things I couldn't do at the time ready for my third year units. However obviously the university hasn't supplied us with answers yet so I cannot check what I am doing is correct or not. Thank you for your help!
I guess I am confused about the question.
A non zero linear functional must by definition evaluate to a non-zero number for some vector. No?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
