Homework Helper
- 2,176
I am sure you are familiar with experiments such as the following but I point it out for those that are not:zonde said:You make it sound like in that experiment it's arbitrary two photons that are entangled. But it's not. These two photons have to be similar enough to produce Hong-Ou Mandel interference. And in that particular experiment that you linked both photon pairs are produced from the same pulse of the same pump laser. And then of course there are four types of entanglemet that you can get. So there is quite a number of loopholes in your argument.
http://arxiv.org/abs/1209.4191
Entanglement Between Photons that have Never Coexisted
http://arxiv.org/abs/0809.3991
High-fidelity entanglement swapping with fully independent sources
The pairs do not need to be produced from the same laser (regardless of the particular experiment I referenced earlier). They need only be phase locked together. It doesn't matter how many types of entanglement are produced, you know which one to expect. In fact you can can choose to cause it if you like.
My point is that a lot of folks picture a situation where the photons start from a common source so "naturally" they exhibit correlations - there is a common cause. But these pairs of photons have NO common point of overlap since they are never in a common light cone. And they do not exhibit the perfect correlations unless they are entangled, something which can be done anywhere and at anytime before or after detection.
