How can we accurately calculate the time of impact in a real-life collision?
  • Thread starter Thread starter wdc
    Ball Collision
In an inelastic collision, such as a billiard ball striking another at rest, both balls share the same velocity post-impact, but the instantaneous change in their velocities raises questions about the forces involved. Ideal collisions suggest infinite forces over infinitesimal durations, while real collisions involve very large but finite forces over small durations. The discussion also explores calculating forces during collisions, particularly in a scenario involving a fast-moving airplane and a stationary rod, emphasizing the need for practical estimates of impact duration. Suggestions for determining this duration include using vibration frequencies or experimental methods like high-speed video analysis. Overall, real-life collisions are complex and often modeled using advanced simulations to account for material deformations and stresses.
wdc
In an inelastic collision of a moving billiard ball with a second ball at rest, I understand that the two balls have the same velocity after contact, correct?
But at the instant of contact how do the velocites of the two balls change instantaneously? Doesn’t that imply an infinite force?
What am I missing here? Thanks.
Sorry. I mis-titled my previous post. It should have read Inelastic collision.
You are not missing anything. An ideal collision involves an infinite force with an infinitesimal duration acting over an infinitesimal distance. A real collision will have a finite (but very large) force acting over a finite (but very small) duration acting over a finite (but very small) distance. In real life, the force will usually not even be constant over the duration of the impact.
Rather than try to measure the exact details of a collision, one can often summarize the relevant effects of a collision in terms of quantities such as "impulse" or "coefficient of restitution".
briggs444: Thanks for your post. It clarifies my problem but not completely. May I explain my problem and the approach I have been taking?
I am trying to exam the effect of a large, fast moving mass (an airplane weighing 25,000 kg moving at 350 m/sec) hitting a stationary object (say a a rod 1 square cm in cross section and 1 meter long that weighs 1 kg). I want to compute the force of the collision on the windshield.. Assuming that I know the strength of the windshield material (i.e. the value of the force (in pounds /sq. inch) that the winshield can withstand), I could then estimate how heavy the rod must be to break the windshield.
First, is this an elastic or an inelastic collision?
My approach
By the law of conservation of momentum, I compute the velocity of the airplane (and the rod) after impact:
Momentum before impact = Momentum after impact.
Thus VaMa + 0 = V’Ma + V’(Mass of rod) = V’ (Ma +1) ... where Va and V’ are the velocity of the airplane before and after the collision .
V’ = VaMa/Ma+1 = Va [1/(1+1/Ma] = Va [ 1-1/Ma]
= 350 [1-0.04 x 10*-3] = 350 (1- 4x10*-5)
So the airplane speed falls by 1400x10*-5 m/sec = 1.4 x 10-2 m/sec = 1.4 cm/sec.
Now, I compute the force that will slow the airplane speed down by this amount –-- using F=M x acceleration where acceleration = 1.4 cm/sec / delta t. But, in light of your post, what delta t do I use here... in a practical problem? I am stumped.
Needless to say I welcome your (and anyone elses) comments. ...wdc
Like all "real life" collisions, it is somewhere in between. The ideas of perfectly elastic and perfectly inelastic collisions, coefficient of restitution, etc are nice approximations, and they are very useful approximations, to teach you how to set up problems using conservation of momentum and/or energy.
In the real situation, both the rod and the windscreen are flexible objects. When you hit the windscreen, it will vibrate in and out. If you have some way to estimate the vibration frequency, that will give you an idea what delta t to use - i.e. 1/4 of the period of vibration, the time it takes to reach its maximum deformation before it "wants" to spring back again.
Another way to get the time is by experiment: hit the windscreen with a projectile that contains a force transducer, or an acclerometer, or make a high speed video (maybe 10,000 frames per second) and measure what happens. Then use that data to model a different situation with a different projectile.
For "low tech" impact testing (like the shock resistance of laptop computers, cellphones, etc if they are accidentally dropped), usually the calculation is done on the basis of past experience, using the maximum acceleration the object is meant to survive on impact. The accelerations can be very large - e.g. thousands of times the acceleration due to gravity.
For impacts that have "serious" consequences (e.g. car crashes, as well as impacts on aircraft), computer models that track the deformations and stresses in the structures over time are used. One of the industry standard programs used for this is LS-DYNA3D. You might be interested in some of the animations on their website, e.g. click the "animated result" tab at http://www.dynaexamples.com/examples-manual/misc/airbag - and explore around the rest of the site to find more. Note, those models are only small demos to show how the program works. "Real world" models may be literally thousands of times bigger, and take several days to run to simulate an impact lasting a few milliseconds.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 32 ·
  • · Replies 60 ·
  • · Replies 49 ·
  • · Replies 35 ·
