BJT voltage divider bias beta variation
7 replies · 5K views · last reply
likephysics
Given, β=100, Is = 6E-16
See attachment.
a) Find min value of Rb such that the BJT is in active region
b) For the Rb found, what is the base-collector voltage if β=200
Assuming, VCE min for active region operation as 0.75V, I got Ic = 0.87mA
since β=100, Ib = 0.0087mA
Vbe = Vt ln (Ic/Is) = 0.728V
using Ib = (Vth-Vbe)/Rth {thevenin equivalent}, I got Rbmin as 7K. The voltage divider voltage is 0.75v and Rth is 2.1k.
But now, when I plug in Ib = Vth-Vbe/Rth, I get 0.00104mA. Which Ib is correct?
I can't figure out how to calculate the beta change. Where do I use the beta?
Ib is 0.0087mA, with new beta Ic will be 1.74mA. which will make IcRc = 3.48v, which doesn't make sense.
  • Circuit schematic of a BJT voltage divider bias stage: VCC = 2.5 V at the top, R_B and a 3 kΩ resistor forming the divider to ground, a 2 kΩ collector resistor, and transistor Q1 with its emitter grounded.
See attachment.
[/b]
Rb has to furnish the base current plus the current thru the 3K. So how did you arrive at that strange equation for Rb? You know Vcc and you calculated ib and Vbe correctly, so what is the right equation for Rb?
I can't figure out the equation for Rb.
I assumed the Vth as 0.75v (voltage divider output)
So, if Rb=7k, I get Vth as 0.75v
Equation for Rb = (Vcc-Vth)/Ix
Ix=0.25mA (this is the current flowing thru the voltage divider).
To supply the desired Ib, Rth should be 2.1k
Rth = Rb(3K)/(Rb+3k)
I don't know what Vth is. Stop worrying about Thevenin equivalents. That theorem is not appropriate here.
Instead, write an equation summing currens to zero at the base.
Whenever I see voltage divider bias, I immediately think thevenin.
Anyway,
Vcc-Vbe/Rb = Vbe/3k + Ib
I know, Ib = 0.0087mA and Vbe = 0.728v
I get, Rb = 7.05K
How do I use the new β?
Anyway,
I get, Rb = 7.05K
Almost.
(Vcc - Vbe)/Rb = Vbe/3K + Ib. Which I think is what you meant anyway. So, so far, so good.
Rb = 7.05K is correct.
With the new beta of 200, what do you compute Ic to be? Vc? Realizing that Ic can't exceed 2.5V/2K and Vc can't be < 0V, what do you conclude about Ic and Vc?
Max Vce is Vce sat, which is about 200mV generally.
This will result in an Icmax of Ic = (2.5-0.2)/2K = 1.15mA
IS that it , you just assume Vce?
I would give you an A at this point.
Saturation voltage is a tricky business, it depends a whole lot on the particular type of transistor. At saturation, the base-collector junction is also forward-biased. Generally, Vc_sat is lower than 200 mV. More like 50-100 mV. But you see the picture vey well now.
